Author Topic: my new Arcade Panel for outrun  (Read 2914 times)
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
« on: December 09, 2011, 11:21:36 am »
Hi
Hello everyone I finally finished the panel that I built for OUTRUN.
 Details on my blog. http://jackiabu.blogspot.com/  ;D
Re: my new Arcade Panel for outrun
« Reply #1 on: December 09, 2011, 12:16:35 pm »
Much improved!  The Ferrari wheel looks right at home in that cab.
jackiabu
« Reply #2 on: December 09, 2011, 01:57:15 pm »
Thanks,  ;D by the way I wanted to ask you if there's a solution for the gear lever had bought. HI / LO
 I have posted in the forum here but like most cases I'm afraid there is no response ...
« Reply #3 on: December 09, 2011, 02:15:10 pm »
The gear lever is wired to your IPAC like any other switch or button.
Making the games work right in MAME isn't so easy though.  :(
See the MAME section of my driving cab info thread linked in my signature.
What version of MAME and roms are you using? (.125, .137, .144 ???)
jackiabu
« Reply #4 on: December 09, 2011, 02:20:43 pm »
my ver is MAMEUE32.0139.
I have already connected to the gear shift IPAC.
 But as you know I had to change twice in HI \ LO weird right?
 By the way if I put one more Micro Switch, this will solve your problem?
« Reply #5 on: December 09, 2011, 02:24:58 pm »
Good News!
I'm using MAME .139 on my cab and have modified it to fix the gear shift.  ;D
PM me your email and I'll send it to you late tonight.
It's just regular MAME though, so no user interface.
(hopefully you have a front-end set up to launch games)
EDIT: The original only had one switch, so adding a 2nd one isn't needed.  It will work like the original.
« Last Edit: December 09, 2011, 02:27:18 pm by BadMouth »
