Author Topic: Need advice on materials  (Read 3314 times)
fantoboy
  • Last login:May 24, 2017, 02:02:13 pm
  • I'm a mushroom cloud layin' motha fu($@!
« on: August 23, 2012, 09:30:57 am »
With a bartop arcade, what would you consider the best material?  I see a lot of people dislike MDF.  So what are the alternatives?  Melamine?
Also- what could I use for a control panel where the front edge is curved down?  A rounded edge between the top of the control panel and front rather than a corner.
Re: Need advice on materials
« Reply #1 on: August 23, 2012, 09:48:46 am »
I used MDF on my weecade clone (darkade).  I also did a downward curve on the CP with MDF. Covered with art and plexi.
yaksplat
    • Random Projects
« Reply #2 on: August 23, 2012, 11:37:29 am »
3/4" maple/birch plywood.  Face the birch side out for a smoother finish with no visible grain.
http://yaksplat.wordpress.com
TopJimmyCooks
« Reply #3 on: August 23, 2012, 11:42:34 am »
I would consider 1/2" birch ply for everything that doesn't have t mould.  use 3/4" for the sides for widest range of T mold compatibility.  Of course, you have to buy a sheet of whatever so having two sizes would add $50 or so to your cost.
If I ever build a bartop, I will make 3 -4 sets of wood parts to use up the stock efficiently.  if you're making templates anyway, you can fly through the multiples.
There's nothing wrong with MDF either - you're trading less structural strength for easier painting.  it weighs more but not a big issue on a bartop.
Woodshop Flunky
« Reply #4 on: August 24, 2012, 02:21:08 am »
I'd use 1/2 inch MDF for the sides.  For a small cabinet, 1/2 seems better to me.
For all the battens and center panels, I'd use 3/4 inch plywood.  It's strong and takes a screw real well.
For the CP, I'd also use the 1/2 MDF.  You can shape it easily, and glue holds MDF just fine.
I think some hardware stores, Home Depot, and maybe Ace sell sheet material cut in smaller sections (2x2 or 4x4).  Not 100% sure... it's been a while since I've looked at that sort of thing.  Anyhow, it might keep you from having to buy full sheets.
