Poll
What colour T-Molding should I get
Red
1 (16.7%)
Yellow
1 (16.7%)
Black
0 (0%)
Chrome
3 (50%)
Other
1 (16.7%)
Total Members Voted: 6
Author Topic: No longer Cursed - 1st Bartop Build 95% complete.  (Read 21888 times)
rtkiii
  • Last login:May 07, 2024, 04:42:35 pm
  • Ready to Build! Not building? Making Movies!
    • RTKIII Productions YouTube Channel
Re: AM I CURSED? - 1st Bartop Build 95% complete.
« Reply #40 on: March 26, 2013, 09:20:36 am »
Nice build...
Drnick
  • Plodding Through Life
« Reply #41 on: March 26, 2013, 01:42:41 pm »
Very small update.  I decided that the noise from the 2 fans in the machine was too much.  I could of course remove 1 of them or install some resistors to slow them down. Instead I decided to just order in some new fans.  This time I am colour co-ordinating and going with red fans that have the ability to change the speed by adjusting a built in screw.
Drnick
Re: No longer Cursed - 1st Bartop Build 95% complete.
« Reply #42 on: April 03, 2013, 03:38:13 am »
And another tiny update,  Glass has arrived and I will be collecting it tonight.  The replacement Dingleberry has arrived from Ultimarc, Installed this and 4-8 way all working as it should.  I also figured out why in 8 way mode it would stick,  I needed 1mm additional clearance at the bottom  of the panel. I added some weather stripping to my control panel supports and perfecto.  (I will most likely adjust the supports up a bit.
So for now all I have left to do is.
Swap out Fans
Install Glass
Adjust CP Supports
Install Feet
Tidy the Wiring up.
On a side note, I spent a day over the weekend sorting out a Racing wheel setup using a spare Dual Core unit connected to my 40".  Due to using older equipment I was limited to using XP32 with Service Pack 2 & DX9.  This means newer emulators will not be possible as they are moving onto newer versions of DX but everything I have thrown at it so far works pretty good.   There are plenty of PC Racers to go with Model 2 emulation and Mame to keep me happy.   I just have to build some kind of stand for the steering wheels as the workbench I am currently using is about 12" too High for comfortable extended play.
EssexMame
  • Last login:February 05, 2026, 08:12:04 am
  • Mame Weekender
« Reply #43 on: April 03, 2013, 05:01:09 am »
95% complete and it looks like you're just about to start the next - the full-on driving cabinet  ;) Want to make me one too ?!
Drnick
« Reply #44 on: April 04, 2013, 08:07:38 am »
I can't see myself making a full sized cabinet for driving games. It will more likely be some kind of foldable unit that the wheel's/Pedals attach to. I can see myself making a virtual Pinball though. Then I would have the set Arcade,Pinball,Driving,Jukebox.  The only issue with any of it is that I think the wifes going to kill me if I try to squeeze anything else into the room I have (15ft Long by 9Ft wide by 9Ft High) Mind you looking at it If I replace the 2 chest freezers with 1 Big upright that would buy me room for another Item  :laugh2: :laugh2:
EssexMame
  • Mame Weekender
« Reply #45 on: May 01, 2013, 07:28:42 am »
Hi Nic,
You got your t-molding and slot cutter (with arbour?) from t-molding.com I believe - how were they. It took ages to arrive didn't it, but got there in the end and the slot cutter and t-molding are all good?
Don't know why I'm even looking yet, it'll be ages before I'm installing t-molding, but the research part is easy to do at work, the sawing less so!
Drnick
« Reply #46 on: May 01, 2013, 07:48:13 am »
Yep, I ordered it all together from t-molding.com  It did take a while to arrive but I think that had more to do with Royal Mail then anything else  :angry: :angry: Hey if you order it now by the time it arrives you should be ready for it.  :cheers:
T-mold and slot cutter are excellent quality.  Just remember to put the slot cutter on the arbour the right way up  >:D
I really must finish my machine off.  All I need to do now is pull the control panel and rout a new Plexipanel for it.  The glass is fitted the fans have been swapped out,  the CP has been adjusted.  Unfortunately I have mostly been playing games on it and getting distracted by the racing setup I have been configuring. Oh well them's the breaks.  I also just picked up a 21" Monitor so am thinking of building a full sized upright now that the weather is improving.  Unfortunately the wife won't let me do that until I get a shed built and get rid of some junk out the house  :laugh2: :laugh2:
