January 30, 2026, 08:17:12 am
Chuck, gotta say, that Mala layout is awesome and really caps off the bartop, Dog. Good lookin' out.[end Randy Jackson impression]
OpenQwaq looks pretty cool. The server install is a ---smurfette--- but straight forward. I'll stand up a CentOS box in the farm when I get home tonight and see if I can get it running. I could see a setup where there would be a hallway and two rooms. The one on the left has the classics built by manufacturers so people could go back and look at them to get inspiration. The room on the right would have all home built/reworked cabs.Can you guys post some 3d drawings here or somewhere I can download them to see if I can import them in? .KMZ export preferably as this looks to be the wanted export/import for OpenQwaq.
Well, I've found at least a couple of possible free to try options to convert Solidworks to SketchUp so I'll have to update my Solidworks assembly to my as built condition. I'll report back if I get something to work. I've also seen some mentions that OpenQwaq supports PDF. Any idea if it supports 3D PDFs? Solidworks can directly export to that format.
That's pretty cool. Of course, to get the proper arcade ambiance, it'll need lower lights and a soundtrack by, say, The Cars...What kind of client would be needed for viewing? Something OS-independent, hopefully...
Kahlid74:At one point alfonzotan's Tron had more photo textures than just the marquee. did something happen with quak or did you get the model that way? just curious.
I might be able to help here, I've built some open qwaq environments before.Success of kmz imports can depend on how the setup was built, using logical groups of components helps. You can explode the models after import into those components and set properties etc.We're not limited to the template environments supplied, we could make our own arcade building. Anyone got a sketch up mOdell of something that would do? Maybe we could tweak something from google warehouse...Pm me if I can help at all...
Well here's the question, is this what we want? If it is, I'll create the environment and get it up and then I'll get you access EightBySix and everyone else and you can start experimenting with it. My video was really just a "Is this what we want before I spend my time opening up my five firewalls and creating my loadbalancer environment because I'm stupid crazy when it comes to my home network"question.
