Author Topic: Attaching cabinet pieces together  (Read 3583 times)
jspicher
  • Last login:March 09, 2023, 08:00:47 am
« on: May 27, 2012, 11:28:36 am »
Hi guys,
I've recently started work on a "from scratch" cabinet. My first cabinet l had a cabinet maker CNC the parts and everything attaches with cool little locking mechanisms.
However l'm going this one alone and don't have a CNC at my disposal and will be doing this the old fashion way.
So l've got my major pieces all cut (side front, top, bottom etc) and l wanted to know what the "best" method for attaching the pieces together is. I was thinking about going with little metal L brackets from the inside with 3/4'' screws but know from experience this can lead to imperfect corners/gaps because of the curvature of the metal brackets.
Maybe something like this is best:
http://www.amazon.com/Black-Corner-Brace-pkg-11655BK/dp/B000VW7PR8/ref=sr_1_7?ie=UTF8&qid=1338132448&sr=8-7
What technique do most of you use to attach the pieces together?
A little assistance would be greatly appreciated.
EightBySix
Re: Attaching cabinet pieces together
« Reply #1 on: May 27, 2012, 11:31:16 am »
Google "modesty blocks". Although most use a baton of wood
jspicher
« Reply #2 on: May 27, 2012, 11:36:58 am »
Cool thanks.
You think these are better than something like this: http://amzn.to/MRcgxD ?
Regards,
darthpaul
  • Last login:February 22, 2026, 10:22:50 am
  • Join, It's your duty
« Reply #3 on: May 27, 2012, 12:32:56 pm »
Used the baton method and pocket screws.
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
walker_tr9
  • Last login:May 27, 2024, 11:34:28 am
  • Infinity is not a number!
« Reply #4 on: May 27, 2012, 07:11:19 pm »
What exactly is the baton method?  Is this where you put a strip of wood at the cabinet "wall" as added support for a shelf?
GregD
  • Last login:December 23, 2025, 04:38:08 pm
    • Arcade Nebula
« Reply #5 on: May 29, 2012, 09:11:30 am »
Yes.  Do not use angle brackets.  Waste of money and I think the results are worse.  Cam locks sound nice and are useful if you need to disassemble but they do not provide a strong joint.  Batons all the way for the main carcass and pocket hole/biscuit joinery everywhere else.
MTPPC
« Reply #6 on: June 25, 2012, 03:54:48 pm »
Batons with glue and a 18ga air brad nailer FTW.
http://pinballmd.com/
