Author Topic: Exiting Model 2 Through MaLa  (Read 4756 times)
Hadeys
  • Last login:January 07, 2024, 08:36:03 pm
« on: January 08, 2012, 02:12:26 am »
Hi, I've been having a problem where I am unable to exit Model 2.  It launches fine, but once Model 2 is running, hitting escape only puts the screen in windowed mode, instead of terminating the program altogether.  Does anybody have any experience with this? This problem has been plaguing me for months!  Any advice helps. Thanks for your time.
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
Re: Exiting Model 2 Through MaLa
« Reply #1 on: January 08, 2012, 05:32:13 am »
¿Have you tested AllInOne?
Celsius
  • Last login:May 10, 2015, 11:40:41 am
    • Rcade project
« Reply #2 on: January 08, 2012, 07:43:18 am »
or closemul
empardopo
    • My personal forum
« Reply #3 on: January 09, 2012, 05:23:43 am »
Yes.
AllInOne can be very useful!  :blah:
thatgammon
  • Last login:July 03, 2020, 05:25:03 am
« Reply #4 on: January 10, 2012, 04:40:03 am »
Yeah use the hot-keys option!!!
Hadeys
« Reply #5 on: January 14, 2012, 04:20:27 pm »
Could somebody explain how closemul works? I've put a few hours into dinking around with it but I've had to success.
thatgammon
« Reply #6 on: January 15, 2012, 09:02:09 am »
Just had to re-install my model 2, using escape as a hotkey works fine.
Have you tried that?
sega_mad
  • Last login:July 09, 2015, 04:03:08 am
« Reply #7 on: February 04, 2012, 11:54:16 pm »
Hi,
I've been through this exact process.
Follow this thread.....start from where "Nitz" gets involved. (he does a step by step resolution)
http://forum.arcadecontrols.com/index.php?topic=112985.0
By doing this it will also hide the M2 picture on start up. Just follow the directions to the letter, and you'lll be fine ;D
Cheers
« Last Edit: February 05, 2012, 12:00:53 am by sega_mad »
thatgammon
« Reply #8 on: February 05, 2012, 12:54:30 pm »
Yeah that solves the launch screen issue but this is for quiting model2!
Setting up a hot key will escape to Mala!
Wade007
  • Last login:April 06, 2017, 01:33:35 pm
  • A MAME cabinet at home is heaven
    • bit.ly/1cWnoIC
    • Cheapskategamer.com
« Reply #9 on: April 27, 2012, 11:34:00 pm »
I'm having the same problem.
I can launch the Model 2 emulator just fine, but if I hit ESC it just shows the M2 shell. It doesn't go back to MALA.
Where can I get this "AllinOne"?? Help?
<coming back from forum search>
Here's the right answer. Use Hotkeys:
http://forum.arcadecontrols.com/index.php?topic=116475.0
See post by harveybirdman-
"When you select close [in Hot Keys] as the feature the field [Sourc] where the default "ESC" is displayed becomes grayed out.[click to make grey]
However you can still click in there an press the button that you really want to use, such as Q, F1 or whatever.
Going to test this really quick on my "cab" (it's not really a cab yet  Wink) and I'll come back and post the results.
EDIT:  indeed this works no problems so you can set your "hotkey" for quit to anything you want."
I tried this out and it works. I used SPACE button in the "Source" field instead of ESC for the "Close" function.
« Last Edit: April 28, 2012, 11:37:52 am by Wade007 »
My Super Arcade cabinet project:
Software blog article: http://bit.ly/1cWnoIC
Hardware blog article: http://bit.ly/1dWxjvP
YouTube video: http://bit.ly/1N818Xm
Super Arcade Cabinet Progress thread (Now Complete):
http://forum.arcadecontrols.com/index.php/topic,123292.0.html
Frontend Video Intro: http://bit.ly/1P9HPDN
