Author Topic: U360 will not load maps with Ledblinky  (Read 3116 times)
bbee383
  • Last login:October 26, 2015, 06:29:59 pm
« on: March 21, 2012, 09:42:20 pm »
I am having an issue with my u360 joysticks with ledblinky and Hyperspin.
I am pretty sure I am missing something in my configuration.
The joysticks work good but when you enter a game through Hyperspin/ledblinky it will not load the maps (IE 4 way, 8 way)
I have joystick_map 7778...4445 set in the mame.ini file
Ledblinky is checked for the U360.
Here is a debug from Ledblinky
[03/21/2012 20:42:43] LEDBlinky v5.0.0.4
[03/21/2012 20:42:43] Detected LED Devices: 000000001000000000000000
[03/21/2012 20:42:43] LEDBlinkyControls.xml: v1.0 01/16/2009 15:38:09
[03/21/2012 20:42:43] 5 mame games loaded from LEDBlinkyControls.xml
[03/21/2012 20:42:43] 1 emulator games loaded from LEDBlinkyControls.xml
[03/21/2012 20:42:51] Game Start Key (P1): 13
[03/21/2012 20:42:51] Game Start Key (P2): 69
[03/21/2012 20:42:51] Loaded LWAX File for FE Start: [Pattern26.lwax]. Single loop only.
[03/21/2012 20:42:57] Emulator: [MAME]
[03/21/2012 20:42:57] Controls.dat INI file Version=0.141.1, Time=2011-01-05 18:17:26, Generated by=SirPoonga
[03/21/2012 20:42:57] 1056 games loaded from controls.ini
[03/21/2012 20:42:57] 6851 games loaded from Mame.xml
[03/21/2012 20:42:57] 0 clones loaded from Mame.xml
[03/21/2012 20:42:57] 1389 games loaded from Colors.ini
[03/21/2012 20:43:14] ROM/Game: [DKONG] Controls: [MAME-DKONG]
[03/21/2012 20:43:14] Control List for DKONG: |P1_BUTTON1|P1_JOYSTICK_LEFT|P1_JOYSTICK_DOWN|P1_JOYSTICK_UP|P1_JOYSTICK_RIGHT|START1|COIN1|START2|COIN2|CONTROL_JOY4WAY
[03/21/2012 20:43:14] Control Speech List for DKONG: |JUMP|RUN LEFT|CLIMB DOWN LADDER|CLIMB UP LADDER|RUN RIGHT|||||4-way Joystick
[03/21/2012 20:43:14] P1_BUTTON1 (MAME-ALLGAMES): |KEYCODE_E
[03/21/2012 20:43:14] P1_JOYSTICK_LEFT (MAME-ALLGAMES): |JOYCODE_1_XAXIS_LEFT_SWITCH
[03/21/2012 20:43:14] P1_JOYSTICK_DOWN (MAME-ALLGAMES): |JOYCODE_1_YAXIS_DOWN_SWITCH
[03/21/2012 20:43:14] P1_JOYSTICK_UP (MAME-ALLGAMES): |JOYCODE_1_YAXIS_UP_SWITCH
[03/21/2012 20:43:14] P1_JOYSTICK_RIGHT (MAME-ALLGAMES): |JOYCODE_1_XAXIS_RIGHT_SWITCH
[03/21/2012 20:43:14] START1 (MAME-DEFAULT): |KEYCODE_1|JOYCODE_1_START
[03/21/2012 20:43:14] COIN1 (MAME-DEFAULT): |KEYCODE_5|JOYCODE_1_SELECT
[03/21/2012 20:43:14] START2 (MAME-DEFAULT): |KEYCODE_2|JOYCODE_2_START
[03/21/2012 20:43:14] COIN2 (MAME-DEFAULT): |KEYCODE_6|JOYCODE_2_SELECT
[03/21/2012 20:43:14] CONTROL_JOY4WAY (MAME-DEFAULT): JOY4WAY
[03/21/2012 20:43:46] Loaded LWAX File for FE Quit: [3backsweep.lwax]. Single loop only.
Any help would be appreciated....
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
Re: U360 will not load maps with Ledblinky
« Reply #1 on: March 22, 2012, 08:59:10 am »
Try this - Enable the "Verbose Logging" option, then run your FE and launch a game.
Search the log for "UltraStik". You should see entries like this:
[03/07/2011 22:55:37] Game Start Key (P1): 32
[03/07/2011 22:55:37] Game Start Key (P2): 17
[03/07/2011 22:55:37] UltraStik U360(s) detected: 1   Restrictor Type: Round
[03/07/2010 22:55:55] Set UltraStik JDR Map [vjoy2way.um] for DEFENDER.
If you're seeing that, then LEDBlinky is configured correctly and is attempting to remap the u360s.
Next, use the Ultramap utility to confirm that the u360s are running firmware 2.3 or newer. If not, upgrade the firmware.
http://www.dndw.com/ledblinky/Support.htm#U360Problem
You can also use the Ultramap utility to make sure the sticks can be remapped and are working as expected.
Robots will kill you.
Arcade Addiction
bbee383
« Reply #2 on: March 22, 2012, 09:44:39 am »
Both u360's are at version 2.5 and work with the ultramap utility.
I will enable the verbose logging when I get home from work.
That's for the help!
arzoo
    • LEDBlinky
« Reply #3 on: March 22, 2012, 10:58:39 am »
Another thing you can try is to start up the Windows Game Controller app (before running your FE), then while the FE is active, alt-tab over to the controller app and see if the joysticks are in 4-way mode. This would help confirm (or not) that LEDBlinky is setting the map correctly. You can also alt-tab out of MAME and see if the sticks are set to the expected map for the selected game.
Arcade Addiction
bbee383
« Reply #4 on: March 22, 2012, 05:29:36 pm »
[03/22/2012 17:18:07] [JDR]
[03/22/2012 17:18:07] UseGPWiz49=0
[03/22/2012 17:18:07] UseUltraStik=1
[03/22/2012 17:18:07] UltraStikRestrictorType=9
[03/22/2012 17:18:07] [OtherSettings]
[03/22/2012 17:18:15] UltraStik U360(s) detected: 2   Restrictor Type: 4way/8way/Circular
[03/22/2012 17:18:15] Set UltraStik JDR Map [joy4way.um] for FE.
[03/22/2012 17:18:15] Loaded LWAX File for FE Start: [Pattern51.lwax]. Single loop only.
[03/22/2012 17:18:15] Received Event - Queue:[1] Msg:[7~MAME].
Looks like it loads in the front end...checked with Windows Game Controller app and joystick is not in 4-way
Event: FEGameStart
[03/22/2012 17:19:06] Using Default Mame Outputs: LED0=Start1~LED1=Start2
[03/22/2012 17:19:06] ROM/Game: [DEFENDER] Controls: [MAME-DEFENDER]
[03/22/2012 17:19:06] Control List for DEFENDER: |P1_BUTTON1|P1_BUTTON2|P1_BUTTON3|P1_BUTTON4|P1_BUTTON5|P1_JOYSTICK_DOWN|P1_JOYSTICK_UP|START1|COIN1|START2|COIN2|CONTROL_VJOY2WAY
[03/22/2012 17:19:06] Control Speech List for DEFENDER: |FIRE|THRUST|SMART BOMB|HYPERSPACE|REVERSE|DOWN|UP|||||2-way Joystick (Vertical)
[03/22/2012 17:19:06] P1_BUTTON1 (MAME-ALLGAMES): |KEYCODE_E
[03/22/2012 17:19:06] P1_BUTTON2 (MAME-ALLGAMES): |KEYCODE_R
[03/22/2012 17:19:06] P1_BUTTON3 (MAME-ALLGAMES): |KEYCODE_SPACE
[03/22/2012 17:19:07] P1_BUTTON4 (MAME-ALLGAMES): |KEYCODE_T
[03/22/2012 17:19:07] P1_BUTTON5 (MAME-ALLGAMES): |KEYCODE_Z
[03/22/2012 17:19:07] P1_JOYSTICK_DOWN (MAME-ALLGAMES): |JOYCODE_1_YAXIS_DOWN_SWITCH
[03/22/2012 17:19:07] P1_JOYSTICK_UP (MAME-ALLGAMES): |JOYCODE_1_YAXIS_UP_SWITCH
[03/22/2012 17:19:07] START1 (MAME-DEFAULT): |KEYCODE_1|JOYCODE_1_START
[03/22/2012 17:19:07] COIN1 (MAME-DEFAULT): |KEYCODE_5|JOYCODE_1_SELECT
[03/22/2012 17:19:07] START2 (MAME-DEFAULT): |KEYCODE_2|JOYCODE_2_START
[03/22/2012 17:19:07] COIN2 (MAME-DEFAULT): |KEYCODE_6|JOYCODE_2_SELECT
[03/22/2012 17:19:07] CONTROL_VJOY2WAY (MAME-DEFAULT): VJOY2WAY
[03/22/2012 17:19:07] Device 9; PBA:48,48,48,48,48,48,0,48,0,48,48,48,48,48,48,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,48,0,0,0,0,0,0,0,0,0,0,0,0,0,0,48,0,0,0,0,0,48
[03/22/2012 17:19:07] Device 9; SBA:191,126,0,0,0,4,0,130,3
[03/22/2012 17:19:07] Speak [Defender ]
[03/22/2012 17:19:08] Speak [FIRE]
[03/22/2012 17:19:09] Device 9; SBA:191,126,0,0,0,4,0,130,3
[03/22/2012 17:19:09] Speak [THRUST]
[03/22/2012 17:19:10] Device 9; SBA:191,126,0,0,0,4,0,130,3
[03/22/2012 17:19:10] Speak [SMART BOMB]
[03/22/2012 17:19:11] Device 9; SBA:191,126,0,0,0,4,0,130,3
[03/22/2012 17:19:11] Speak [HYPERSPACE]
[03/22/2012 17:19:13] Device 9; SBA:191,126,0,0,0,4,0,130,3
[03/22/2012 17:19:13] Speak [REVERSE]
[03/22/2012 17:19:14] Device 9; SBA:191,126,0,0,0,4,0,130,3
[03/22/2012 17:19:14] Device 9; PBA:48,48,48,48,48,48,0,48,0,48,48,48,48,48,48,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,48,0,0,0,0,0,0,0,0,0,0,0,0,0,0,48,0,0,0,0,0,48
[03/22/2012 17:19:14] Speak [Primary Control]
[03/22/2012 17:19:15] Speak [2-way Joystick (Vertical)]
[03/22/2012 17:19:18] 1 MAME Output messages queued up.
[03/22/2012 17:19:18] Set UltraStik JDR Map [vjoy2way.um] for DEFENDER.
Does not work in mame ether
arzoo
    • LEDBlinky
« Reply #5 on: March 23, 2012, 08:37:23 am »
Try setting the restrictor type to None.
Arcade Addiction
bbee383
« Reply #6 on: March 23, 2012, 05:20:58 pm »
Ok.. Tried that and it didn't help.
The part that is confusing me is when I alt tab out set the joystick with the ultistick software it works fine.
When I go back to hyperspin it resets it to analog with no mapping.  :banghead:
Thanks for the help so far!
arzoo
    • LEDBlinky
« Reply #7 on: March 23, 2012, 06:56:08 pm »
Ok, here's some more things to try:
I assume the map (.um) files in your ...\LEDBlinky\jdr\UltraStik folder are the ones that installed with LEDBlinky. These can be checked by copying them into the ...\program files\ultramap\maps folder and test with the Ultramap app.
If the map files are working, next we need to isolate HS and LEDBlinky.
Use Ultramap to set a 4-way map. Then disable LEDBlinky in the HS config (so LEDBlinky won't run with HS). Run HS and alt-tab out to Ultramap or Windows Game Controllers dialog to check if the sticks are still in 4-way mode. If they are, then we know HS is not causing the problem.
Next try LEDBlinky without HS; set the sticks to 8-way, then launch LEDBlinky from a Run or Cmd window with this command:
...\LEDBlinky\ledblinky.exe 1
You should see the LEDBlinky icon in the system tray. Wait about 10 seconds, then right-click the icon and select Exit to quit the app. Use Ultramap or the Windows Game Controllers dialog to check the sticks - they should be in 4-way mode which is the default that LEDBlinky uses when the FE is expected to be active. You can also check the debug.log for this:
[03/23/2012 18:44:42] Set UltraStik JDR Map [joy4way.um] for FE.
If the log shows the sticks set to 4-way but they remained in 8-way (or switched to analog), then something with the ultrastik.dll is not working.
Post the results back here (or PM or email).
Also, what version of Windows are you running?
Arcade Addiction
bbee383
« Reply #8 on: March 23, 2012, 07:40:01 pm »
Ok here are the results
Map files are working correctly.
Works in Hyperspin with ledblinky disabled
Ran Ledblinky from command line with set to 8way...lost the mapping (switched to analog) and it is loading according to the logs.
bbee383
« Reply #9 on: March 23, 2012, 08:09:11 pm »
Win 7 64bit
arzoo
    • LEDBlinky
« Reply #10 on: March 23, 2012, 08:19:47 pm »
So that pretty much narrows the problem down to the ultrastik.dll - so lets test that without LEDBlinky.
Download this U360 Test app and put it into your LEDBlinky folder. Use it to set a few maps (4-way, 8-way, etc) and confirm if the sticks are actually mapped (using the same methods as before).
The app will generate a log file (UltraStikTest.log) if there are any detected errors.
If it doesn't work, try running the test app in Win 32 compatibility mode.
« Last Edit: March 23, 2012, 08:25:38 pm by arzoo »
Arcade Addiction
bbee383
« Reply #11 on: March 23, 2012, 08:50:46 pm »
It runs, but doesn't generate log file
arzoo
    • LEDBlinky
« Reply #12 on: March 23, 2012, 08:59:19 pm »
So it detects your u360's - does it set the maps correctly? Did you try the compatibility mode? The log file would only be generated if it detects a problem.
« Last Edit: March 23, 2012, 09:01:25 pm by arzoo »
Arcade Addiction
bbee383
« Reply #13 on: March 23, 2012, 09:05:14 pm »
Yes it set the maps and didn't send a log.
I did this in reg and win 32
arzoo
    • LEDBlinky
« Reply #14 on: March 23, 2012, 09:10:37 pm »
Please email me your debug.zip file.
Arcade Addiction
