Author Topic: Installing MAME updates with patch.exe? newbie question  (Read 2858 times)
1500points
    • How to succeed at Robotron
« on: March 07, 2012, 08:36:59 am »
Hello,
I have spent some time researching on google and experimenting on my own, but can't figure it out.
So I am seeking some assistance. thanks in advance.
Have MAME 145 from mamedev. need to apply the 3 updates ( http://mamedev.org/updates.html )
--Exactly which folder, by name, do I place the 3 diff files in my MAME folder structure?
--exactly which folder should I navigate to for running the patch command from (from DOS)
--What do I do once the patch.exe window appears with a blinking cursor and blank screen.
Thank you.
1500points
Re: Installing MAME updates with patch.exe? newbie question
« Reply #2 on: March 07, 2012, 12:17:55 pm »
Thank you, the visuals are a big help but I am still stuck.
At the section labeled "Apply the "u" Update DIFFs."
I have everything installed prior to this installed as suggested including editing the batch files for the bin path.
PROBLEM- When I go to the command prompt and run "patchmame 0145u1"  it opens the patch.exe program to a blank black window and just sits.
I'm using Windows 7 64-bit.
any ideas how to get it to start patching file as the instructions explain?
1500points
« Reply #3 on: March 07, 2012, 12:25:12 pm »
figured it out it was the silly Elevated command prompt issue. had to run command prompt  by right click and run as administrator. ahem.  thanks again! very cool.
