Author Topic: Add resolution for calamity drivers  (Read 4838 times)
White_widow57
  • Last login:June 20, 2012, 09:52:33 am
« on: May 10, 2012, 08:56:37 am »
Hi, i use calamity drivers with my radeon hd (120 resolutions added) but i don't have the 640x288 for my frontend (maximus arcade). How can i add this resolution with vmmaker? Thanks
mazinger-z
  • Last login:January 03, 2016, 12:50:47 pm
Re: Add resolution for calamity drivers
« Reply #1 on: May 10, 2012, 11:08:26 am »
Yes, you can. Just add it in ResList.txt and launch VMMaker again.
White_widow57
« Reply #2 on: May 10, 2012, 12:32:45 pm »
Ok i've juste have to add a line like that:
640 x 288 @ ??
What refresh rate must i use? (50.000000, 60.000000, 30.000000 ...)
  • Last login:Today at 02:55:00 am
« Reply #3 on: May 10, 2012, 12:51:30 pm »
Yes, that's how it works. Just enter 60.000000 for the refresh, the modeline generator will limit the refresh to the maximum for your monitor specs, probably it'll be around 52 Hz or so.
steveggz
  • Last login:July 04, 2012, 09:41:28 pm
« Reply #4 on: May 10, 2012, 02:04:27 pm »
Do you have to re-run VMMaker after adding a custom resolution to ResList.txt ?
« Reply #5 on: May 10, 2012, 02:12:23 pm »
White_widow57
« Reply #6 on: May 10, 2012, 04:14:12 pm »
Perfect for Maximus arcade, thanks a lot!
