Author Topic: AVGA 3000 Driver install done, DVi Port no image, is that normal after Tri sync?  (Read 1272 times)
gatordad
  • Trade Count: (+11)
  • Last login:October 01, 2025, 10:06:07 am
Hi guys
I'm configuring a new computer and I just installed XP with all the latest updates on a new drive, Troubleshoot a bad stick of RAM that was causing the Blue screen of Death, now I'm on to the AVGA 3000 install.
I removed all my orig ati drivers, installed the avga 3000, installed the drivers, set up the tri sync utility, and choose MultiFrequency Monitor 15-38 as this will be used with a wg d 9800.
I still have this running off a lcd and now I have no image from the DVI port, Is that normal after running the tri sync utility?
I want to install the rest of the misc stuff (software, pc games etc.) before putting this in the cab and hooking up the wg d9800
Any advice is appreciated
gatordad
Just to add some additional info
Before I installed the Tri sync utility, I had dvi port lcd image and was able to verify that all the drivers loaded or at least I was able to see the different resolutions that were now available.
Only after running the Tri Sync utility did the DVI port lcd stop responding
Do you think I need to set up mirrored displays or extended desktop?
I am going to uninstall and try again tonight but It seems more difficult than it should be.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
The multi-frequency monitor should be connected to the VGA port not the DVI port.
Andy
