Author Topic: [Nanao MS9-29] Picture moves and expands etc  (Read 26810 times)
  • Last login:Today at 05:02:24 pm
Re: Picture moves and expands etc
« Reply #40 on: June 26, 2013, 07:52:39 am »
this is viewing through teamviewer so you can see the effect.. on screen I can't see anything due to the picture being way off to the left
Aha. Try disabling/uninstalling teamviewer, these remote access software usually install a mirror video driver which interacts with the local video driver badly (it's not he first time that similar erros have been reported).
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #41 on: June 26, 2013, 07:53:36 am »
Do you happen to be running some of those programs that makes all changes to the system be temporal so that when once you reboot everything is restored (can't remember the name)?
no nothing like that running..
just windows XP x64 with your drivers with magic resolutions..
hrmm ok... will make things harder to setup lol.. but will see what happens
« Last Edit: August 01, 2013, 08:31:27 pm by Sledge »
« Reply #42 on: June 26, 2013, 07:55:30 am »
Also, try setting the desktop to a resolution which is not 1234x ... (640x480 for instance).
And... when in the game, when the screen is off, try moving the mouse to see if you can pan on the picture.
Sledge
« Reply #43 on: June 26, 2013, 08:11:27 am »
ok yep that's better now :)
normal desktop resolution is 640x480.. that's the lowest it will go..in windows
when the screen is off.. how will I know if it is moving?
« Reply #44 on: June 26, 2013, 08:15:57 am »
Sorry, I didn't mean the screen turn off, but when the picture is way off to the left, I wondered if it's possible to get it in the center by moving the mouse.
Anyway, I didn't understand, does it work now when launching donkey kong?
Sledge
« Reply #45 on: June 26, 2013, 08:23:12 am »
yes it's working fine now... :)
uninstalling teamviewer did the trick..
however some other game do not display correctly? all weird and squiggly like a totally wrong resolution..
puckman was fine but puckmanh isn't
actually quite a few games are no longer displaying correctly the same way...
Truxton is doing the same thing..
« Last Edit: June 26, 2013, 08:35:33 am by Sledge »
Sledge
« Reply #46 on: June 26, 2013, 08:44:31 am »
this is what truxton looks like..
« Reply #47 on: June 26, 2013, 08:57:37 am »
Do you get a stable picture if you test 1234x320 on ArcadeOSD?
« Reply #48 on: June 26, 2013, 09:27:10 am »
Check this thread:
http://forum.arcadecontrols.com/index.php/topic,87528.msg919065.html#msg919065
Check if your model is the one that autoswitches from 15/24 KHz. If that's the case, you may need to adjust the 24 kHz H-freq potentiometer.
Sledge
« Reply #49 on: June 26, 2013, 09:59:18 pm »
no my monitor is not the autoswitching type. it has a cable which needs to be manually switched from 15 to 24..
So I assume I need to limit everything to 15khz..
I will try Arcade OSD with that res asap.
Edit: No I do not get a stable picture with 1234x320
no stable picture with any of the 23khz and above modes
now running VMMaker without the monitor spec1 line in it...
ok everything seems ok now.. except that all vertical games seem to run in 640x480
Is that normal?
going back to normal resolutions (not magic) gives me 105 modes, and then the vertical game I tried (tiger heli) ran at 704x480
Will getting an ArcadeVGA help with this? Are there any issues I should know about with the arcadeVGA and groovymame?
« Last Edit: June 28, 2013, 08:53:50 am by Sledge »
« Reply #50 on: June 29, 2013, 10:33:10 am »
Hi Sledge,
Ok, if your monitor is not the autoswitching type then you need to decide which of either ranges to use, and definitely the 15 kHz one is the one to choose.
All your vertical games run at 640x480 because if you remember from your above posts, you wanted to limit the total height used by MAME, so we set this limitation here:
monitor_specs0    15450.00-16050.00, 55-65, 3.91, 4.70, 6.85, 0.190, 0.191, 1.018, 0, 0, 248, 448
If you want to restore the capability of using higher vertical resolutions, set that value back to normal, like this:
monitor_specs0    15450.00-16050.00, 55-65, 3.91, 4.70, 6.85, 0.190, 0.191, 1.018, 0, 0, 288, 448
Or whatever in the middle, e.g. limit it to 256 lines in case you can't access the v-size pot:
monitor_specs0    15450.00-16050.00, 55-65, 3.91, 4.70, 6.85, 0.190, 0.191, 1.018, 0, 0, 256, 448
Then in mame.ini, set the corresponding custom line by using these two options:
monitor custom
crt_range0              15450-16050, 50-65, 3.910, 4.700, 6.850, 0.190, 0.191, 1.018, 0, 0, 192, 288, 448, 576
So as you see, it's up to you to decide which maximum height will trigger the interlaced+stretched mode.
Sledge
« Reply #51 on: June 29, 2013, 11:02:14 am »
Hi Calamity,
Yes I reverted the monitor specs in VMMaker back to this:
No change..
I converted that to the above and put it into the mame.ini
Still no change...
still 640x480..
I have attached a log file..
I appreciate your trying to help :)
« Last Edit: June 29, 2013, 11:07:00 am by Sledge »
« Reply #52 on: June 29, 2013, 11:29:55 am »
You need to run VMMaker with the new settings so you create the required resolutions, now you don't have progressive resolutions above 264, see:
Switchres: [ 35] 1234x 248 @ 59: DALDTMCRTBCD1234x248x0x59 - Modeline "1232x248_59 16.05KHz 59.43Hz" 26.19 1232 1336 1456 1632 248 251 254 270   -hsync -vsync
Switchres: [ 36] 1234x 256 @ 58: DALDTMCRTBCD1234x256x0x58 - Modeline "1232x256_58 16.05KHz 57.72Hz" 26.19 1232 1336 1456 1632 256 259 262 278   -hsync -vsync
Switchres: [ 37] 1234x 264 @ 56: DALDTMCRTBCD1234x264x0x56 - Modeline "1232x264_56 16.05KHz 56.11Hz" 26.19 1232 1336 1456 1632 264 267 270 286   -hsync -vsync
Switchres: [ 38] 1234x 448 @ 60: DALDTMCRTBCD1234x448x0x60 - Modeline "1232x448_60 15.53KHz 60.06Hz" 25.09 1232 1328 1448 1616 448 467 473 517 interlace  -hsync -vsync
Also, you forgot setting 'monitor custom' in mame.ini.
Sledge
« Reply #53 on: June 29, 2013, 11:46:32 am »
Sorry.. I don't understand any of this stuff lol..
Changed ms929 to custom(didn't realise I had to do that sorry/missed that bit..),also changed: 15450.00-16050.00, 55-65 to 15450.00-16050.00, 50-65, and ran VMMaker again with magic resolutions set..
rebooted... now tigerheli runs at 432x280p ?? is that right now? seems right to my uneducated mind..
« Last Edit: June 29, 2013, 11:55:05 am by Sledge »
« Reply #54 on: June 29, 2013, 12:00:07 pm »
That's right now :)
280p equals the height of that game, same for 'contra'. Try dspirit too, it should be 288p. Try 1942, it should be 256p.
etc.
Sledge
« Reply #55 on: June 29, 2013, 08:49:50 pm »
1 more question.. if the games are too tall..(for the cabinet) the only way to shrink them a little bit (2cm or so) is with the vertical pots on the screen? (or limit the resolutions so they run at 640x480)
Thanks for your help Calamity!
Edit: I've now got my vertical limit set to 256, so everything above is interlaced, and now all on screen..
« Last Edit: July 27, 2013, 08:18:30 am by Sledge »
Sledge
« Reply #56 on: July 27, 2013, 08:18:40 am »
And for future reference this is my custom monitor settings for MS9-29 :
crt_range0                15450.00-16050.00, 50-65, 4.389, 4.389, 8.046, 0.190, 0.191, 1.018, 0, 0, 192, 256, 448, 576
a little different to the presets thread..
taken from 512x240 geometry....not sure if this is the correct one to get the settings from...
« Reply #57 on: July 27, 2013, 10:16:03 am »
Thanks for the reference. I'll edit your first post topic with your monitor type so future readers find the information easier.
Sledge
Re: [Nanao MS9-29] Picture moves and expands etc
« Reply #58 on: August 01, 2013, 12:30:33 am »
ok... as an experiment I installed Win7, with Soft15 etc
got 15hz modelines installed..
but when I try to run a game with refresh_dont_care 1 I get a blank screen and no sound
refresh_dont_care 0 = the games all run at 640x480
I'm running in d3d to avoid the interlace to non interlace win 7 issue
anyone got an idea as to what I need to do?
EDIT: Actually.. it's weird.. sometimes it works.. most times not
only other difference is now I added an SSD as well... too fast for it?
Direct3D: Error 88760868 during device present call
something to do with that maybe? but why?
« Last Edit: August 01, 2013, 01:03:27 am by Sledge »
« Reply #59 on: August 01, 2013, 03:04:39 pm »
Try running GroovyMAME from an elevated console (run cmd.exe as administrator).
Sledge
« Reply #60 on: August 01, 2013, 06:49:43 pm »
same thing happens..
1 out of 5 or so tries will start a game
though I did notice a LOT of lag in 1941 when it did run...(720x480@59.63) syncrefresh seemed to fix this i think??
1942 seemed ok (400x256@57.73)
OK.. seems the games are definitely running... just not in focus.. I have to ALT-TAB to them...
« Last Edit: August 01, 2013, 08:17:44 pm by Sledge »
« Reply #61 on: August 02, 2013, 05:58:08 am »
How are you launching the games? Your log show two video displays, which one is your primary device?
Sledge
« Reply #62 on: August 02, 2013, 06:09:42 am »
when testing I run them from cmd, but it does the same through hyperspin as well
I only have the HD4850 installed, connected to a Jpac => arcade screen.
« Reply #63 on: August 02, 2013, 06:13:31 am »
Video: Monitor 0000000000010001 = "\\.\DISPLAY1" (primary)
Video: Monitor 0000000000010003 = "\\.\DISPLAY2"
Do you have two monitors?
Sledge
« Reply #64 on: August 02, 2013, 06:17:49 am »
no.. I don't :(
« Reply #65 on: August 02, 2013, 06:25:55 am »
That's odd. So you say it's like the application didn't start maximized? Try running it with the -nomt option.
Sledge
« Reply #66 on: August 02, 2013, 06:27:21 am »
I ran it once and it worked fine:
Starting AY-3-8910A ':ay1'
Starting AY-3-8910A ':ay2'
did it again and it didn't work.. had to ALT-TAB to the game..
same section as above has this:
for my info.. what is -nomt ?
all I get is a blank screen.. but I can ALT-TAB to the game.. sometimes I have to ALT-TAB twice for it to work...
Sledge
« Reply #67 on: August 02, 2013, 06:33:42 am »
yep, this makes it display every time!
can that go in the ini? or do I need to work out how to get hyperspin to parse that?
« Last Edit: August 02, 2013, 06:36:18 am by Sledge »
« Reply #68 on: August 02, 2013, 06:39:26 am »
That option is to disable multithreading. It seems there's a slight problem with GM's threads syncronization in your system.
« Reply #69 on: August 02, 2013, 06:40:10 am »
You can put it in the ini, of course. Edit this option:
multithreading 0
Sledge
« Reply #70 on: August 02, 2013, 06:49:59 am »
multithreading 0
yep did that.. but OMG everything is so slow now :(
1941 = 50.23%
1942 = 82.41%
sf2 =100%
hrmm
« Reply #71 on: August 02, 2013, 06:54:34 am »
Try one of these things (not both at once):
-syncrefresh_tolerance 10.0
or
-syncrefresh
Sledge
« Reply #72 on: August 02, 2013, 07:01:23 am »
already have syncrefesh 1 in ini
using that option in cmd = no change
= unknown option
syncrefresh_tolerance 10.0 in ini = no difference
maybe I should just get an AVGA or go back to XP until you release next drivers.. then try again?
« Last Edit: August 02, 2013, 07:05:53 am by Sledge »
« Reply #73 on: August 02, 2013, 07:22:31 am »
Have you tried with -video ddraw? The latest version of GM shouldn't have problems with switching between interlaced/progressive. Possibly with -video ddraw you can keep multihreading enabled so the performance is not degraded.
Sledge
« Reply #74 on: August 02, 2013, 07:27:39 am »
yes
1941 runs at 80% or so with -nomt (starts every time ok and at 100% without -nomt)
1942 = Unable to initialize DirectDraw
« Last Edit: August 02, 2013, 07:32:13 am by Sledge »
Sledge
« Reply #75 on: September 05, 2013, 02:26:57 am »
So I'm now using a different video card, and all my settings are screwed up...
Should custom monitor settings change depending on the video card? I wouldn't have though so...
now using:
Win 7 with latest drivers/VMMaker
HD2600pro
these were the settings that worked for me before:15450.00-16050.00, 50-65, 4.389, 4.389, 8.046, 0.190, 0.191, 1.018, 0, 0, 256, 448
Now reverting back to the settings in the presets thread: 15450.00-16050.00, 55-65, 3.91, 4.70, 6.85, 0.190, 0.191, 1.018, 0, 0, 256, 448
Still not quite right.. but they will do...
Also in the monitor presets thread it says this:
Additionally, and opposite to GroovyMAME, VMMaker needs the MonitorType = "CUSTOM" option in order to process any monitor_specs lines.
So what should MonitorType = in mame.ini ??
I think I have that set to Custom as well.. ??
« Last Edit: September 06, 2013, 04:10:24 am by Sledge »
« Reply #76 on: September 07, 2013, 08:36:40 am »
That thread is outdated, sorry. Now, you need to use "custom" in both cases.
Sledge
« Reply #77 on: September 10, 2013, 05:18:47 am »
How do I add 800x600 as a resolution to be available as native/custom etc
Need it to be available for PC Games.... (Monitor does display that resolution)
I think this is why SFxTekken crashes at startup...
If I start the cabinet with an LCD, SFxT works fine...
« Last Edit: September 10, 2013, 06:02:31 am by Sledge »
« Reply #78 on: September 12, 2013, 02:37:53 pm »
Hi Sledge,
You have two ways of adding the 800x600 resolution:
- Add a definition for it in ReslList.txt, following the format in there (spaces included). Then select a monitor preset that's capable of that resolution in vmmaker.ini, and run VMMaker, or
- Use Winmodelines to add an 800x600 modeline.
Sledge
« Reply #79 on: September 12, 2013, 07:15:09 pm »
I did try this, but it didn't seem to work..
in VMMaker I'm using the CUSTOM preset
Will have a look at Winmodelines and see if I can work that out..
« Last Edit: September 12, 2013, 11:41:06 pm by Sledge »
