February 24, 2026, 03:36:41 am
I used transparent corner protectors (used for walls) from local hardware store and spray painted the inside black. They are made of a hard plastic, but have held up pretty well for me over the years. If you try this route, avoid the ones with the adhesive already on.. it's virtually impossible to dissolve that glue without marring up the inside. Thanks or a great suggestion. I will look into this.
If you have access to a router and want to put t-molding across the top and bottom of the marquee check this out:http://forum.arcadecontrols.com/index.php?topic=107100.msg1138345#msg1138345I did this on my cab and it worked really well.Here's another cheap option but it is a Canadian retailer:https://www.theplaydiumstore.com/p-1824-retainer-for-video-game-marquee-5ft-lengths.aspxI'm sure you can find this at places in the US as well.Good luck!Dino Z.
