Author Topic: Can Mala Hotkeys be setup to close an emu with ANY two keys? [SOLVED]  (Read 3999 times)
Wade007
  • Last login:April 06, 2017, 01:33:35 pm
  • A MAME cabinet at home is heaven
    • bit.ly/1cWnoIC
    • Cheapskategamer.com
I'm using Hotkeys to close Sega Model 2 in Mala by pressing one button. Works fine but I'd like to use a two key combination that DOES NOT include Shift, Alt, or Ctrl.
Is that possible? How?
I'd like to map it to the 2 + 4 keys simultaneously. Can that be done in Hotkeys?
« Last Edit: May 12, 2012, 11:03:15 pm by Wade007 »
My Super Arcade cabinet project:
Software blog article: http://bit.ly/1cWnoIC
Hardware blog article: http://bit.ly/1dWxjvP
YouTube video: http://bit.ly/1N818Xm
Super Arcade Cabinet Progress thread (Now Complete):
http://forum.arcadecontrols.com/index.php/topic,123292.0.html
Frontend Video Intro: http://bit.ly/1P9HPDN
TopJimmyCooks
Re: Can Mala Hotkeys be setup to close an emu with ANY two keys?
« Reply #1 on: May 11, 2012, 02:14:40 pm »
Can't via Mala but you could with AutoHotKey.
empardopo
  • Last login:September 28, 2025, 07:08:15 am
    • My personal forum
« Reply #2 on: May 12, 2012, 09:00:07 am »
Again, I think you could take a look to AllInOne.
Greetings!
Wade007
    • bit.ly/1cWnoIC
« Reply #3 on: May 12, 2012, 12:18:19 pm »
OK. Thanks for your responses.
Empardoro, how do I launch AllinOne within Mala? Via a BAT file? Is there another way?
En español: ¿Como puedo lanzar to programa "AllInOne" en Mala? No entiendo muy bien como se hace. ¿Atravez de una .Bat programa? ¿Hay una otra manera?
« Last Edit: May 12, 2012, 09:26:48 pm by Wade007 »
Wade007
    • bit.ly/1cWnoIC
« Reply #4 on: May 12, 2012, 11:02:41 pm »
I'm now confident, having figured out how to use both AllInOne and AutoHotkeys, that either one of these programs can be used to set up a two-key-combo-quit-emulator function as described in my initial post.
For example, see my last post here describing how I got AllInOne to work with Daphne:
http://forum.arcadecontrols.com/index.php?topic=120183.0
I used AutoHotKeys for Demul with success as well.
I used Mala Hot Keys to quit Sega Model 2.
If you want to remap a single key to the quit emulator function and the emulator itself doesn't allow a remap (best option if possible), then HotKeys within Mala will do it just fine. Mala Hotkeys will also map a two-key Close (Quit emulator) function as long as one of those two keys is Shift, Alt, or Ctrl.
Mala Hot Keys set up for this is as follows:
Type: Post
Source: (1st chosen key)
Destination: ESC (if the Escape key is your emulator's quit function)
Then just check "Shift", "Alt", and/or "Ctrl" to create the 2+ button combo to quit the emulator. Again, this works great as long as you are OK with using Shift, Alt and/or Ctrl as the 2nd or more combo button. In my case I didn't want to use any of those keystrokes as the second part of the combo. Enter Auto Hot Key or AllInOne.
