December 15, 2025, 06:52:18 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Audio/Jukebox/MP3 Forum
Car Speaker & small amp problems
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Car Speaker & small amp problems (Read 3990 times)
EvilGreenDevil
Trade Count:
0
Full Member
Offline
Last login:June 10, 2016, 01:50:45 pm
on:
March 22, 2012, 07:46:54 am »
Building my first cabinet and ran into a little bit of a disappointment when my audio orders arrived yesterday and I couldn't get things working. I was hoping someone could help. Building a bartop cabinet that will use 4" speakers as most do. I found a link to a cheap "mini/motorcycle" amp through researching other threads that is suppose to run on 12V. I'm thinking that wiring a molex connector from my 450w PC power supply should be enough to power it.
I did the wiring for the power and connected it to the amp, success (at least I thought so given the red power light on the amp went on). I used the 12V line from an extra molex connector and the ground wire next to it. The 12V/ground were then spliced to the corresponding ones to the amp harness.
I went on to connect the +/- terminals to the corresponding wires that came with the amp by a simple connection of the wires and wrapping each one in electrical tape. When I pugged in the speakers i'm getting a faint/dirty hum and no sound from the pc is recognized. I know I'm doing something wrong.
The amp is connected to the audio jack (I've tried front and back) to the PC using a 3.5mm --> RCA split
Speakers:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=269-178
Amp:
http://www.aliexpress.com/product-fm/369889204--New-Red-MP3-Stereo-Amp-Motorcycle-Amplifier--Made-in-China-Cheap-Accept-Paypal-wholesalers.html
Back of amp
Any help would be appreciated
Logged
Xbox360 GT - EvilGreenDevil | twitter - dcmyers
My First Bartop Build
EvilGreenDevil
Trade Count:
0
Full Member
Offline
Re: Car Speaker & small amp problems
Reply #1 on:
March 22, 2012, 12:48:08 pm »
It was and right after posting my question I went back to the cabinet to check the audio card settings in windows. I think I had an audio setting checked that I didn't new for stereo/analogue audio.
I get sound now but I'm still getting a minor hum whenever sound isn't being played. I'm assuming it's a grounding issue.
Logged
Drnick
Trade Count:
+2
Full Member
Offline
Last login:June 21, 2024, 03:32:31 pm
Plodding Through Life
Reply #2 on:
March 22, 2012, 05:28:11 pm »
Indeed it is a grounding issue. I have the exact same amp. You could either try a grounding loop or you could use a separate power supply. I used a 14V 3a or something very close to and that works OK. Ultimately I decided against using it in the Kiosk I was converting and went for a set of Logitech x530's instead. I am now using the amp to run a small sub I had kicking around from an old 5.1 dvd setup.
Logged
Bartop
http://forum.arcadecontrols.com/index.php/topic,121269.0.html
Jukebox
http://forum.arcadecontrols.com/index.php/topic,118409.0.html
Garden
http://forum.arcadecontrols.com/index.php/topic,157271.0.html
Entertainment Ctr
http://forum.arcadecontrols.com/index.php/topic,160984.0.html
NeoGeo
http://forum.arcadecontrols.com/index.php/topic,157547
Its 10 Years now and still no damned redundancy
EvilGreenDevil
Trade Count:
0
Full Member
Offline
Reply #3 on:
March 22, 2012, 06:39:42 pm »
Not sure I'm going that big, mine is a small bar top so I will just be using the car speakers, no sub.
What at your suggestions for a ground loop and where to attach it in the cab if I'm gonna stick with the pc psu?
Logged
Drnick
Trade Count:
+2
Full Member
Offline
Reply #4 on:
March 23, 2012, 04:20:17 am »
Do a search for Ground Loop Isolator and see what comes up, you should be able to find something fairly cheaply. I can't really advise on the best one as I just used a separate adadpter to power the amp in the end.
Logged
Bartop
Jukebox
Garden
Entertainment Ctr
NeoGeo
matsadona
Trade Count:
0
Full Member
Offline
Last login:October 28, 2023, 06:00:12 am
Reply #5 on:
March 23, 2012, 06:14:00 am »
Drnick is right. This is a common problem, which I share using my laptop for DJ’ing. You need an isolator and they are pretty cheap.
Here is one found at Radio Shack, which I assume you would find close to were you live.
http://www.radioshack.com/product/index.jsp?productId=2062214
Logged
Building, collecting and playing arcade machines
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
