Author Topic: JUKE 2000 - wall jukebox (DONE)  (Read 5480 times)
Jp19
  • Last login:January 17, 2016, 09:23:15 pm
« on: May 17, 2012, 07:59:05 pm »
been planning for a while and today i started my wall jukebox build.
JUKE 2000 ive decided to go with this graphic.
had a go myself and im pretty happy with it........the title (JUKE2000) will be lit up.
so i went to the local bnq and picked up some of the plexi faced picture frames 50 x 70cm i got two of these,
the idea is to use both backboards, they're quite thick, not the usual hardboard. One will be used as the back half
and the other as the front, the front will then be covered in one sheet of plexi........ the artwork will then be laid over it,
the artwork will be printed at home using inkjet self adhesive a4 labels, like i did on my marvel vs cab. And finally the last piece
of plexi on top of that like a sandwich effect, idea being the second plexi will add a glass effect to the artwork.
so went out and picked a few things up this morning:
2 picture frames
2 pc fans
pc speakers - logitech
euro chassis socket
Usb panel mount
slimline keyboard
mains 12 inch strip light
2 cans of black spray paint
multi plug extension
inkjet labels
mounting brackets
piano hinge
started building this afternoon.......added some batons to both sides of the picture frame backs, and created two halves of the juke.
Also added a piano hinge in the middle.
I then marked out a marquee hole, monitor, keypad and speaker holes and cut these with the jigsaw.
and then cut holes from the bottom panel for two pc fans, a hole for a euro power plug, and a panel usb.
finally sanded it down and tided it up, ready to be painted black tomorrow.
also today managed to hack the keyboard into a keypad, opened it up, removed matrix and push pads,
took all keys off the keyboard apart from numbers, backspace, pg up, pg dwn, and
qwerty (options buttons - vol up, play pause etc.) then trimmed it down to have a smaller surface, also decased a tft monitor
i had lying around, and decased the speakers.
« Last Edit: May 26, 2012, 09:11:28 pm by Jp19 »
Jp19
Re: JUKE 2000 - wall jukebox
« Reply #1 on: May 18, 2012, 05:29:43 pm »
UPDATE: got the inside all finished today, mounted a few supports added a couple of channels for wires and mounted the monitor case.
Also got the first coat of spray on the inside, need to do another coat in the morning and graphics tomorrow.
Jp19
« Reply #2 on: May 19, 2012, 12:30:11 am »
finished my custom keypad aswell............heres a demo of it in action and the front end  :cheers:
« Last Edit: May 19, 2012, 12:32:08 am by Jp19 »
Jp19
Re: JUKE 2000 - wall jukebox (UPDATE - custom keyboard)
« Reply #3 on: May 21, 2012, 07:50:53 pm »
so ive been busy, painted in and out, installed all the insides, got keypad mounted, monitor mounted, and also cut and mounted plexi.
about 95% finished. need print graphics and apply them and find a computer. if theres anyone following this  :dunno enjoy !
Jp19
and a short video....will make a better one when graphics are on.
you had me until the nickelback  :lol
Jp19
just waiting on a pc, other than that im pretty much finished.#
Jp19
Re: JUKE 2000 - wall jukebox (UPDATE - graphics)
« Reply #7 on: May 26, 2012, 09:10:59 pm »
Finished  :P
  • Last login:January 10, 2026, 01:53:23 pm
Re: JUKE 2000 - wall jukebox (DONE)
« Reply #8 on: May 26, 2012, 09:51:30 pm »
Cool!
Good job.
And you cant beat Elvis!!
 :applaud: :applaud:
