Author Topic: Help with Low Volume- Cocktail J-Pac  (Read 1284 times)
shredso
  • Last login:January 27, 2020, 09:23:27 pm
« on: November 06, 2011, 12:01:09 pm »
I'm working on converting my cocktail 60 in 1 to a MAME setup.  I have most everything working but the sound is super quiet.  I have it turned up in the game and in windows and you can hardly hear it.  It was fine before.  I know I could just use PC speakers and it would probably sound better  but I would like to keep the speaker as is.  Is there a cheap amplifier or something I could use?
BobA
  • What Me Worry?
Re: Help with Low Volume- Cocktail J-Pac
« Reply #1 on: November 06, 2011, 12:25:40 pm »
Here is a small mono amp kit that you can buy.   Amp Kit
Or you can buy a cheap stereo amp and use mono input to drive 1 or 2 speakers on a single channel DX Amp
Ultimately the amp and power supply from a PC set of 2.0 speakers might be cheaper.  Just use your existing speakers.  You might have to use mono to both stereo channels for the speakers to sound right. Or if your speakers are wired together for mono just use 1 channel.
« Last Edit: November 06, 2011, 12:28:27 pm by BobA »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #2 on: November 06, 2011, 12:31:52 pm »
When I build a MAME kit to install in a JAMMA cabinet, I mount everything onto a wood board, including JPac and an small audio amplifier (I picked up a bunch of kits a while back at an electronics discount place for about $5 a piece).
You can see the amp in this pic -- it is the really small board:
EDIT: BobA beat me to it ... he's smart and too damned fast on the links!  ;)
Working: Not Enough
Projects: Too Many
Progress: None
