Author Topic: jamma to monitor question  (Read 4535 times)
gerryirl
  • Last login:November 18, 2012, 06:42:39 am
« on: December 19, 2011, 06:58:13 pm »
Hi
New to the board. I have a CA&G monitor model number VI 2500 . I have a jamma loom bought to connect up buttons pc etc. The connection on the monitor board has 6 pins but the jamma connector has only 5 can there be an adapter bought to connect or have I bought the wrong  loom. I have attached pics as someone might be able to help
Gerry
Jamma connector
monitor imput
grantspain
Re: jamma to monitor question
« Reply #1 on: December 19, 2011, 07:06:43 pm »
use hs(horizontal sync)-white wire
the chassis has the standard connectors found on hantarex monitors
http://www.coin.demon.co.uk/-video.htm#hantarex
6 pin rgb lead
gerryirl
« Reply #2 on: December 19, 2011, 07:16:21 pm »
6 pin rgb lead
Thanks alot for the quick reply.
What do I need to get off that link you posted there that will mkae it work
MTPPC
« Reply #3 on: December 20, 2011, 01:55:39 am »
I'm pretty sure you just tie pins 5 and 6 together on the chassis but someone more knowledgeable than me should confirm this.
http://pinballmd.com/
grantspain
« Reply #4 on: December 20, 2011, 06:13:50 pm »
you can but normally it just uses the h.sync
on that page you need RGB lead (6 way green plug) complete with wires. Used. £4.20 HAN012
gerryirl
« Reply #5 on: December 21, 2011, 07:07:02 pm »
thanks grantspain very much for your help on this, so all I do when I get that lead is join up the wires and leave the vs pin free?
dopkomachine
  • Newbie
  • Last login:March 29, 2012, 01:47:20 pm
« Reply #6 on: March 11, 2012, 12:37:32 pm »
Will a 5 pin jamma connector work on a pc crt vga connector? I have an Ultimate Mortal Kombat 3 arcade and want to get a new monitor. So.... will a standard pc vga monitor work?
many thanks
Brad
BobA
  • What Me Worry?
« Reply #7 on: March 17, 2012, 11:10:37 pm »
No not without and adapter that converts CGA to VGA.
