Author Topic: Controls controls controls...Noob learning  (Read 10811 times)
rCadeGaming
  • Just call me Rob!
Re: Controls controls controls...Noob learning
« Reply #40 on: March 15, 2012, 04:26:01 pm »
Translucent is different than those clear ones.
Sorry, didn't realize that.  If you want something really customized to your exact idea, I think there are people who make one-off custom ball tops on Shoryuken.
For lighting the sticks, I found some pre-drilled stick shafts for sale, so you wouldn't have to worry about that:
http://www.focusattack.com/short-sanwa-jlf-stainless-steel-hollow-joystick-shaft/
That fits a JLF.  It's the same dimensions as the stock shaft, but they call it the "short" shaft because they also sell a longer one.  They also have short and long hollow shafts for the Seimitsu LS-32.
Trip
  • Last login:January 03, 2020, 01:37:04 pm
« Reply #41 on: March 15, 2012, 09:36:25 pm »
This could work out, paradise sells the joysticks you recommend and hollow short shafts for them.  I wondered what the difference was between the long and short and thanks for the tip that the short are the regular versions.  They don't have balltops I like, really dislike the bubbly ones...  Will have to see if I can find the custom ones on shoryuken.
http://www.paradisearcadeshop.com/en/paradise-arcade-custom-parts/422-sanwa-jlf-stainless-steel-hollow-joystick-shaft.html
Now I need to find some buttons.  I may just get some IL clear ones from paradise with RGB and maybe get some clear balltops instead of going translucent.  What do you think of IL buttons paradise sells?
http://www.paradisearcadeshop.com/en/59-il-translucent-buttons
« Last Edit: March 15, 2012, 09:38:36 pm by Trip »
Trip
« Reply #42 on: April 05, 2012, 07:11:13 pm »
Yey, got a bunch of EI2's and Sanwa JLFs!
