Author Topic: [Nanao MS9-29] Picture moves and expands etc  (Read 26339 times)
Sledge
  • Last login:August 02, 2025, 01:37:53 am
Re: [Nanao MS9-29] Picture moves and expands etc
« Reply #80 on: September 13, 2013, 11:32:53 pm »
Hi.. umm.. me again
So I'm trying to use winmodelines...
added this mode line:
Modeline "800x600_50,0Hz 16,0KHz (60Hz)" 15.823 800 808 883 992 600 601 607 638 interlace -hsync -vsync
seems to be available and working...
But SFxTekken still crashes :(
Any ideas what I could try next?
Should I try to make it a 60Hz mode? if so how?
Should I try adding some 31Khz modelines even if I don't use them... maybe they will help SFxTK to start? if so.. how?
I tried loading winmodelines in XP to see if it would show me what the modeline is for 800x600, but it only lists the 15Khz modes in there...
« Last Edit: September 14, 2013, 12:42:58 am by Sledge »
Sledge
« Reply #81 on: September 14, 2013, 01:24:18 am »
Also the reason why I'm thinking it may be something to do with 800x600 is this in the readme as a requirement:
Monitor:
       800 x 600(SVGA) or higher
In game though it allows me to choose 640x480 as a resolution
  • Online Online
  • Last login:Today at 04:53:27 pm
« Reply #82 on: September 21, 2013, 12:51:13 pm »
You can't make it a 60 Hz mode due to the frequencies involved. But you can keep the same modeline and label it as 60 Hz, (800x600_50). This can be done with Winmodelines, by editing the figures between " ".
Sledge
« Reply #83 on: September 22, 2013, 03:11:34 am »
Well that didn't help SFxTekken :(
there must be some reason for it not to be working..
Works fine in XP with Calamity drivers... hrmmm...
If I start the PC with and LCD connected, then switch to a 15khz mode, switch to the Arcade screen, SFxTK runs.. but slowly.. and in a window
If I go fullscreen, the game runs faster, but split into 2 screens through the JPAC
Edit:
Just found another game that works with LCD but not Arcade screen... Star defender 4
« Last Edit: September 22, 2013, 06:31:47 am by Sledge »
Sledge
« Reply #84 on: September 28, 2013, 02:18:35 am »
well just tried with an AVGA, and SFxTekken still doesn't work....
Oh well.. just have to do without that game I guess...
  • Online Online
« Reply #85 on: September 28, 2013, 04:38:47 am »
It could be Windows 7 is reporting your manually added 800x600 modelines as having a halved refresh, like 25 or 30, because they're interlaced, so the game can't find them. Try adding a real 800x600 SVGA mode through Winmodelines using the VESA GTF preset so the game will find it (obviously, don't try this mode on your arcade monitor!).
Anyway, as a general rule, a program that crashes or refuses to run because it doesn't find a certain resolution is a poorly coded program, if you ask me. Blame its creators.
Sledge
« Reply #86 on: September 28, 2013, 08:19:33 pm »
Sorry.. I tried this with an absolutely fresh install of windows...
And yes, I do blame it's creators :(
Sledge
« Reply #87 on: January 04, 2014, 08:46:25 am »
Just thought i'd put this here in case it's an issue with the monitor setup, rather than start a new thread..
I just went to play Moon Patrol but i get a scrambled screen:
I'm currently using:
monitor = custom
crt_range0  15450-16050, 50-65, 3.910, 4.700, 6.850, 0.190, 0.191, 1.018, 0, 0, 192, 288, 448, 576
but, it does the same thing using the ms929 preset as well..
any idea what could be going wrong?
My friend who also has an AVGA, says it works for him.. chooses 256x256 for him also...
All games that use 256x256 seem to be the same...
Maybe just the h-hold need adjusting?
« Last Edit: January 04, 2014, 09:04:01 am by Sledge »
  • Online Online
« Reply #88 on: January 04, 2014, 09:16:51 am »
Sure.
Sledge
« Reply #89 on: January 04, 2014, 10:36:27 pm »
Sure.
Yep :)
All good now!
wasn't a software issue :)
Dalba
  • Last login:August 18, 2025, 02:54:37 pm
« Reply #90 on: January 13, 2014, 10:07:32 am »
Hello,
on my nanao MS9-29 if i use the specific user monitor preset in vmmaker and use "ms929" in mame.ini as monitor type, i just can't have resolutions correctly centered. But if i use the default custom preset in vmmaker, and set "arcade_15" in mame.ini, all my resolutions are near perfectly centered.
I also have a nanao MS-2931, and i can use the specifics preset in vmmaker and mame.ini without problems !
So am i the only one suffering problems with nanao ms9-29 presets ?   I'm using xp32 with crt_emu 9.3. Using x1900xt or hd4350 and changing crt_emu driver 6.5 or 9.3 never solve this problem.
  • Online Online
« Reply #91 on: January 13, 2014, 05:35:54 pm »
A given preset is not supposed to end up centered magically, you usually need to readjust your monitor potentiometers the first time. However, if the "arcade_15" preset matches better your current monitor adjustment, just stick with it, unless your ms9-29 is one of the auto-switching models (15/25 kHz).
Dalba
« Reply #92 on: January 14, 2014, 04:25:02 am »
By "not centered correctly" i mean that if i adjust one game in 320x240 for example, others resolution won't be centered. Some will have black borders on one side, some will be out of screen on left or right...
With default custom preset in vmmaker, and arcade_15 in mame, i just have to center one resolution and all the rest is ok...  That's why i wonder if preset for ms9-29 submitted by user is correct, or if it is a problem on groovymame side...
Sledge
« Reply #93 on: January 14, 2014, 04:39:10 am »
FYI as above i'm using this:
monitor = custom
though i have easy access to the v-size pot for games that run at 288 lines...
horizontally speaking though, i think most of my games are centered, except for maybe Street fighter games maybe move a little... but nothing major..
  • Online Online
« Reply #94 on: January 14, 2014, 12:06:24 pm »
Dalba, it could be your monitor reacts slightly different from Sledge's. For running fixed-sync, or dual-sync monitors but only using the 15 kHz range, my advice is to use the standard presets (arcade_15, etc.).
