Author Topic: Groovymame howto  (Read 8611 times)
rexel
  • Last login:January 14, 2012, 01:40:37 am
Groovymame howto
« on: September 24, 2011, 12:29:34 am »
HI
Is there a Groovymame howto??
Iam trying to get things setup but stuck with either going down the soft 15khz path or using groovymame.
But iam stuck on finding out what to do first to get things going.
Cheers
  • Online Online
  • Last login:Today at 11:27:46 am
Re: Groovymame howto
« Reply #1 on: September 24, 2011, 10:14:39 am »
Hi rexel,
Unfortunately there's no 'howto' yet, info exists but is spread. Let us know which video card/monitor/OS you're trying to set up because depending on that you'll need to follow a different path.
retrorepair
  • Last login:July 06, 2025, 06:47:43 pm
« Reply #2 on: September 25, 2011, 01:35:51 pm »
I can give an account of my setup path here, maybe it'll be a similar case for you.
I have a Radeon 2400 HD card, Windows XP x64 and and Nanao MS9 arcade monitor to work with.
First thing I did was download and install Calamity's ATI drivers (Catalyst version 9.3 for my card) and GroovyMAME from the GroovyMAME homepage: http://mame.groovy.org/
Then I installed the ATI drivers and restarted the machine.
Next I unzipped GroovyMAME to a folder on my C drive and configured the VMMaker software also available from the GroovyMAME site. This is done by editing the VMMaker.ini with notepad and I chose "GENERIC" as my monitor type since the default "CUSTOM" setting gave some odd resolutions first time I tried it. I also had to set my dotclock to 7.3 as anything below that did not agree with my GFX card. Apparently 2xxxHD cards and up have this issue, though your mileage may vary. Finally I set up the path to my MAME executable and told the ini to create an XML and read that XML after to generate the resolutions I needed. It then generated the most suitable list of resolutions/refresh rates for my setup (limited to 120) and wrote that info to the registry. I then reset the machine again.
At this point you can use arcade_osd to check the available resolutions (those installed and usable via groovymame) to make sure you can actually use them. No problems here.
Lastly I needed to run the games I wanted to play and made sure they all worked as expected. The only games I had an issue with were the Midway Wolf/Y/T unit games (termintor 2, MK 1,2,3, NBA Jam etc) which would be squashed in the middle of the screen. I simply then made an ini for each game (e.g. mk.ini) in a "ini" subdirectory of my groovymame folder for each game and formatted them like this:
modeline         1
resolution        401x256
This probably isn't ideal for whatever reason but it did work for me and I have no stutter, tearing or pixel deformities on these games. You may need to experiment with different resolutions to get it looking correct.
These games also had another issue where they rocketed at about 450% speed which was fixed (albeit not an ideal solution) by enabling tripplebuffering. This also fixed huge Tekken Tag slowdowns while fighters were moving ingame while still keeping the benefits of the setup.
I hope this helps a bit, I can expand upon any points here if needed.
My arcade racing setup:
My Youtube Channel: http://www.youtube.com/user/RetroRepair
My Twitter: http://twitter.com/retrorepair
rexel
« Reply #3 on: September 25, 2011, 11:39:57 pm »
Hi rexel,
im looking to get started using a p4 with ATI x300, running windows xp sp2 and i would like to hook this upinto an arcade monitor using a Kortek Kt2623M chasis.
Would appreciate any guidance with the setup..
retrorepair
« Reply #4 on: September 26, 2011, 01:17:20 am »
The Kt2623M is 15k right? Just do what I said above.
rexel
« Reply #5 on: September 26, 2011, 06:23:45 am »
do u mean 15khz?
retrorepair
« Reply #6 on: September 26, 2011, 11:47:40 am »
Yes
rexel
« Reply #7 on: December 11, 2011, 10:38:06 pm »
Iam wondering if anyone else would like to contribute with a how-to on groovymame.. ? it would be pretty useful considering there not an official one yet (not that i could find anyway..)
modeline         1
resolution        401x256
