Author Topic: LED newbie question....  (Read 2564 times)
gonzojoey
  • Last login:August 30, 2020, 10:26:44 am
« on: May 12, 2012, 12:33:35 am »
I haven't really worked with LED's yet, so I have a simple question that I'm hoping someone can help me with...
I have an older "Poker" style arcade machine that has lighted buttons, but they currently have #161 miniature bulbs with the wedge base in them. I'd like to install an LED-Wiz from GGG to control the lights, but Randy over at GGG suggested that I replace the bulbs w/ LEDs (which I agree would be best), but I'm not 100% sure what to replace them with. Is this what I'm looking for?: http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fmini-wedge.html
But they have "Polarized" and "Non-Polarized" versions and some are "SMD" and others not. I'm not looking for color changing or anything fancy, just something that will light the buttons using the current housings I have and that is compatible w/ the LED-Wiz. Any suggestions?
Thanks in advance!
-JG
darthpaul
  • Last login:February 22, 2026, 10:22:50 am
  • Join, It's your duty
Re: LED newbie question....
« Reply #1 on: May 12, 2012, 01:00:02 am »
The Superbrights are 12v, LEDwiz is 5v, non-polorized means you don't have to worry which way you put the bulb in the socket, it will work either way.
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
  • Last login:Today at 09:15:18 am
« Reply #2 on: May 12, 2012, 01:30:14 am »
"SMD" = Surface Mount Device (no holes/leads going through the board)
#161 and #555 bulbs use the same base, but the #555s are 6.3V instead of 14V.
These three might give you a good starting point:
http://www.paradisearcadeshop.com/en/pinball-leds/121-tropical-spotlight-63vac-led-555-replacement.html
http://www.paradisearcadeshop.com/en/pinball-leds/85-555-led-replacements.html
http://www.twistedquarter.com/index.php?main_page=product_info&cPath=8&products_id=1253
gonzojoey
« Reply #3 on: May 12, 2012, 02:27:48 am »
Thanks guys! I appreciate the help and lesson on LEDs :)
I'll be purchasing the ones from paradise arcade shop.
  • Last login:Yesterday at 08:36:11 pm
    • GroovyGameGear.com
« Reply #4 on: May 14, 2012, 01:28:02 pm »
The LED-Wiz will work with 12v LEDs as well, if configured properly.   Polarized or non-polarized isn't a big deal.  If it doesn't work in one orientation, just flip it around.  No damage will result if it goes in backwards, it just won't work that way.
armi0024
  • Last login:January 12, 2023, 09:57:36 pm
« Reply #5 on: May 14, 2012, 03:34:44 pm »
