Author Topic: Build an OND designed cab 'Metropolis'  (Read 634167 times)
0 Members and 10 Guests are viewing this topic.
stigzler
    • Mago Arcade
Re: Build an OND designed cab 'Metropolis'
« Reply #480 on: April 24, 2016, 02:32:24 am »
Not sure which plans you're using so can't quite visualise your issue. However, when cutting mine, I used the following (with vert and hori measurements):
More here:
https://sites.google.com/site/alienarcade74/sub-projects/cabinet-design
« Last Edit: April 24, 2016, 02:36:45 am by stigzler »
billgatesmate
  • Last login:May 21, 2016, 10:29:57 pm
« Reply #481 on: April 24, 2016, 02:48:16 am »
Legend, that's exactly what I was looking for. Thank you
YoshiFtJ
  • Last login:June 05, 2016, 01:25:06 pm
« Reply #482 on: June 04, 2016, 07:40:24 pm »
Alright guys, I have been looking through these forums and other places for awhile now and think I will go with this build, as it looks rather nice and seems relatively simple to do.
If I were to go with the plans posted on the first post, would I have the correct dimensions for a complete cabinet? I have looked through these pages and saw that stigzler seemed to have success. Other than the monitor position, did you have any trouble?
The only modification that I see myself making is having 8 buttons per player rather than the 6, otherwise this should be exactly what I am looking to build.
vaderag
  • Last login:May 07, 2025, 11:33:07 am
  • Building my own cab :)
« Reply #483 on: June 05, 2016, 01:55:18 pm »
You should be fine. I'm building now, you can find my metric diagrams above. Seem to be working so far!!
stigzler
    • Mago Arcade
« Reply #484 on: June 05, 2016, 03:09:35 pm »
You'll be golden. Don't worry about 8 buttons either. I managed to fit in two sets of joystick and 8 buttons with a trackball in between within reduced dimensions (with the bolt on cp removed - essentially between the two side panels)
Old pic, but it'll give you the idea:
kmccb23
  • Last login:April 13, 2022, 06:04:55 am
« Reply #485 on: June 29, 2016, 10:35:23 am »
Has anyone compiled a parts list for this build?
I want to get all the lumber that is needed in one stop.. I see 1/2" MDF 4x4 and then two sheets of 3/4" 4x8 in the design.. But then later in the PDF it shows a 1/2" base that wasn't included in the first drawings..
vaderag
« Reply #486 on: June 29, 2016, 04:37:22 pm »
3 4x8 in the relevant sizes is enough for everything except the back opening panel (tho if you cut it right you might be okay)
kmccb23
« Reply #487 on: July 02, 2016, 09:40:52 pm »
I got the wood and started drawing my measurements on the board.. I'm stumped on how to do the degree/angle measurements.. If there were more measurements given where the angles are, I can simple draw a line to meet two points.. But the PDF I have does not have them..
I've attached an example.. The 15*.. I know the angle starts at 38 3/8" high (shown by red line in attachment).. If I knew the measurement of the other line shown I could simple connect the two points.. So I'm stuck..
How do I figure out these since there are no measurements to connect the points? There are numerous angle cuts that I need to draw but can't..
stigzler
    • Mago Arcade
« Reply #488 on: July 03, 2016, 04:51:59 am »
Similar issue to this guy's post a few posts above?
http://forum.arcadecontrols.com/index.php/topic,118612.msg1572881.html#msg1572881
He seemed to get it solved.
kmccb23
« Reply #489 on: July 03, 2016, 09:04:06 am »
Thanks for the reply.. I did see that after I posted, however, the drawing you posted that helped him out seems to be a modified plan of what the OP originally posted..
Was hoping to use the OPs plans..
vaderag
« Reply #490 on: July 03, 2016, 09:31:53 am »
If you look through the thread I posted a cm version of the design - pretty certain that had the angles on... there is certainly enough info to work it out
Remember you'll need to modify somewhat as likely you won't have the same monitor as op
kmccb23
« Reply #491 on: July 03, 2016, 01:53:10 pm »
Are you referring to this post / drawing? http://www.apjgriffiths.com/shared/METROPOLIS_ARCADE_CAB-CENTIMETRES.png
If so, still the same issue, except in centimeters.. I can't go point to point to make the angle as the measurements aren't all there to accomplish that.
vaderag
« Reply #492 on: July 03, 2016, 02:12:31 pm »
Having marked and cut mine a few weeks back using that diagram I can 100%promise that if you're looking for something that isn't on there, then it can either be worked out with some basic trigonometry or is not needed :)
kmccb23
« Reply #493 on: July 03, 2016, 02:32:56 pm »
I figure it's something I just don't "get" that's why I'm asking for help.. So in your drawing.. Let's take the 15* cut that needs made..
We know it starts 20.3 in from the left.. We know it starts 97.5 from the bottom.. We know the cut goes to 124.7.. So I know the width of the start of the cut (20.3 from the left edge). I know the height of the start of the cut (97.5 from the bottom).. I know how high I have to go with the cut (124.7 from the bottom).. But I don't know the width I take that cut to meet the 124.7 from the bottom measurement..
How do I get that?
Thanks much!!!
vaderag
« Reply #494 on: July 03, 2016, 02:51:04 pm »
Okay, so, I'm not 100% certain but I think you're talking about the main diagonal...
The key is to draw your straight lines longer than needed, but mark the end points. You'll end up with essentially dots you can join up. The 15 degrees is from the vertical, so having the longer vertical also gives you the basis for that angle. Also, I found that my protractor want precise enough to get the lines spot on with it, so doing it this way made it easier to match everything up.
Also, don't worry about being too precise on the second piece - if you're using the flush trim router then you'll be fine :)
kmccb23
« Reply #495 on: July 03, 2016, 05:07:29 pm »
Really appreciate the help.. :)
I don't think I'm going to use a router at all.. Not my best tool.. I'm just going to do my best with a circular saw and jigsaw.. So without those measurements I need.. Sounds like a protractor is 100% needed.. I had to borrow my daughters from school lol..
http://imgur.com/a/Ye6TV
The first picture is me intersecting the lines as you said.. I then put the protractor on and tried my best to mark 15*.. Is this how it has to be done?
Thanks again.
vaderag
« Reply #496 on: July 04, 2016, 03:33:46 am »
Thanks again.
Looks about right to me :)
I would seriously recommend investing in a router tho, I'd never used one before this project, but I really don't think I'd have ended up with the results I gave so far without it!!
kmccb23
« Reply #497 on: July 13, 2016, 08:25:41 am »
So I got my panels cut and my support 1x2 boards attached.. Regarding assembly.. Do the side panels just "sit" on the support 1x2 boards of the base?? Or are they screwed into those 1x2 boards from the outside of the side panels on the bottom?
vaderag
« Reply #498 on: July 16, 2016, 08:47:16 am »
I've finally nearly finished cutting all the pieces now - just the CP sides to go, but they're going to have to wait as my second cheap chinese flush trim bit has just died :(
Anyway - going to move on to the slot cutting for now (for the T-Moulding) - is it just the two sides and the CP sides that have T-Moulding on??
MOsting i'm wondering if the sides of the front panel should have it?
  • Last login:Yesterday at 01:01:52 am
« Reply #499 on: July 16, 2016, 02:24:39 pm »
Any place there are bare edges, I would have it.
der_yeti
  • Last login:June 12, 2019, 09:58:31 am
« Reply #500 on: July 22, 2016, 06:42:33 am »
Hi,
is it possible to get a cad compatible file of the sidepanels with rounded edges?
like in this Picture:
http://newwiki.arcadecontrols.com/index.php?title=File:Ond_build-004.jpg
I want to let the sides cut at a local store.
vaderag
« Reply #501 on: July 23, 2016, 01:19:20 pm »
Thanks. I'm thinking of beveling those edges so may not be bare... I'll have a think
Talking of beveling, I'm planning to do my monitor cut out tomorrow but have a question about the cut and bevel...
Obviously the router is going to give me curved corners both in the cut and the bevel... How do you overcome this to get proper right angles?
« Reply #502 on: July 23, 2016, 01:38:45 pm »
Use a chisel.
vaderag
« Reply #503 on: July 23, 2016, 01:50:22 pm »
Use a chisel.
So, do you leave some excess there, or will the excess left by the router cutting up to the corners be enough? And presumably, I'll need a good non blunt chisel (which means another trip to the shop)
« Reply #504 on: July 23, 2016, 01:52:13 pm »
Actually, recently I don't have an issue with the rounded corners - but if I have to square it, I use a chisel.
vaderag
« Reply #505 on: July 25, 2016, 08:53:42 am »
So, i never got around to my bevelling, tho i think that is the last piece of woodwork (barring cutting holes for my speakers and the CP) that is left before assembly...
Question... when using the bevel bit on the monitor cut out, do I a) run the bearing along the very bottom MM or so of the cutout, or b) use a straight edge clamped underneath and run it along that?
Obviously a) gives me a mm thickness left, so probably makes the edges more robust, but b) gives me a full bevel coming down to a point?
Cheers
vaderag
« Reply #506 on: July 25, 2016, 11:31:46 am »
Also... in the instructions, for the bezel the instructions say.
1) Cut the hole [DONE]
2) Chamfer/bezel the edges [TO DO]
3) Route the back for the monitor to sit in...
Thinking this through, if i bevel the edges then surlely once i route the rest out then the edge of the bevel is actually going to be removed by the routing out of the back, which would actually make the cut hole bigger??
kmccb23
« Reply #507 on: July 26, 2016, 10:08:26 am »
Almost finished with mine.. Just need some direction on the marquee..
If I get something similar to this - http://www.gameongrafix.com/marquees/arcade-emulator - how does it get mounted etc??
vaderag
« Reply #508 on: August 04, 2016, 03:23:32 am »
There are a few suggestions around here, I think further up this thread maybe, but I'm planning to go with the plastic paper binder option when I get there :)
« Reply #509 on: August 26, 2016, 12:23:24 am »
I was pondering this 'project' the other day. You know, thinking about my Metropolis theme, the artwork and so forth. I thought "If I were to build this myself what would I do differently".  Structurally I think I'd stick to the design,  then I got an idea! what about putting just one game on the cab.  A game of Metropolis that I write?  It would all hang together then, the artwork, the game, the theme.  It could be fun - a scrolling 2D platform Metropolis game.  Is it hard to do?  :dunno D'ya think I could do it?  What should the game play be?  Would anyone be interested?
vaderag
« Reply #510 on: August 26, 2016, 02:23:35 am »
Nice idea! I had the same thought with my cab - Super Bubble Fighter II Turbo.
I guess simplest way would be to replace the sprites on an existing game?? Creating your own would be challenging and unless you're aiming to seriously work hard on it with a mind to maybe selling, it would probably be a bit naff ;)
I wanted to ask about the build, where the cp back creates the lip for the plexi to sit, is the cp supposed to be level or stick up a bit too help with the lip?
« Reply #511 on: August 29, 2016, 06:32:12 pm »
About the game development, both idea's interest me.  A good start would be to hack an existing game.  Going from scratch maybe too ambitious, but I never think about that, just go where it takes me.
The thickness of the CP provides the lip behind which the plexi sits.  The rear edge of the panel is rounded off to provide a gap - like in the diagram.
« Reply #512 on: August 29, 2016, 10:00:50 pm »
Based on the movie Metropolis??? Sign me up!
« Reply #513 on: August 29, 2016, 11:40:27 pm »
Heh, I was wondering when you'd catch this  ;D.  Yes based on the movie, it has plenty that could be material for a game:
-Futuristic city as imagined in 1927!
-Evil robot inventor Rotwang who builds a robot with hopes of recreating his wife Hel.
-The "False Maria" robot spreading chaos in the underground city, inciting riots and mayhem.
-The heroine Maria trying to rescue people from a flooding city.
-The giant Heart Machine requiring constant 'hands on' to stop it from blowing it's stack.
-The hero Freder running  around underground catacombs battling evil and trying to save the day.
Side scrolling 2D, all in glorious 8 bit looking, chunky sprites etc!
Could be my obsession in 2017 (assuming current stuff is complete).
« Last Edit: August 30, 2016, 04:24:24 am by Ond »
vaderag
« Reply #514 on: August 30, 2016, 03:13:49 am »
So  just to confirm, you've rounded both the front and the back of the main cp piece and then that sits on top of the cp back piece (flush at the back). The cp back piece then attaches to the cp backing piece which is attached to the main body. And the plexi sits on top of the cp backing held in place by the extra height  from the rounded cp back??
« Reply #515 on: August 30, 2016, 04:22:20 am »
Yes! That is exactly correct.
vaderag
« Reply #516 on: August 30, 2016, 04:23:47 am »
Perfect, thanks :) Ill hopefully drill the holes for fixing those two bits later!!
vaderag
« Reply #517 on: August 30, 2016, 04:24:55 am »
Side scrolling 2D, all in glorious 8 bit, chunky sprites etc!
Sounds like tweaking Sonic sprites from the Cyber City zone might work :)
« Last Edit: August 30, 2016, 05:53:39 am by vaderag »
vaderag
« Reply #518 on: September 11, 2016, 03:34:15 am »
Question... What's the best way to get the pieces squared up... Presumably I need an angle on a few of the pieces that fill gaps (and on the cp back piece since the top piece is at an angle...) - do I just sand these with a bit of guesswork??
JudgeRob
  • Last login:July 13, 2024, 10:00:33 pm
« Reply #519 on: September 14, 2016, 07:23:58 pm »
Router an angle down the long edge to get it close.  Fill any gaps and sand to perfection.
