March 09, 2026, 07:13:52 am
use hs(horizontal sync)-white wirethe chassis has the standard connectors found on hantarex monitorshttp://www.coin.demon.co.uk/-video.htm#hantarex6 pin rgb lead
I'm pretty sure you just tie pins 5 and 6 together on the chassis but someone more knowledgeable than me should confirm this.
Quote from: MTPPC on December 20, 2011, 01:55:39 amI'm pretty sure you just tie pins 5 and 6 together on the chassis but someone more knowledgeable than me should confirm this. you can but normally it just uses the h.syncon that page you need RGB lead (6 way green plug) complete with wires. Used. £4.20 HAN012
