Author Topic: What will a cap kit fix?  (Read 2108 times)
honkey
  • Last login:December 16, 2015, 02:54:04 pm
« on: November 04, 2011, 01:12:03 pm »
If a monitor turns on but only displays a horizontal line, does that sound like something that just needs a new cap kit? What other problems could it be?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: What will a cap kit fix?
« Reply #1 on: November 04, 2011, 01:17:04 pm »
It might be ... or it could just be a cold solder joint ... or some other stuff ...
I prefer Randy Fromm's stuff, but this isn't bad and is free:
http://www.arcaderepairtips.com/2011/04/07/repairing-monitor-collapse-issues/
Working: Not Enough
Projects: Too Many
Progress: None
  • Last login:January 26, 2026, 07:56:08 pm
« Reply #2 on: November 04, 2011, 02:44:17 pm »
Everything.
Dead power supplies, bad PCBs, misadjusted images, borken joysticks, and marquee lights.
you forgot coin jams and increasing player gaming ability
ids
  • Fighter Captured
« Reply #3 on: November 04, 2011, 03:04:46 pm »
Everything.
not to mention what they've done for my love life   ;)
mgb
  • North East, US
« Reply #4 on: November 04, 2011, 10:19:49 pm »
A cap kit is typically a good start because they're fairly easy and chances are they can use a replacement.
You have a vertical deflection problem. This can be due to certain caps being bad but it can also be due to a bad vertical output transistor or ic.
What kind of monitor
