Author Topic: Sound issues with groovymame  (Read 12372 times)
White_widow57
  • Last login:June 20, 2012, 09:52:33 am
« on: January 02, 2012, 08:22:55 pm »
After testing with my Arcadevga 7000, i've found an ati radeon 9250 use with calamity 6.5 but always the problem! With groovymame i have sound craps with neogeo's game, pacman, ... And when i close groovymame, in the dosbox, i can see that the game speed is about 97-98% (neo-geo) and 85%(pacman) or 102%(cps2). Icanot see slowdown, just with the sound, same thing with Cabmame! I think it just with game that don't have real 60 Hz refresh rate.
Ps: i use a p4 2.5ghz with 1gb ram
  • Last login:Yesterday at 05:28:27 pm
Re: Sound issues with groovymame
« Reply #1 on: January 03, 2012, 11:08:07 am »
There's definitely somethig odd going on with your system. The -soundsync patch relies on using a stream buffer with the DSBCAPS_CTRLFREQUENCY flag activated... maybe this feature is not supported by your souncard/drivers (weird).
I'm testing a completely different implementation for the -soundsync patch that should work for both Windows and Linux and might solve your issue. Hopefully I gather some time to make a new buid with this and other changes I have in mind.
White_widow57
« Reply #2 on: January 03, 2012, 12:16:53 pm »
In my mind it doesn't come from the soundcard because i've test with a soundblaster pci 512 and with the AC'97 of the motherboard. I've just test with the classic version of Mame, and i have the same problème :/
White_widow57
« Reply #3 on: January 05, 2012, 12:11:42 am »
Same problem with mame/cabmame and with arcadevga(without "only 60hz" in avres) or with radeon 9250 + calamity + groovymame :/
Paradroid
    • SCART Hunter
« Reply #4 on: January 05, 2012, 06:36:47 am »
Sounds like you have some performance issues with your system that aren't directly related to GroovyMAME. For what it's worth, I was having some stuttering problems (video and audio) with my test system (an old Core 2 Duo that was previously used as a HTPC) and spent some time tweaking it today to try to sort it out. I uninstalled a whole bunch of stuff that was no longer needed (virus scanner, media software, etc.) and now the problems have gone. Played a bunch of games tonight and everything was perfect. :) I can't say exactly what fixed my particular issue (since I went to town on my system) but my point is that there must be something causing your problem. The trick is finding exactly what it is. ;)
Aside from retro gaming, I use computers for audio production. I've spent a lot of time over the years chasing down the cause of dropouts and glitches. One of the most useful tools I ever found is DPC Latency Checker <http://www.thesycon.de/deu/latency_check.shtml>. Once you tweak your system (through disabling processes, getting all your drivers in order, etc) and get green bars on the DPC graph, your audio should be problem free. That's my experience, at least.
Of course, your problem might be something entirely different... :dunno
« Reply #5 on: January 05, 2012, 07:14:19 am »
I agree with Paradroid, there's something else going on there, probably CPU related. There might be a combination of different issues.
For instance, if GroovyMAME is producing the right modelines (check logs) neo-geo games should run very close to 100%. Pacman slowdown is normal due to having 288 lines when rotated.
There is nothing special about 60 Hz modes that should keep the sound perfect, unless there's something completely odd we're not considering in the equation. Just by chance, have you got a secondary PC monitor attached when doing these tests?
White_widow57
« Reply #6 on: January 05, 2012, 08:18:48 am »
No i just have the tv ( vga to scart ). My computer has just been formated, Xp cleen with latest drivers! And with the arcadevga if i Check only 60hz in Avgares, there isn't any sound crap so i do not think it come from the computer.
« Reply #7 on: January 05, 2012, 08:49:30 am »
Do you remove the ini folder before testing GroovyMAME?
White_widow57
« Reply #8 on: January 05, 2012, 09:14:36 am »
There isn't any ini folder.
« Reply #9 on: January 05, 2012, 10:15:55 am »
When you run AVGAres, it produces lots of inis that go into the INI folder inside MAME's folder. I just wanted to make sure that those inis are not left there after that interferring with GroovyMAME's behaviour.
Anyway, please send me a log (groovymame romname -v -md 4 >romname.txt) of one of neo-geo games, that might help me figure out what's going on.
White_widow57
« Reply #10 on: January 05, 2012, 10:59:17 am »
There isn't any ini files because i have restore the computer. I send you this after 6pm.
White_widow57
« Reply #11 on: January 05, 2012, 03:53:28 pm »
That's a neogeo game!
Parsing mame.ini
Parsing mame.ini
SwitchRes: Entering switchres_modeline_setup (0)
SwitchRes: Monitor: cga Orientation: horizontal Aspect 4:3
SwitchRes: MonitorLimits 15250.00-15700.00,49.50-65.00,2.000,4.700,8.000,0.064,0.192,1.024,0,0,288.0,448
SwitchRes: Raw limits (59.1856Hz)-> YresMin= 237p, YresMax= 245p(490i)
SwitchRes: Logical limit YresMin (448/2) = 224p
SwitchRes: Setup monitor limits min=184x224 max=0x490
SwitchRes: Starting with Horizontal freq of 14.344 and Vertical refresh of 59.19
SwitchRes: Increased horizontal frequency from 14.344 to 15.250
SwitchRes: Using 14 lines padding
SwitchRes: # 15.250Khz -> 15.700Khz: ( | Hfreq Change | Vpad +14 lines | )
SwitchRes: # kof2003 [3] 320x224@59.19 15.2699Khz
SwitchRes: ModeLine          "320x224x59.19" 6.474431 320 336 368 424 224 232 235 258 -HSync -VSync
SwitchRes v0.013: [kof2003] (1) horizontal (320x224@59.19)->(320x224@59.19)->(320x224@59.19)
SwitchRes: # kof2003 320x224@59.19 15.2699Khz
SwitchRes: DefaultVideo 'System\CurrentControlSet\Control\Video\{6546FC24-497E-4F96-8A99-E9E9D23EAFB2}\0000'
SwitchRes: DALDTMCRTBCD192X224X0X60:
 SwitchRes: (63729/68) Modeline 4.000000 192 200 224 256 224 234 237 261
SwitchRes: DALDTMCRTBCD216X224X0X60:
 SwitchRes: (63570/68) Modeline 4.630000 216 232 256 296 224 234 237 261
SwitchRes: DALDTMCRTBCD224X224X0X60:
 SwitchRes: (63533/68) Modeline 4.760000 224 240 264 304 224 234 237 261
SwitchRes: DALDTMCRTBCD224X240X0X60:
 SwitchRes: (63509/68) Modeline 4.760000 224 240 264 304 240 242 245 261
SwitchRes: DALDTMCRTBCD232X224X0X60:
 SwitchRes: (63497/68) Modeline 4.880000 232 248 272 312 224 234 237 261
SwitchRes: DALDTMCRTBCD240X224X0X60:
 SwitchRes: (63460/68) Modeline 5.010000 240 256 280 320 224 234 237 261
SwitchRes: DALDTMCRTBCD240X240X0X60:
 SwitchRes: (63436/68) Modeline 5.010000 240 256 280 320 240 242 245 261
SwitchRes: DALDTMCRTBCD240X256X0X59:
 SwitchRes: (63350/68) Modeline 5.310000 240 256 280 328 256 258 261 277
SwitchRes: DALDTMCRTBCD248X224X0X60:
 SwitchRes: (63403/68) Modeline 5.260000 248 264 288 336 224 234 237 261
SwitchRes: DALDTMCRTBCD248X240X0X60:
 SwitchRes: (63379/68) Modeline 5.260000 248 264 288 336 240 242 245 261
SwitchRes: DALDTMCRTBCD248X256X0X59:
 SwitchRes: (63284/68) Modeline 5.570000 248 264 296 344 256 258 261 277
SwitchRes: DALDTMCRTBCD256X224X0X60:
 SwitchRes: (63338/68) Modeline 5.510000 256 272 304 352 224 234 237 261
SwitchRes: DALDTMCRTBCD256X240X0X60:
 SwitchRes: (63314/68) Modeline 5.510000 256 272 304 352 240 242 245 261
SwitchRes: DALDTMCRTBCD256X256X0X59:
 SwitchRes: (63247/68) Modeline 5.700000 256 272 304 352 256 258 261 277
SwitchRes: DALDTMCRTBCD256X288X0X52:
 SwitchRes: (63151/68) Modeline 5.700000 256 272 304 352 288 290 293 309
SwitchRes: DALDTMCRTBCD264X224X0X60:
 SwitchRes: (63302/68) Modeline 5.630000 264 280 312 360 224 234 237 261
SwitchRes: DALDTMCRTBCD264X240X0X60:
 SwitchRes: (63278/68) Modeline 5.630000 264 280 312 360 240 242 245 261
SwitchRes: DALDTMCRTBCD272X224X0X60:
 SwitchRes: (63265/68) Modeline 5.760000 272 288 320 368 224 234 237 261
SwitchRes: DALDTMCRTBCD280X224X0X60:
 SwitchRes: (63229/68) Modeline 5.880000 280 296 328 376 224 234 237 261
SwitchRes: DALDTMCRTBCD280X240X0X60:
 SwitchRes: (63205/68) Modeline 5.880000 280 296 328 376 240 242 245 261
SwitchRes: DALDTMCRTBCD288X224X0X60:
 SwitchRes: (63192/68) Modeline 6.010000 288 304 336 384 224 234 237 261
SwitchRes: DALDTMCRTBCD288X240X0X60:
 SwitchRes: (63168/68) Modeline 6.010000 288 304 336 384 240 242 245 261
SwitchRes: DALDTMCRTBCD296X224X0X60:
 SwitchRes: (63156/68) Modeline 6.130000 296 312 344 392 224 234 237 261
SwitchRes: DALDTMCRTBCD296X240X0X60:
 SwitchRes: (63132/68) Modeline 6.130000 296 312 344 392 240 242 245 261
SwitchRes: DALDTMCRTBCD304X224X0X60:
 SwitchRes: (63099/68) Modeline 6.380000 304 320 352 408 224 234 237 261
SwitchRes: DALDTMCRTBCD304X240X0X60:
 SwitchRes: (63075/68) Modeline 6.380000 304 320 352 408 240 242 245 261
SwitchRes: DALDTMCRTBCD312X288X0X53:
 SwitchRes: (62872/68) Modeline 6.730000 312 328 360 416 288 290 293 309
SwitchRes: DALDTMCRTBCD320X224X0X60:
 SwitchRes: (63026/68) Modeline 6.630000 320 336 368 424 224 234 237 261
SwitchRes: DALDTMCRTBCD320X240X0X60:
 SwitchRes: (63002/68) Modeline 6.630000 320 336 368 424 240 242 245 261
SwitchRes: DALDTMCRTBCD320X256X0X58:
 SwitchRes: (62931/68) Modeline 6.860000 320 336 368 424 256 258 261 277
SwitchRes: DALDTMCRTBCD320X448X0X60:
 SwitchRes: (62307/68) Modeline 6.620000 320 336 368 424 448 466 471 521 interlace
SwitchRes: DALDTMCRTBCD320X480X0X60:
 SwitchRes: (62259/68) Modeline 6.620000 320 336 368 424 480 482 487 521 interlace
SwitchRes: DALDTMCRTBCD328X224X0X60:
 SwitchRes: (62989/68) Modeline 6.760000 328 344 376 432 224 234 237 261
SwitchRes: DALDTMCRTBCD328X256X0X58:
 SwitchRes: (62894/68) Modeline 6.990000 328 344 376 432 256 258 261 277
SwitchRes: DALDTMCRTBCD336X240X0X60:
 SwitchRes: (62928/68) Modeline 6.890000 336 352 384 440 240 242 245 261
SwitchRes: DALDTMCRTBCD336X256X0X58:
 SwitchRes: (62807/68) Modeline 7.380000 336 352 392 456 256 258 261 277
SwitchRes: DALDTMCRTBCD344X240X0X60:
 SwitchRes: (62892/68) Modeline 7.010000 344 360 392 448 240 242 245 261
SwitchRes: DALDTMCRTBCD344X256X0X58:
 SwitchRes: (62770/68) Modeline 7.510000 344 360 400 464 256 258 261 277
SwitchRes: DALDTMCRTBCD352X224X0X60:
 SwitchRes: (62830/68) Modeline 7.390000 352 368 408 472 224 234 237 261
SwitchRes: DALDTMCRTBCD352X240X0X60:
 SwitchRes: (62806/68) Modeline 7.390000 352 368 408 472 240 242 245 261
SwitchRes: DALDTMCRTBCD352X256X0X58:
 SwitchRes: (62733/68) Modeline 7.640000 352 368 408 472 256 258 261 277
SwitchRes: DALDTMCRTBCD360X224X0X60:
 SwitchRes: (62794/68) Modeline 7.510000 360 376 416 480 224 234 237 261
SwitchRes: DALDTMCRTBCD360X240X0X60:
 SwitchRes: (62770/68) Modeline 7.510000 360 376 416 480 240 242 245 261
SwitchRes: DALDTMCRTBCD368X224X0X60:
 SwitchRes: (62757/68) Modeline 7.640000 368 384 424 488 224 234 237 261
SwitchRes: DALDTMCRTBCD368X240X0X60:
 SwitchRes: (62733/68) Modeline 7.640000 368 384 424 488 240 242 245 261
SwitchRes: DALDTMCRTBCD368X256X0X58:
 SwitchRes: (62659/68) Modeline 7.900000 368 384 424 488 256 258 261 277
SwitchRes: DALDTMCRTBCD368X448X0X60:
 SwitchRes: (62039/68) Modeline 7.620000 368 384 424 488 448 466 471 521 interlace
SwitchRes: DALDTMCRTBCD376X240X0X60:
 SwitchRes: (62697/68) Modeline 7.760000 376 392 432 496 240 242 245 261
SwitchRes: DALDTMCRTBCD376X256X0X59:
 SwitchRes: (62622/68) Modeline 8.030000 376 392 432 496 256 258 261 277
SwitchRes: DALDTMCRTBCD376X272X0X55:
 SwitchRes: (62574/68) Modeline 8.030000 376 392 432 496 272 274 277 293
SwitchRes: DALDTMCRTBCD384X224X0X60:
 SwitchRes: (62685/68) Modeline 7.880000 384 400 440 504 224 234 237 261
SwitchRes: DALDTMCRTBCD384X240X0X60:
 SwitchRes: (62661/68) Modeline 7.880000 384 400 440 504 240 242 245 261
SwitchRes: DALDTMCRTBCD384X256X0X58:
 SwitchRes: (62585/68) Modeline 8.160000 384 400 440 504 256 258 261 277
SwitchRes: DALDTMCRTBCD384X288X0X52:
 SwitchRes: (62489/68) Modeline 8.160000 384 400 440 504 288 290 293 309
SwitchRes: DALDTMCRTBCD400X224X0X60:
 SwitchRes: (62612/68) Modeline 8.130000 400 416 456 520 224 234 237 261
SwitchRes: DALDTMCRTBCD400X232X0X60:
 SwitchRes: (62600/68) Modeline 8.130000 400 416 456 520 232 238 241 261
SwitchRes: DALDTMCRTBCD400X240X0X60:
 SwitchRes: (62588/68) Modeline 8.130000 400 416 456 520 240 242 245 261
SwitchRes: DALDTMCRTBCD400X248X0X60:
 SwitchRes: (62518/68) Modeline 8.510000 400 416 456 528 248 250 253 269
SwitchRes: DALDTMCRTBCD400X256X0X59:
 SwitchRes: (62491/68) Modeline 8.540000 400 416 456 528 256 258 261 277
SwitchRes: DALDTMCRTBCD400X264X0X57:
 SwitchRes: (62467/68) Modeline 8.540000 400 416 456 528 264 266 269 285
SwitchRes: DALDTMCRTBCD400X272X0X55:
 SwitchRes: (62443/68) Modeline 8.540000 400 416 456 528 272 274 277 293
SwitchRes: DALDTMCRTBCD400X280X0X54:
 SwitchRes: (62419/68) Modeline 8.540000 400 416 456 528 280 282 285 301
SwitchRes: DALDTMCRTBCD400X288X0X52:
 SwitchRes: (62395/68) Modeline 8.540000 400 416 456 528 288 290 293 309
SwitchRes: DALDTMCRTBCD416X224X0X60:
 SwitchRes: (62519/68) Modeline 8.500000 416 432 472 544 224 234 237 261
SwitchRes: DALDTMCRTBCD416X256X0X58:
 SwitchRes: (62415/68) Modeline 8.820000 416 432 472 544 256 258 261 277
SwitchRes: DALDTMCRTBCD432X224X0X60:
 SwitchRes: (62445/68) Modeline 8.760000 432 448 488 560 224 234 237 261
SwitchRes: DALDTMCRTBCD432X240X0X60:
 SwitchRes: (62421/68) Modeline 8.760000 432 448 488 560 240 242 245 261
SwitchRes: DALDTMCRTBCD432X248X0X60:
 SwitchRes: (62290/68) Modeline 9.430000 432 456 504 584 248 250 253 269
SwitchRes: DALDTMCRTBCD432X256X0X58:
 SwitchRes: (62263/68) Modeline 9.460000 432 456 504 584 256 258 261 277
SwitchRes: DALDTMCRTBCD432X264X0X57:
 SwitchRes: (62239/68) Modeline 9.460000 432 456 504 584 264 266 269 285
SwitchRes: DALDTMCRTBCD432X272X0X55:
 SwitchRes: (62215/68) Modeline 9.460000 432 456 504 584 272 274 277 293
SwitchRes: DALDTMCRTBCD432X280X0X54:
 SwitchRes: (62191/68) Modeline 9.460000 432 456 504 584 280 282 285 301
SwitchRes: DALDTMCRTBCD448X224X0X60:
 SwitchRes: (62294/68) Modeline 9.390000 448 472 520 600 224 234 237 261
SwitchRes: DALDTMCRTBCD448X240X0X60:
 SwitchRes: (62270/68) Modeline 9.390000 448 472 520 600 240 242 245 261
SwitchRes: DALDTMCRTBCD456X232X0X60:
 SwitchRes: (62244/68) Modeline 9.530000 456 480 528 608 232 238 241 261
SwitchRes: DALDTMCRTBCD456X240X0X60:
 SwitchRes: (62232/68) Modeline 9.530000 456 480 528 608 240 242 245 261
SwitchRes: DALDTMCRTBCD456X256X0X58:
 SwitchRes: (62152/68) Modeline 9.850000 456 480 528 608 256 258 261 277
SwitchRes: DALDTMCRTBCD464X224X0X60:
 SwitchRes: (62220/68) Modeline 9.650000 464 488 536 616 224 234 237 261
SwitchRes: DALDTMCRTBCD464X256X0X59:
 SwitchRes: (62114/68) Modeline 9.990000 464 488 536 616 256 258 261 277
SwitchRes: DALDTMCRTBCD480X224X0X60:
 SwitchRes: (62148/68) Modeline 9.890000 480 504 552 632 224 234 237 261
SwitchRes: DALDTMCRTBCD480X240X0X60:
 SwitchRes: (62124/68) Modeline 9.890000 480 504 552 632 240 242 245 261
SwitchRes: DALDTMCRTBCD480X464X0X60:
 SwitchRes: (61406/68) Modeline 9.870000 480 504 552 632 464 474 479 521 interlace
SwitchRes: DALDTMCRTBCD480X480X0X60:
 SwitchRes: (61382/68) Modeline 9.870000 480 504 552 632 480 482 487 521 interlace
SwitchRes: DALDTMCRTBCD496X224X0X60:
 SwitchRes: (62074/68) Modeline 10.150000 496 520 568 648 224 234 237 261
SwitchRes: DALDTMCRTBCD496X240X0X60:
 SwitchRes: (62050/68) Modeline 10.150000 496 520 568 648 240 242 245 261
SwitchRes: DALDTMCRTBCD496X480X0X60:
 SwitchRes: (61307/68) Modeline 10.140000 496 520 568 648 480 482 487 521 interlace
SwitchRes: DALDTMCRTBCD512X224X0X60:
 SwitchRes: (61981/68) Modeline 10.520000 512 536 584 672 224 234 237 261
SwitchRes: DALDTMCRTBCD512X240X0X60:
 SwitchRes: (61957/68) Modeline 10.520000 512 536 584 672 240 242 245 261
SwitchRes: DALDTMCRTBCD512X256X0X58:
 SwitchRes: (61845/68) Modeline 11.000000 512 536 592 680 256 258 261 277
SwitchRes: DALDTMCRTBCD512X288X0X52:
 SwitchRes: (61749/68) Modeline 11.000000 512 536 592 680 288 290 293 309
SwitchRes: DALDTMCRTBCD512X448X0X60:
 SwitchRes: (61262/68) Modeline 10.510000 512 536 584 672 448 466 471 521 interlace
SwitchRes: DALDTMCRTBCD512X480X0X60:
 SwitchRes: (61214/68) Modeline 10.510000 512 536 584 672 480 482 487 521 interlace
SwitchRes: DALDTMCRTBCD544X256X0X58:
 SwitchRes: (61675/68) Modeline 11.660000 544 568 624 720 256 258 261 277
SwitchRes: DALDTMCRTBCD544X480X0X60:
 SwitchRes: (61041/68) Modeline 11.120000 544 568 624 712 480 482 487 521 interlace
SwitchRes: DALDTMCRTBCD576X224X0X60:
 SwitchRes: (61639/68) Modeline 11.780000 576 600 656 752 224 234 237 261
SwitchRes: DALDTMCRTBCD640X240X0X60:
 SwitchRes: (61273/68) Modeline 13.040000 640 664 728 832 240 242 245 261
SwitchRes: DALDTMCRTBCD640X256X0X58:
 SwitchRes: (61133/68) Modeline 13.720000 640 672 736 848 256 258 261 277
SwitchRes: DALDTMCRTBCD640X480X0X60:
 SwitchRes: (60535/68) Modeline 12.980000 640 664 728 832 480 482 487 521 interlace
SwitchRes: DALDTMCRTBCD640X480X0X61:
 SwitchRes: (60503/68) Modeline 13.270000 640 664 728 832 480 483 488 523 interlace
SwitchRes: DALDTMCRTBCD640X480X0X62:
 SwitchRes: (60435/68) Modeline 13.710000 640 672 736 848 480 483 488 523 interlace
SwitchRes: DALDTMCRTBCD648X240X0X60:
 SwitchRes: (61239/68) Modeline 13.140000 648 672 736 840 240 242 245 261
SwitchRes: DALDTMCRTBCD664X496X0X59:
 SwitchRes: (60300/68) Modeline 13.860000 664 696 760 872 496 499 504 539 interlace
SwitchRes: DALDTMCRTBCD664X496X0X60:
 SwitchRes: (60277/68) Modeline 14.090000 664 696 760 872 496 499 504 539 interlace
SwitchRes: DALDTMCRTBCD672X224X0X60:
 SwitchRes: (61105/68) Modeline 13.760000 672 704 768 880 224 234 237 261
SwitchRes: DALDTMCRTBCD672X240X0X60:
 SwitchRes: (61081/68) Modeline 13.760000 672 704 768 880 240 242 245 261
SwitchRes: DALDTMCRTBCD672X272X0X55:
 SwitchRes: (60884/68) Modeline 14.530000 672 704 776 896 272 274 277 293
SwitchRes: DALDTMCRTBCD688X512X0X57:
 SwitchRes: (60151/68) Modeline 14.150000 688 720 784 896 512 515 520 555 interlace
SwitchRes: DALDTMCRTBCD688X512X0X58:
 SwitchRes: (60076/68) Modeline 14.660000 688 720 792 912 512 515 520 555 interlace
SwitchRes: DALDTMCRTBCD704X240X0X60:
 SwitchRes: (60884/68) Modeline 14.530000 704 736 808 928 240 242 245 261
SwitchRes: DALDTMCRTBCD704X272X0X55:
 SwitchRes: (60737/68) Modeline 15.040000 704 736 808 928 272 274 277 293
SwitchRes: DALDTMCRTBCD704X480X0X60:
 SwitchRes: (60144/68) Modeline 14.490000 704 736 808 928 480 482 487 521 interlace
SwitchRes: DALDTMCRTBCD704X528X0X56:
 SwitchRes: (59963/68) Modeline 14.830000 704 736 808 928 528 531 536 571 interlace
SwitchRes: DALDTMCRTBCD720X480X0X60:
 SwitchRes: (60071/68) Modeline 14.740000 720 752 824 944 480 482 487 521 interlace
SwitchRes: DALDTMCRTBCD728X544X0X54:
 SwitchRes: (59815/68) Modeline 15.110000 728 760 832 952 544 547 552 587 interlace
SwitchRes: DALDTMCRTBCD728X544X0X55:
 SwitchRes: (59791/68) Modeline 15.350000 728 760 832 952 544 547 552 587 interlace
SwitchRes: DALDTMCRTBCD736X272X0X55:
 SwitchRes: (60568/68) Modeline 15.690000 736 768 840 968 272 274 277 293
SwitchRes: DALDTMCRTBCD768X224X0X60:
 SwitchRes: (60597/68) Modeline 15.640000 768 800 872 1000 224 234 237 261
SwitchRes: DALDTMCRTBCD768X576X0X52:
 SwitchRes: (59462/68) Modeline 16.240000 768 800 880 1008 576 579 584 619 interlace
SwitchRes: DALDTMCRTBCD792X592X0X49:
 SwitchRes: (59343/68) Modeline 16.230000 792 824 904 1032 592 595 600 635 interlace
SwitchRes: DALDTMCRTBCD792X592X0X50:
 SwitchRes: (59330/68) Modeline 16.360000 792 824 904 1032 592 595 600 635 interlace
SwitchRes: DALDTMCRTBCD1280X240X0X60:
 SwitchRes: (57800/68) Modeline 25.930000 1280 1328 1448 1656 240 242 245 261
SwitchRes: Found 120 custom of 129 active modelines
[0]SwitchRes: 192 x 224 @ 60p-> 0.00 Custom Modeline
[1]SwitchRes: 216 x 224 @ 60p-> 0.00 Custom Modeline
[2]SwitchRes: 224 x 224 @ 60p-> 0.00 Custom Modeline
[3]SwitchRes: 224 x 240 @ 60p-> 0.00 Custom Modeline
[4]SwitchRes: 232 x 224 @ 60p-> 0.00 Custom Modeline
[5]SwitchRes: 240 x 224 @ 60p-> 0.00 Custom Modeline
[6]SwitchRes: 240 x 240 @ 60p-> 0.00 Custom Modeline
[7]SwitchRes: 240 x 256 @ 59p-> 0.00 Custom Modeline
[8]SwitchRes: 248 x 224 @ 60p-> 0.00 Custom Modeline
[9]SwitchRes: 248 x 240 @ 60p-> 0.00 Custom Modeline
[10]SwitchRes: 248 x 256 @ 59p-> 0.00 Custom Modeline
[11]SwitchRes: 256 x 224 @ 60p-> 0.00 Custom Modeline
[12]SwitchRes: 256 x 240 @ 60p-> 0.00 Custom Modeline
[13]SwitchRes: 256 x 256 @ 59p-> 0.00 Custom Modeline
[14]SwitchRes: 256 x 288 @ 52p-> 0.00 Custom Modeline
[15]SwitchRes: 264 x 224 @ 60p-> 0.00 Custom Modeline
[16]SwitchRes: 264 x 240 @ 60p-> 0.00 Custom Modeline
[17]SwitchRes: 272 x 224 @ 60p-> 0.00 Custom Modeline
[18]SwitchRes: 280 x 224 @ 60p-> 0.00 Custom Modeline
[19]SwitchRes: 280 x 240 @ 60p-> 0.00 Custom Modeline
[20]SwitchRes: 288 x 224 @ 60p-> 0.00 Custom Modeline
[21]SwitchRes: 288 x 240 @ 60p-> 0.00 Custom Modeline
[22]SwitchRes: 296 x 224 @ 60p-> 0.00 Custom Modeline
[23]SwitchRes: 296 x 240 @ 60p-> 0.00 Custom Modeline
[24]SwitchRes: 304 x 224 @ 60p-> 0.00 Custom Modeline
[25]SwitchRes: 304 x 240 @ 60p-> 0.00 Custom Modeline
[26]SwitchRes: 312 x 288 @ 53p-> 0.00 Custom Modeline
[27]SwitchRes: 320 x 224 @ 60p-> 98.00 Custom Modeline
[28]SwitchRes: 320 x 240 @ 60p-> 91.33 Custom Modeline
[29]SwitchRes: 320 x 256 @ 58p-> 85.50 Custom Modeline
[30]SwitchRes: 320 x 448 @ 60i-> 77.00 Custom Modeline
[31]SwitchRes: 320 x 480 @ 60i-> 70.33 Custom Modeline
[32]SwitchRes: 328 x 224 @ 60p-> 95.56 Custom Modeline
[33]SwitchRes: 328 x 256 @ 58p-> 83.06 Custom Modeline
[34]SwitchRes: 336 x 240 @ 60p-> 86.57 Custom Modeline
[35]SwitchRes: 336 x 256 @ 58p-> 80.74 Custom Modeline
[36]SwitchRes: 344 x 240 @ 60p-> 84.36 Custom Modeline
[37]SwitchRes: 344 x 256 @ 58p-> 78.52 Custom Modeline
[38]SwitchRes: 352 x 224 @ 60p-> 88.91 Custom Modeline
[39]SwitchRes: 352 x 240 @ 60p-> 82.24 Custom Modeline
[40]SwitchRes: 352 x 256 @ 58p-> 76.41 Custom Modeline
[41]SwitchRes: 360 x 224 @ 60p-> 86.89 Custom Modeline
[42]SwitchRes: 360 x 240 @ 60p-> 80.22 Custom Modeline
[43]SwitchRes: 368 x 224 @ 60p-> 84.96 Custom Modeline
[44]SwitchRes: 368 x 240 @ 60p-> 78.29 Custom Modeline
[45]SwitchRes: 368 x 256 @ 58p-> 72.46 Custom Modeline
[46]SwitchRes: 368 x 448 @ 60i-> 63.96 Custom Modeline
[47]SwitchRes: 376 x 240 @ 60p-> 76.44 Custom Modeline
[48]SwitchRes: 376 x 256 @ 59p-> 70.61 Custom Modeline
[49]SwitchRes: 376 x 272 @ 55p-> 65.46 Custom Modeline
[50]SwitchRes: 384 x 224 @ 60p-> 81.33 Custom Modeline
[51]SwitchRes: 384 x 240 @ 60p-> 74.67 Custom Modeline
[52]SwitchRes: 384 x 256 @ 58p-> 68.83 Custom Modeline
[53]SwitchRes: 384 x 288 @ 52p-> 59.11 Custom Modeline
[54]SwitchRes: 400 x 224 @ 60p-> 78.00 Custom Modeline
[55]SwitchRes: 400 x 232 @ 60p-> 74.55 Custom Modeline
[56]SwitchRes: 400 x 240 @ 60p-> 71.33 Custom Modeline
[57]SwitchRes: 400 x 248 @ 60p-> 68.32 Custom Modeline
[58]SwitchRes: 400 x 256 @ 59p-> 65.50 Custom Modeline
[59]SwitchRes: 400 x 264 @ 57p-> 62.85 Custom Modeline
[60]SwitchRes: 400 x 272 @ 55p-> 60.35 Custom Modeline
[61]SwitchRes: 400 x 280 @ 54p-> 58.00 Custom Modeline
[62]SwitchRes: 400 x 288 @ 52p-> 55.78 Custom Modeline
[63]SwitchRes: 416 x 224 @ 60p-> 74.92 Custom Modeline
[64]SwitchRes: 416 x 256 @ 58p-> 62.42 Custom Modeline
[65]SwitchRes: 432 x 224 @ 60p-> 72.07 Custom Modeline
[66]SwitchRes: 432 x 240 @ 60p-> 65.41 Custom Modeline
[67]SwitchRes: 432 x 248 @ 60p-> 62.40 Custom Modeline
[68]SwitchRes: 432 x 256 @ 58p-> 59.57 Custom Modeline
[69]SwitchRes: 432 x 264 @ 57p-> 56.92 Custom Modeline
[70]SwitchRes: 432 x 272 @ 55p-> 54.43 Custom Modeline
[71]SwitchRes: 432 x 280 @ 54p-> 52.07 Custom Modeline
[72]SwitchRes: 448 x 224 @ 60p-> 69.43 Custom Modeline
[73]SwitchRes: 448 x 240 @ 60p-> 62.76 Custom Modeline
[74]SwitchRes: 456 x 232 @ 60p-> 64.73 Custom Modeline
[75]SwitchRes: 456 x 240 @ 60p-> 61.51 Custom Modeline
[76]SwitchRes: 456 x 256 @ 58p-> 55.68 Custom Modeline
[77]SwitchRes: 464 x 224 @ 60p-> 66.97 Custom Modeline
[78]SwitchRes: 464 x 256 @ 59p-> 54.47 Custom Modeline
[79]SwitchRes: 480 x 224 @ 60p-> 64.67 Custom Modeline
[80]SwitchRes: 480 x 240 @ 60p-> 58.00 Custom Modeline
[81]SwitchRes: 480 x 464 @ 60i-> 40.22 Custom Modeline
[82]SwitchRes: 480 x 480 @ 60i-> 37.00 Custom Modeline
[83]SwitchRes: 496 x 224 @ 60p-> 62.52 Custom Modeline
[84]SwitchRes: 496 x 240 @ 60p-> 55.85 Custom Modeline
[85]SwitchRes: 496 x 480 @ 60i-> 34.85 Custom Modeline
[86]SwitchRes: 512 x 224 @ 60p-> 60.50 Custom Modeline
[87]SwitchRes: 512 x 240 @ 60p-> 53.83 Custom Modeline
[88]SwitchRes: 512 x 256 @ 58p-> 48.00 Custom Modeline
[89]SwitchRes: 512 x 288 @ 52p-> 38.28 Custom Modeline
[90]SwitchRes: 512 x 448 @ 60i-> 39.50 Custom Modeline
[91]SwitchRes: 512 x 480 @ 60i-> 32.83 Custom Modeline
[92]SwitchRes: 544 x 256 @ 58p-> 44.32 Custom Modeline
[93]SwitchRes: 544 x 480 @ 60i-> 29.16 Custom Modeline
[94]SwitchRes: 576 x 224 @ 60p-> 53.56 Custom Modeline
[95]SwitchRes: 640 x 240 @ 60p-> 90.33 Custom Modeline
[96]SwitchRes: 640 x 256 @ 58p-> 84.50 Custom Modeline
[97]SwitchRes: 640 x 480 @ 60i-> 69.33 Custom Modeline
[98]SwitchRes: 640 x 480 @ 61i-> 69.33 Custom Modeline
[99]SwitchRes: 640 x 480 @ 62i-> 69.33 Custom Modeline
[100]SwitchRes: 640 x 480 @ 72p-> 89.33 System Modeline
[101]SwitchRes: 640 x 480 @ 75p-> 89.33 System Modeline
[102]SwitchRes: 640 x 480 @ 85p-> 89.33 System Modeline
[103]SwitchRes: 640 x 480 @ 90p-> 89.33 System Modeline
[104]SwitchRes: 640 x 480 @ 100p-> 89.33 System Modeline
[105]SwitchRes: 640 x 480 @ 120p-> 89.33 System Modeline
[106]SwitchRes: 640 x 480 @ 160p-> 89.33 System Modeline
[107]SwitchRes: 640 x 480 @ 200p-> 89.33 System Modeline
[108]SwitchRes: 648 x 240 @ 60p-> 89.10 Custom Modeline
[109]SwitchRes: 664 x 496 @ 59i-> 62.71 Custom Modeline
[110]SwitchRes: 664 x 496 @ 60i-> 62.71 Custom Modeline
[111]SwitchRes: 672 x 224 @ 60p-> 92.24 Custom Modeline
[112]SwitchRes: 672 x 240 @ 60p-> 85.57 Custom Modeline
[113]SwitchRes: 672 x 272 @ 55p-> 74.59 Custom Modeline
[114]SwitchRes: 688 x 512 @ 57i-> 56.52 Custom Modeline
[115]SwitchRes: 688 x 512 @ 58i-> 56.52 Custom Modeline
[116]SwitchRes: 704 x 240 @ 60p-> 81.24 Custom Modeline
[117]SwitchRes: 704 x 272 @ 55p-> 70.26 Custom Modeline
[118]SwitchRes: 704 x 480 @ 60i-> 60.24 Custom Modeline
[119]SwitchRes: 704 x 528 @ 56i-> 51.76 Custom Modeline
[120]SwitchRes: 720 x 480 @ 60i-> 58.22 Custom Modeline
[121]SwitchRes: 728 x 544 @ 54i-> 46.27 Custom Modeline
[122]SwitchRes: 728 x 544 @ 55i-> 46.27 Custom Modeline
[123]SwitchRes: 736 x 272 @ 55p-> 66.31 Custom Modeline
[124]SwitchRes: 768 x 224 @ 60p-> 80.33 Custom Modeline
[125]SwitchRes: 768 x 576 @ 52i-> 37.11 Custom Modeline
[126]SwitchRes: 792 x 592 @ 49i-> 32.48 Custom Modeline
[127]SwitchRes: 792 x 592 @ 50i-> 32.48 Custom Modeline
[128]SwitchRes: 1280 x 240 @ 60p-> 88.33 Custom Modeline
SwitchRes: Index 27/129 modeline DALDTMCRTBCD320X224X0X60 score 98.00 matches
SwitchRes: Got Custom modeline 320x224@59.911082 - DALDTMCRTBCD320X224X0X60:
    "320x224@60" 6.630000 320 336 368 424 224 234 237 261 -HSync -VSync
SwitchRes: Setting modeline registry entry for DALDTMCRTBCD320X224X0X60
SwitchRes: Set Registry mode DALDTMCRTBCD320X224X0X60 with:
SwitchRes: (63047/63026/63047) Modeline 6.470000 320 336 368 424 224 232 235 258
SwitchRes: Setting Option -redraw 0
SwitchRes: Setting Option -rotate
SwitchRes: Setting Option -nosoundsync
SwitchRes: Enabling VSYNC
SwitchRes: Setting Option -nothrottle
SwitchRes: Setting Option -waitvsync
SwitchRes: Setting Option -resolution 320x224@60
Video: Monitor 00010001 = "\\.\DISPLAY1" (primary)
DirectDraw: Using DirectDraw 7
Blitting thread created
winwindow_video_window_create: blit_lock = TRUE
Blitting thread started
window_proc: WM_NCACTIVATE
window_proc: blit_lock = TRUE
DirectDraw: Configuring device GIGABYTE RADEON 9250
DirectDraw: primary surface created: 320x224x32 (R=00FF0000 G=0000FF00 B=000000FF)
DirectDraw: New blit size = 320x224
DirectDraw: blit surface created: 320x224x32 (R=00FF0000 G=0000FF00 B=000000FF)
complete_create: blit_lock = FALSE
window_proc: WM_PAINT
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
RawInput: APIs detected
Input: Adding Mouse #0: Souris à  roulette USB Logitech
Input: Adding Gun #0: Souris à  roulette USB Logitech
Input: Adding Kbd #0: Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2
DirectInput: Using DirectInput 7
Starting Driver Device 'root'
  (missing dependencies; rescheduling)
Starting 68000 'maincpu'
Starting Z80 'audiocpu'
Starting NVRAM 'saveram'
Starting Video Screen 'screen'
Starting Speaker 'lspeaker'
Starting Speaker 'rspeaker'
Starting YM2610 'ymsnd'
Starting NEC uPD4990A 'upd4990a'
Average speed: 97.08% (128 seconds)
Sound: buffer overflows=54 underflows=7
window_proc: WM_DESTROY
Blitting thread ended
Blitting thread destroyed
SwitchRes: Resetting modeline registry entry for DALDTMCRTBCD320X224X0X60
SwitchRes: (63026/63026/63026) Modeline 6.630000 320 336 368 424 224 234 237 261
« Last Edit: January 05, 2012, 05:46:52 pm by Calamity »
White_widow57
« Reply #12 on: January 05, 2012, 04:11:54 pm »
That's a Capcom play system 2 (hyper street fighter 2) who work perfect!
Parsing mame.ini
SwitchRes: Raw limits (59.6294Hz)-> YresMin= 235p, YresMax= 243p(486i)
SwitchRes: Setup monitor limits min=184x224 max=0x486
SwitchRes: Starting with Horizontal freq of 14.461 and Vertical refresh of 59.63
SwitchRes: Increased horizontal frequency from 14.461 to 15.250
SwitchRes: Using 12 lines padding
SwitchRes: # 15.250Khz -> 15.700Khz: ( | Hfreq Change | Vpad +12 lines | )
SwitchRes: # hsf2 [3] 384x224@59.63 15.2651Khz
SwitchRes: ModeLine          "384x224x59.63" 7.693623 384 400 440 504 224 231 234 256 -HSync -VSync
SwitchRes v0.013: [hsf2] (1) horizontal (384x224@59.63)->(384x224@59.63)->(384x224@59.63)
SwitchRes: # hsf2 384x224@59.63 15.2651Khz
[27]SwitchRes: 320 x 224 @ 60p-> 0.00 Custom Modeline
[28]SwitchRes: 320 x 240 @ 60p-> 0.00 Custom Modeline
[29]SwitchRes: 320 x 256 @ 58p-> 0.00 Custom Modeline
[30]SwitchRes: 320 x 448 @ 60i-> 0.00 Custom Modeline
[31]SwitchRes: 320 x 480 @ 60i-> 0.00 Custom Modeline
[32]SwitchRes: 328 x 224 @ 60p-> 0.00 Custom Modeline
[33]SwitchRes: 328 x 256 @ 58p-> 0.00 Custom Modeline
[34]SwitchRes: 336 x 240 @ 60p-> 0.00 Custom Modeline
[35]SwitchRes: 336 x 256 @ 58p-> 0.00 Custom Modeline
[36]SwitchRes: 344 x 240 @ 60p-> 0.00 Custom Modeline
[37]SwitchRes: 344 x 256 @ 58p-> 0.00 Custom Modeline
[38]SwitchRes: 352 x 224 @ 60p-> 0.00 Custom Modeline
[39]SwitchRes: 352 x 240 @ 60p-> 0.00 Custom Modeline
[40]SwitchRes: 352 x 256 @ 58p-> 0.00 Custom Modeline
[41]SwitchRes: 360 x 224 @ 60p-> 0.00 Custom Modeline
[42]SwitchRes: 360 x 240 @ 60p-> 0.00 Custom Modeline
[43]SwitchRes: 368 x 224 @ 60p-> 0.00 Custom Modeline
[44]SwitchRes: 368 x 240 @ 60p-> 0.00 Custom Modeline
[45]SwitchRes: 368 x 256 @ 58p-> 0.00 Custom Modeline
[46]SwitchRes: 368 x 448 @ 60i-> 0.00 Custom Modeline
[47]SwitchRes: 376 x 240 @ 60p-> 0.00 Custom Modeline
[48]SwitchRes: 376 x 256 @ 59p-> 0.00 Custom Modeline
[49]SwitchRes: 376 x 272 @ 55p-> 0.00 Custom Modeline
[50]SwitchRes: 384 x 224 @ 60p-> 98.00 Custom Modeline
[51]SwitchRes: 384 x 240 @ 60p-> 91.33 Custom Modeline
[52]SwitchRes: 384 x 256 @ 58p-> 85.50 Custom Modeline
[53]SwitchRes: 384 x 288 @ 52p-> 75.78 Custom Modeline
[54]SwitchRes: 400 x 224 @ 60p-> 94.00 Custom Modeline
[55]SwitchRes: 400 x 232 @ 60p-> 90.55 Custom Modeline
[56]SwitchRes: 400 x 240 @ 60p-> 87.33 Custom Modeline
[57]SwitchRes: 400 x 248 @ 60p-> 84.32 Custom Modeline
[58]SwitchRes: 400 x 256 @ 59p-> 81.50 Custom Modeline
[59]SwitchRes: 400 x 264 @ 57p-> 78.85 Custom Modeline
[60]SwitchRes: 400 x 272 @ 55p-> 76.35 Custom Modeline
[61]SwitchRes: 400 x 280 @ 54p-> 74.00 Custom Modeline
[62]SwitchRes: 400 x 288 @ 52p-> 71.78 Custom Modeline
[63]SwitchRes: 416 x 224 @ 60p-> 90.31 Custom Modeline
[64]SwitchRes: 416 x 256 @ 58p-> 77.81 Custom Modeline
[65]SwitchRes: 432 x 224 @ 60p-> 86.89 Custom Modeline
[66]SwitchRes: 432 x 240 @ 60p-> 80.22 Custom Modeline
[67]SwitchRes: 432 x 248 @ 60p-> 77.21 Custom Modeline
[68]SwitchRes: 432 x 256 @ 58p-> 74.39 Custom Modeline
[69]SwitchRes: 432 x 264 @ 57p-> 71.74 Custom Modeline
[70]SwitchRes: 432 x 272 @ 55p-> 69.24 Custom Modeline
[71]SwitchRes: 432 x 280 @ 54p-> 66.89 Custom Modeline
[72]SwitchRes: 448 x 224 @ 60p-> 83.71 Custom Modeline
[73]SwitchRes: 448 x 240 @ 60p-> 77.05 Custom Modeline
[74]SwitchRes: 456 x 232 @ 60p-> 78.76 Custom Modeline
[75]SwitchRes: 456 x 240 @ 60p-> 75.54 Custom Modeline
[76]SwitchRes: 456 x 256 @ 58p-> 69.71 Custom Modeline
[77]SwitchRes: 464 x 224 @ 60p-> 80.76 Custom Modeline
[78]SwitchRes: 464 x 256 @ 59p-> 68.26 Custom Modeline
[79]SwitchRes: 480 x 224 @ 60p-> 78.00 Custom Modeline
[80]SwitchRes: 480 x 240 @ 60p-> 71.33 Custom Modeline
[81]SwitchRes: 480 x 464 @ 60i-> 53.55 Custom Modeline
[82]SwitchRes: 480 x 480 @ 60i-> 50.33 Custom Modeline
[83]SwitchRes: 496 x 224 @ 60p-> 75.42 Custom Modeline
[84]SwitchRes: 496 x 240 @ 60p-> 68.75 Custom Modeline
[85]SwitchRes: 496 x 480 @ 60i-> 47.75 Custom Modeline
[86]SwitchRes: 512 x 224 @ 60p-> 73.00 Custom Modeline
[87]SwitchRes: 512 x 240 @ 60p-> 66.33 Custom Modeline
[88]SwitchRes: 512 x 256 @ 58p-> 60.50 Custom Modeline
[89]SwitchRes: 512 x 288 @ 52p-> 50.78 Custom Modeline
[90]SwitchRes: 512 x 448 @ 60i-> 52.00 Custom Modeline
[91]SwitchRes: 512 x 480 @ 60i-> 45.33 Custom Modeline
[92]SwitchRes: 544 x 256 @ 58p-> 56.09 Custom Modeline
[93]SwitchRes: 544 x 480 @ 60i-> 40.92 Custom Modeline
[94]SwitchRes: 576 x 224 @ 60p-> 64.67 Custom Modeline
[95]SwitchRes: 640 x 240 @ 60p-> 51.33 Custom Modeline
[96]SwitchRes: 640 x 256 @ 58p-> 45.50 Custom Modeline
[97]SwitchRes: 640 x 480 @ 60i-> 30.33 Custom Modeline
[98]SwitchRes: 640 x 480 @ 61i-> 30.33 Custom Modeline
[99]SwitchRes: 640 x 480 @ 62i-> 30.33 Custom Modeline
[100]SwitchRes: 640 x 480 @ 72p-> 50.33 System Modeline
[101]SwitchRes: 640 x 480 @ 75p-> 50.33 System Modeline
[102]SwitchRes: 640 x 480 @ 85p-> 50.33 System Modeline
[103]SwitchRes: 640 x 480 @ 90p-> 50.33 System Modeline
[104]SwitchRes: 640 x 480 @ 100p-> 50.33 System Modeline
[105]SwitchRes: 640 x 480 @ 120p-> 50.33 System Modeline
[106]SwitchRes: 640 x 480 @ 160p-> 50.33 System Modeline
[107]SwitchRes: 640 x 480 @ 200p-> 50.33 System Modeline
[108]SwitchRes: 648 x 240 @ 60p-> 50.59 Custom Modeline
[109]SwitchRes: 664 x 496 @ 59i-> 25.15 Custom Modeline
[110]SwitchRes: 664 x 496 @ 60i-> 25.15 Custom Modeline
[111]SwitchRes: 672 x 224 @ 60p-> 55.14 Custom Modeline
[112]SwitchRes: 672 x 240 @ 60p-> 48.48 Custom Modeline
[113]SwitchRes: 672 x 272 @ 55p-> 37.50 Custom Modeline
[114]SwitchRes: 688 x 512 @ 57i-> 20.31 Custom Modeline
[115]SwitchRes: 688 x 512 @ 58i-> 20.31 Custom Modeline
[116]SwitchRes: 704 x 240 @ 60p-> 45.88 Custom Modeline
[117]SwitchRes: 704 x 272 @ 55p-> 34.90 Custom Modeline
[118]SwitchRes: 704 x 480 @ 60i-> 24.88 Custom Modeline
[119]SwitchRes: 704 x 528 @ 56i-> 16.39 Custom Modeline
[120]SwitchRes: 720 x 480 @ 60i-> 23.67 Custom Modeline
[121]SwitchRes: 728 x 544 @ 54i-> 12.10 Custom Modeline
[122]SwitchRes: 728 x 544 @ 55i-> 12.10 Custom Modeline
[123]SwitchRes: 736 x 272 @ 55p-> 32.53 Custom Modeline
[124]SwitchRes: 768 x 224 @ 60p-> 97.00 Custom Modeline
[125]SwitchRes: 768 x 576 @ 52i-> 53.78 Custom Modeline
[126]SwitchRes: 792 x 592 @ 49i-> 48.65 Custom Modeline
[127]SwitchRes: 792 x 592 @ 50i-> 48.65 Custom Modeline
[128]SwitchRes: 1280 x 240 @ 60p-> 79.33 Custom Modeline
SwitchRes: Index 50/129 modeline DALDTMCRTBCD384X224X0X60 score 98.00 matches
SwitchRes: Got Custom modeline 384x224@59.903910 - DALDTMCRTBCD384X224X0X60:
    "384x224@60" 7.880000 384 400 440 504 224 234 237 261 -HSync -VSync
SwitchRes: Setting modeline registry entry for DALDTMCRTBCD384X224X0X60
SwitchRes: Set Registry mode DALDTMCRTBCD384X224X0X60 with:
SwitchRes: (62712/62685/62712) Modeline 7.690000 384 400 440 504 224 231 234 256
SwitchRes: Setting Option -resolution 384x224@60
DirectDraw: primary surface created: 384x224x32 (R=00FF0000 G=0000FF00 B=000000FF)
DirectDraw: New blit size = 384x224
DirectDraw: blit surface created: 384x224x32 (R=00FF0000 G=0000FF00 B=000000FF)
Starting Timer 'scantimer'
Starting EEPROM 'eeprom'
Starting Q-Sound 'qsound'
Average speed: 100.03% (33 seconds)
Sound: buffer overflows=2 underflows=0
SwitchRes: Resetting modeline registry entry for DALDTMCRTBCD384X224X0X60
SwitchRes: (62685/62685/62685) Modeline 7.880000 384 400 440 504 224 234 237 261
« Last Edit: January 05, 2012, 05:48:15 pm by Calamity »
« Reply #13 on: January 05, 2012, 06:14:12 pm »
Hi White_widow,
Now, I think I understand what's happening.
In both cases, neo-geo and capcom, the -soundsync option is being internally disabled because GroovyMAME considers it's not necessary to have it enabled, because the modeline's calculated refresh is close enough to the desired refresh. This behaviour was designed as it is at some point, but now I see it's a problem because it makes impossible for the user to force -soundsync in these situations.
When GroovyMAME disables -soundsync, it's assuming that your CPU is be fast enough to emulate the game. The problem comes when this is not true, as it seems to be your case:
- neogeo: 97.08% -> sound issues
- capcom: 100.03% -> sound ok
For some reason the neogeo games can't get emulated at full speed in your computer. Try to prove this wrong by using regular MAME 0.144 pressing F11 to check the speed.
If it ends up being CPU related, enabling -triplebuffer for those games may help improving performance.
« Last Edit: January 05, 2012, 06:24:43 pm by Calamity »
White_widow57
« Reply #14 on: January 05, 2012, 09:10:33 pm »
Strange that a pentium 4 with 512mo(test with 1go) isn't enough powerfull for neogeo. I must test with Mame .144 with ddraw, hwstretch 0, switchres 1 ?
« Reply #15 on: January 06, 2012, 04:34:25 am »
Yes, same options and: -syncrefresh -resolution0 320x224@60
White_widow57
« Reply #16 on: January 06, 2012, 06:26:22 pm »
I have test and the same result with kof2003, but I will end up believing that it's my computer because with games like kof 98 (smaller roms) it perfect.
« Reply #17 on: January 06, 2012, 06:36:24 pm »
Try kof2003 with GroovyMAME and the -triplebuffer option, it should make a better use of your CPU, at the cost of some scroll glitches.
White_widow57
« Reply #18 on: January 06, 2012, 06:43:58 pm »
Already test and same result, framerate goes from 85% to 98% and sometimes 55%.
caskad
  • Last login:April 02, 2012, 02:48:22 am
« Reply #19 on: January 06, 2012, 07:01:34 pm »
if i remember, pacman slow down too !
P4 can handle it, it's very strange! perhaps upgrade your proc driver?
« Last Edit: January 06, 2012, 07:04:13 pm by caskad »
White_widow57
« Reply #20 on: January 06, 2012, 08:35:47 pm »
I have found an Athlon 64X2 3800+ with 1 go, is it a good choice? Can I use a classic 32bits Xp with the 64bits Athlon?
« Reply #21 on: January 07, 2012, 05:14:05 am »
Pacman's slowdown is of different nature: 288 progressive lines can't refresh at 60.60606 Hz on a standard resolution CRT. Try running it rotated, it should reach 100% for sure.
I dare to say that's more than enough for most games. You can use XP-32 just fine, but if you can get a copy of XP-64 you'll get even better overall performance for MAME.
caskad
« Reply #22 on: January 10, 2012, 01:31:33 am »
Hello,
But pacman must run fine on this kind of proc, even on horizontal right?
Here's is Pacman.txt
frequence = 50.974026 ? normal?
« Reply #23 on: January 10, 2012, 03:50:48 am »
Hello,
Yes it's normal, because you're v-syncing to this video mode:
ModeLine "400x288x50.97" 8.164000 400 416 456 520 288 289 292 308 -HSync -VSync
Enable -triplebuffer for that game and you'll see how it reaches 100%.
White_widow57
« Reply #24 on: February 01, 2012, 04:25:28 pm »
I finaly found an intel dual core 1.6ghz with 1go ddr2 and an Ati x550, I have quickly test with this computer and it seems to be better than with my old configuration. Thanks a lot to Calamity/Caskad/Paradroid.
retrorepair
  • Last login:July 06, 2025, 06:47:43 pm
« Reply #25 on: February 01, 2012, 10:37:28 pm »
I can confirm that with my Phenom X2 550 I've had no such issues with those games.
MAME is what it is and though groovymame and Calamity's drivers will give you better results in a cab than any other version of MAME your PC still needs to be up to spec.
That said if you run vert games in horizontal you are not only changing the resolution you are changing the refresh too so yeah, you might as well be running vanilla MAME since you'll encounter all the problems groovymame and Calamity's drivers are built to overcome.
My arcade racing setup:
My Youtube Channel: http://www.youtube.com/user/RetroRepair
My Twitter: http://twitter.com/retrorepair
dogman91
  • Last login:April 22, 2013, 12:35:24 am
« Reply #26 on: April 12, 2013, 02:25:52 am »
I'm having similar issues... the sound is warping and wobbling and such (pitch shifting) on a constant level with certain games, most prominently Street Fighter II': Champion Edition. Also, after the title screen ends, the demo attract sequence has delayed start of a few seconds (before the character select music plays) versus right away like the original. I've checked with another MAME (MAMEUI) and these issues don't exist there. Thanks for any help.
running 32bit XP, 2.2GHz and 3gb of RAM
« Last Edit: April 12, 2013, 02:28:38 am by dogman91 »
wesbrown18
  • Last login:October 24, 2018, 09:29:23 pm
« Reply #27 on: April 13, 2013, 10:56:09 am »
GroovyMame synchs the sound to the vsync.  If your CPU isn't fast enough to have accurate vsync timing, then the sound is going to be off, as GroovyMame locks to vsync.
What sort of 2.2ghz CPU?  That number by itself is meaningless -- Intel Core?  Core Duo 2?  The architecture makes a huge difference.  Running 64-bit, for example, will increase your speed by as much as 30% for MAME.
For some comparison, my quad-core Llano A8-3870K at 3.0ghz is pushed fairly hard by Street Fighter 2.  I attach a screenshot of Puzzle Bobble running on my cabinet -- 60% of one core.  If you don't have enough head room on a single core to handle the spikes, you're going to hear audio issues.
dogman91
« Reply #28 on: April 13, 2013, 02:13:16 pm »
It's an AMD Athlon 64 Processor 3400+; probably a single core. I will try loading XP 64-bit and see how that goes... thanks for the info.
Spicules
  • Last login:July 29, 2017, 11:40:33 am
« Reply #29 on: May 24, 2013, 01:35:49 am »
I am having this same problem with a AMD 64 3000+ and XP 64, 1GB ram, and Arcadevga 2 (Ati 9200).   I'm seeing 100% or minor, occassional drops to 90+% occassionally.     I feel like I shouldn't be having problems with this rig, despite how anchient it is.  I'm just trying to play 2D games - capcom/ neo geo/ etc.  No 3D.
« Last Edit: May 24, 2013, 02:07:52 am by Spicules »
« Reply #30 on: May 24, 2013, 04:32:58 am »
This is how things are, unfortunately. Modern MAME is one of the most CPU demanding software out there.
Spicules
« Reply #31 on: May 25, 2013, 02:12:42 am »
[/quote]
That's what I was afraid of ... I guess I will simply have to upgrade.
