Author Topic: install a 4-pin annode RGB to a button??  (Read 1419 times)
gstav
  • Last login:December 19, 2025, 05:53:11 am
    • forum.arcadecontrols.com/index.php/topic,157861.0.html
« on: March 24, 2012, 11:53:25 am »
Hi!
I have the Seimitsu PS-14-KN and bout some annode 4 pins RGB leds to light them up!
I've seen guides of installing pre-made RGB boards sutch as UILA and ARCEYE, but is there any instructions made
for my type of install?
Any smart way of doing this? Guess I have to drill a hole in the base somewere..  ::)
Cheers! :cheers:
"One coin to rule em' all"
BobA
  • What Me Worry?
Re: install a 4-pin annode RGB to a button??
« Reply #1 on: March 24, 2012, 04:08:59 pm »
You can bend the pins of your LED out so you can install it the same way as the UILA board.   Holes will have to be in the same place and you would have to solder wires to all the pins (4).
gstav
« Last Edit: March 25, 2012, 09:05:04 am by gstav »
BobA
  • What Me Worry?
« Reply #3 on: March 25, 2012, 09:34:26 am »
No real way to tell until you get your LEDs and try them.  :dunno
gstav
« Reply #4 on: March 25, 2012, 11:13:29 am »
*lol* true! :burgerking:
