Author Topic: maximus arcade - is it any good?  (Read 3362 times)
Los Abrazos Rotos
« on: May 04, 2012, 02:45:04 pm »
Just wondering - I'm using hyperspin at the moment but for some reason we dont get on  :badmood:
GregD
  • Last login:December 23, 2025, 04:38:08 pm
    • Arcade Nebula
Re: maximus arcade - is it any good?
« Reply #1 on: May 04, 2012, 03:29:21 pm »
Maximus is very good.  I don't believe that it is still being developed and you have to pay for it but other than that it works just fine.  It is really easy to setup if you want to compare it to Hyperspin.
Los Abrazos Rotos
« Reply #2 on: May 04, 2012, 03:52:39 pm »
Mm ok, thanks..  I dont know what it is with hyperspin, I always seem to have trouble with it.
Cynicaster
« Reply #3 on: May 04, 2012, 03:59:05 pm »
What does Maximus bring to the table over and above MaLa?  I use the latter and I'm happy with it, my only gripe is the background music feature doesn't work.
Mark Thomas
  • Last login:August 16, 2014, 07:41:56 am
« Reply #4 on: May 04, 2012, 04:06:41 pm »
What issues are you having buddy?
Los Abrazos Rotos
« Reply #5 on: May 04, 2012, 04:13:13 pm »
I dont like the menu systems very much,  It should be perfect but I always seem to get frustrated with it..  I probably need to read the instructions a bit
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #6 on: May 04, 2012, 04:24:18 pm »
I'm tinkering with Hyperspin at the moment for a bartop for a coworker.  I really enjoy it.  It does take some getting used to the hyperhq, but once you figure that out it's easy peezy!
« Reply #7 on: May 04, 2012, 04:38:35 pm »
Nothing.  It doesn't really have many options.
It's biggest feature is that it's easy for newbs.
Good choice for people who want a front-end without putting much work into it.
Bad choice for people who want something unique.
Los Abrazos Rotos
« Reply #8 on: May 04, 2012, 04:42:11 pm »
Might have to turn some settings down, theres just too much going on.. I think I prefer something a little more functional, less glossy
Mark Thomas
« Reply #9 on: May 04, 2012, 04:58:08 pm »
Iv always found Mamewah to be a pretty decent front end and you can customise it to your liking. If you want video previews you can add them or just have a list of games, create custom lists etc. why not try a few different front ends and see which suits you needs best.
  • Last login:Today at 06:24:33 pm
« Reply #10 on: May 04, 2012, 05:58:05 pm »
If you're looking for a functional yet simple graphic interface, you might want to look at MAMEUIFX.
http://mame32fx.altervista.org/home.htm
I've been using it for the last year and a half.
It is easy to configure and uses the same standard files used by many front ends for game descriptions, screencaps, marquees, cab pics, cp pics, etc.
« Last Edit: May 04, 2012, 06:00:40 pm by PL1 »
Los Abrazos Rotos
« Reply #11 on: May 04, 2012, 06:20:08 pm »
Thanks, I'll check that out
nick3092
  • Last login:March 22, 2022, 03:57:28 pm
« Reply #12 on: May 04, 2012, 07:21:59 pm »
+1 for MaLa. But I fear it is no longer being developed. Loadman has not posted anything for quite some time, and only appears to log on once every 2 - 3 months.
eds1275
  • Rock and Roll!
« Reply #13 on: May 04, 2012, 07:42:06 pm »
AHA I'm not the only one with background music issues. I didn't know it was a known issue. I'll stop trying to figure out what I did wrong then.
gamepimp
« Reply #14 on: May 04, 2012, 08:27:07 pm »
I would avoid Maximus. It would b an awesome program if the developer was still working on it to fix the bugs and add more functions. But since he's not, u end up paying for a buggy program that will never get any better. Plus, I hear that some ppl who buy it never get the registration code sent to them. And I understand u cant get ahold of the developer very easily to get it. I got tired of dealing with the bugs and switched to GameEx. Takes a little more time to setup and figure out, but it's a very versatile front end that has awesome support.
Los Abrazos Rotos
« Reply #15 on: May 05, 2012, 03:05:02 am »
I've heard good things about gamex, thanks for the tip
Los Abrazos Rotos
« Reply #16 on: May 05, 2012, 03:33:03 am »
OK, totally sold on Gamex, its great - exactly what I was looking for  :applaud:
gamepimp
« Reply #17 on: May 06, 2012, 07:26:08 pm »
It really is a top notch frontend. Tom (the programmer) will practically bend over backwards to fix bugs. And there are some great guys who will help answer any questions users might have over at the GameEx forums. So make sure u head over there if u get stuck!
Los Abrazos Rotos
« Reply #18 on: May 07, 2012, 02:59:57 am »
GameEx is absolutely incredible, thanks so much for the heads up.  :applaud:
