Author Topic: Cave Games, getting better performace????  (Read 2357 times)
lettuce
  • Make It So!
« on: December 04, 2011, 06:58:04 am »
Am still using MAME 0.143 on my dedicated mame PC, it has a 2.8GHZ AMD sempron cpu, ATI X600 GFX card, 4GB RAM and running GroovyMAME. Deathsmile runs at around 85% speed, was wondering if this was due to GPU or CPU limitation when it comes to these new CAVE games....i know in the past MAME always been about 98% CPU power and 2% GPU is that still the case?
  • Last login:November 28, 2025, 03:34:14 pm
Re: Cave Games, getting better performace????
« Reply #1 on: December 04, 2011, 12:06:14 pm »
64 bit build will increase speed if you have a 64 bit O/S. For sure.
lettuce
  • Make It So!
« Reply #2 on: December 04, 2011, 02:53:00 pm »
Yeah i thought it would. The only reason i asked is on my main PC (i7 4GHZ, ATI 6970 2GB) the game ripps (obviously), so was just thinking if it was either GPU or CPU dependant
shateredsoul1979
  • Last login:December 22, 2011, 01:09:28 pm
« Reply #3 on: December 04, 2011, 08:51:12 pm »
search for slowpoke mame, that's suppose to be a version of mame compiled to run those games faster for older pcs
but, at 4gz you should be fine. I get no ripping on a i7 at 2.8 ghz (or 2.6, can't remember) and a 3.1ghz i3 home pc with a pathetic graphics card.
Try turning off your graphic card enhancements, it may also have to do with your mame settings.  These games are cpu dependent.
lettuce
  • Make It So!
« Reply #4 on: December 05, 2011, 12:12:59 pm »
Well yeah to be fair i think the AMD Sempron is a budget CPU that probably why at 2.8ghz im only getting 85% speed form Deathsmile....i guess now the CAVE driver has been removed from the latest version of mame we wont see any performance enhancements from the CAVE games
