Author Topic: Nora's Neo-Geo MVS Mini (5/12/14 UPDATE)  (Read 53723 times)
Yvan256
  • Last login:February 22, 2026, 05:26:42 pm
    • Yvan256
Re: Nora's Neo-Geo MVS Mini (04/23/13 - Painting 85% Finished)
« Reply #120 on: May 02, 2013, 11:28:09 pm »
Thanks guys! Everything is coming along nicely.
One of my friends is helping me with the marquee.  Here is what he has so far:
My initial thought was to have a marquee resembling the Neo Geo marquees, but now I'm leaning towards having something original, simple, and "kiddy".
Cheers!
How about a Neo-Geo MVS style marquee but with obvious "kiddy" elements, such as using a "Felt" font for the text?
Unstupid
« Reply #121 on: May 03, 2013, 07:21:18 am »
Cheers!
This cab looks way too nice for that artwork!
CWorley
  • Last login:August 09, 2019, 07:44:36 pm
Re: Nora's Neo-Geo MVS Mini (05/02/13 - Marquee Started)
« Reply #122 on: May 03, 2013, 08:50:24 am »
After sleeping on it, decided the marquee needs to stay true to the Neo Geo theme.  I would like to personalize it a bit though for my daughter.
Suggestions are definitely welcomed.
Cheers!
Re: Nora's Neo-Geo MVS Mini (05/03/13 - Marquee Suggestions Needed)
« Reply #123 on: May 03, 2013, 09:42:07 am »
Maybe Nora Geo instead of Neo Geo.
....or a modified version of the Neo Geo Station logo.
....or borrow from one of the newer, more colorful SNK candy cabs, like the Neo 29. (although I'm not sure that works with the CP)
....or a standard marquee in purple with her picture in the "now featuring" window.
You could try to incorporate the faces, but make them cuter.
Just throwing ideas out there.
Just had another thought: cute little bust-a-move dinosaurs....
« Last Edit: May 03, 2013, 09:44:31 am by BadMouth »
CWorley
« Reply #124 on: May 04, 2013, 10:13:55 am »
Thanks for the suggestions, guys!  I'll definitely play around with these ideas.
Any other thoughts towards the marquee?
« Reply #125 on: May 06, 2013, 11:14:21 am »
I own a marquee just like the one above, if you want it, I'd donate it to the cause. Other wise the standard 1 or 2 slot marquee in purple that says Nora Geo sounds just about perfect.
CWorley
« Reply #126 on: July 01, 2013, 06:44:56 pm »
Thanks for the offer Malenko, but I think I can come up with something original.
Haven't had a lot of time to work the cab lately, but here's a pic of where it's at right now:
Cheers!
CWorley
« Reply #127 on: July 31, 2013, 08:43:15 pm »
Here's a pic of the marquee light panel:
Slowly but surely...
Cheers!
« Reply #128 on: August 01, 2013, 09:01:57 am »
Glad to see you're still making progress.
CWorley
« Reply #129 on: August 02, 2013, 11:18:21 pm »
Installing the speaker shelf...
Cheers!
Unstupid
« Reply #130 on: August 03, 2013, 12:03:56 am »
Arent those speakers going to cast some shadows on your marquee?  Just curious!
CoryBee
  • Bopity Boopy
« Reply #131 on: August 03, 2013, 06:26:24 am »
I was thinking the same thing. I get shadows from the ends of 1/4" pieces of wood laying flat, that is definitely going to be a problem with the speakers.
« Reply #132 on: August 03, 2013, 09:31:05 am »
You could probably get away with moving the led panel in front of the speakers and putting sanded plexi in front of it to diffuse the light.
If you allowed for fairly thick marquee glass, you could use two pieces of half that thickness with the marquee sandwiched in between and sand the rear one.
« Reply #133 on: August 03, 2013, 09:35:39 am »
+1 Great idea! Wish this place had a rep system... ;D
CWorley
« Reply #134 on: August 03, 2013, 12:58:24 pm »
Thanks for all the comments, guys!
It won't be that hard to move the light panel in front of the the speakers.
I already have my two pieces of clear plastic for the marquee.  They're 1/8" thick.
If I left the protective paper on the back piece of plexi, would that do the trick?  Or do I have to sand it like mentioned?  And what does the thickness of the plexi have to do with it?
  • Last login:Yesterday at 09:46:51 pm
« Reply #135 on: August 03, 2013, 03:49:59 pm »
Here is another option to consider.
« Reply #136 on: August 04, 2013, 10:13:38 am »
might not cast a shadow if the LEDs were moved to the angled part above the speakers
CWorley
« Reply #137 on: August 05, 2013, 10:18:48 am »
I was thinking the same thing BadMouth.  I'll do some testing once I have the plexi, marquee retainers, and a temporary marquee.
CWorley
« Reply #138 on: May 12, 2014, 11:06:18 pm »
Back on task after life got in the way for a bit.  Currently installing the pc components into the cab (pics attached).  Hoping to finish this project up this summer.  Not in a hurry though since my daughter is still 2-3 years away from being able to use it anyway.
What's left to do:
- Finish installing pc components and test them out
- Finish any remaining wiring
- Test out marquee light placement on temporary marquee
- Order and put on side and front decals
- Install final marquee
- Finalize software
Cheers!
Re: Nora's Neo-Geo MVS Mini (5/12/14 UPDATE)
« Reply #139 on: May 13, 2014, 11:55:35 am »
Glad to see this is getting some action again. I really like this little build  :applaud:
brucelee00
  • Last login:December 13, 2020, 05:16:36 pm
« Reply #140 on: May 13, 2014, 01:24:54 pm »
Love the color on this build. Looking forward to seeing it completed :)
« Reply #141 on: May 18, 2014, 10:02:40 am »
+1 to both statements. Cant wait to see the finished project!
CWorley
« Reply #142 on: May 20, 2014, 10:10:03 am »
Thanks, guys!  I appreciate it.  Updates will probably come slow, but looking to finish by the end of August.
stigzler
    • Mago Arcade
« Reply #143 on: May 22, 2014, 02:13:50 am »
.... but looking to finish by the end of August.
Shhhhh!!!  :laugh2:
Lovely looking build. I was going to have mine finished by Xmas, 2013.. then end of January, 2014..then yesterday....
