Author Topic: NO PC LED controllers?  (Read 2022 times)
gatordad
  • Trade Count: (+11)
  • Last login:November 06, 2025, 10:15:06 am
« on: July 13, 2012, 08:49:03 pm »
Are there any LED controllers that do not require a PC available, or am I stuck with just direct power from a 5v source?
I only need 9 buttons lit but would like to have an attract mode etc.
Re: NO PC LED controllers?
« Reply #1 on: July 13, 2012, 09:47:48 pm »
Arduino?
« Reply #2 on: July 13, 2012, 10:44:28 pm »
PACLED64 can run an animation without being connected to a computer (usb). If it's powered it will run the programmed animation (default or one you load on it).
  • Last login:November 26, 2025, 03:26:23 pm
« Reply #3 on: July 13, 2012, 10:51:35 pm »
http://www.pcboard.ca/ LED rainbow (http://www.pcboard.ca/kits/led_rainbow/) is a pretty good unit. We have used a few dozen of them. Cheap and easy to put together....and programmable too.
gatordad
« Reply #4 on: July 14, 2012, 11:45:58 am »
When I say NO PC I meant no usb plug power so power would come from a direct 5v source.
Mysterioii
« Reply #5 on: July 14, 2012, 12:25:33 pm »
Take any one of em that's powered off of usb and solder two wires on there and connect it to any 5 volt source you want.  Or program an arduino as suggested...  it already allowa you to power it from either the usb or a power jack
« Reply #6 on: July 15, 2012, 12:48:28 am »
LED rainbow runs off 12 volts. throw it on a wall wart and done.
