Author Topic: Good LCD monitor for vertical cabinet?  (Read 2475 times)
Crazy Cooter
  • Senator Cooter was heard today telling the entire congressional body to STFU...
  • Last login:August 19, 2025, 11:29:13 pm
« on: December 01, 2011, 11:52:59 pm »
Has anyone found a good LCD for use in a vertical cabinet?  The ones around my house have horrible viewing angles top-to-bottom (which will be side-to-side once it's in the cabinet).  It will need to spin inside a 24" wide cabinet so I'm not looking for a big one.
Blanka
Re: Good LCD monitor for vertical cabinet?
« Reply #1 on: December 02, 2011, 04:02:57 am »
Get the HP LP2065 or similar. They are easy to find second hand, or even new (discontinued in 2010). Use tftcentral.co.uk's panel selector to find other models with the same panel inside. There are some Dell's and Philipses with the same panel inside.
GregD
  • Last login:December 23, 2025, 04:38:08 pm
    • Arcade Nebula
« Reply #2 on: December 02, 2011, 06:56:14 am »
 I just pocked up a Dell 2007FP off of craigslist for $70.  It is an ips panel.  They are out there.
rmusick
  • Last login:November 12, 2017, 09:15:41 pm
« Reply #3 on: December 02, 2011, 09:22:37 am »
Whatever you get make sure it is IPS.  I got one.. Best purchase I ever made. I bought a 20 inch off Ebay earlier this year for about $100
Crazy Cooter
« Reply #4 on: December 02, 2011, 04:55:17 pm »
Is it safe to assume that I will have good viewing angles solely based on the IPS description?  Also, do I need to check them for lag or is that a non-issue with IPS panels?
Blanka
« Reply #5 on: December 03, 2011, 04:32:56 pm »
IPS is quite good for lag. It is the only panel type that can deliver true 16m colours, with lag below 20ms and a below 10ms response time. With PVA you get better blacks, but lag up to 50ms. With TN you get faster response, but bad viewing angles and often a lot of lag (especially the larger panels >24 inch).
Crazy Cooter
« Reply #6 on: December 03, 2011, 10:48:08 pm »
Thanks guys, I've got a some shopping to do.  :cheers:
jekbrown
  • Last login:March 15, 2018, 12:18:58 am
« Reply #7 on: December 04, 2011, 01:15:42 am »
my vert cab is gonna use a Panasonic 32" IPS-panel TV.  I'll use a bezel to hide everything outside the 3:4 viewable area.  These tend to go for $320 on amazon, but every once in awhile they go on sale for $299....that's the time to strike.   :D
