Author Topic: FS:Out of Stock. ZD Encoder Boards with wiring: $14.75 shipped. [USA/MN]  (Read 135361 times)
UPDATE- MARCH 2013 - I am closing shop. Thank you for all your support.
I have an inventory Zero Delay Encoder Boards in stock. They are now improved. All the wires now have the wider .187 inch terminal connectors on the end for better versatility connecting to your arcade parts. The good news is that the price is still at a low 14.75 per board shipped in the US. International is simply the difference in shipping added to the price. Feel free to PM me for a price quote. :D
Now the board has always come with 4 wires for a joystick and 8 wires for buttons, but board is capable of taking up to 12 button wires, and some people have expressed interest in utilizing all wires. I am happy to announce that I now offer an option to purchase the board with 4 joystick wires and 12 button wires! The price for the board with the extra wires is $17.50 after shipping in the US. As with the 14.75 option, international price is only the cost difference in shipping added. PM me for a quote. - For those that have already made a purchase and want extra wires, I will happily send you the additional wires at $3.50 shipped for each set of 4 wires. domestic or international. Just let me know!
Here is the board:
Zero Delay Arcade Control Encoder
The Zero delay is the most cost effective encoder option available. It is plug and play, lag free and very compact. (8.5 cm X 3.5 cm X 1 cm)
The Zero Delay board comes with:
  • USB Cable
  • 4 Wire sets for joystick.
  • 8 Wire sets for 8 buttons, or 12 wire sets if you want to upgrade.
  • Instructions
The Zero Delay also has these additional features for those that wish to utilize them:
  • Hat switch for secondary joystick, POV controls, or console style gaming controls
  • Autofire option
  • Rapidfire option
  • 5 pin port for Japanese (Sanwa) ports
FAQ:
Q: What method does this board encode the controls?
A: Controls are encoded like a gamepad.
Q: How do I hook up the controls?
A: one end of the wire plugs right into the board port, the other end connectors into the joystick or button switch. The included instructions will let you know what each port maps to. The terminals will fit up to .187 size terminals, which is the most common size for arcade switches. If you have switches that take the larger .25 terminals, you can either soldier on the terminals or crimp on new connectors.
Q: Have these boards been inspected?
A: Each board was given QC initials. Also, I have personally plugged every board in my PC and determined that it registers correctly with the PC. I have also visually inspected all the wires and boards.
Q: How should payment be made?
A: I am set up for Paypal. If you are interested in purchasing, send me a PM.
Q: Is this compatible with PS3?
A: I have had a chance to try it out, yes, it worked great. It should be great for fighters! Just bear in mind that there is no Home button. If you need an encoder with a PS3 Home button, check out my ZD Rematch!
Q: Does it need special software?
A: It uses the standard joystick drivers on the computer, no software needed!
Thank you!!
« Last Edit: March 19, 2013, 04:30:09 pm by Vigo »
seantk421
  • Last login:April 20, 2014, 11:24:54 pm
Re: FS: Arcade Control Encoder Boards with wiring: $14.75 shipped. [USA/MN]
« Reply #1 on: September 22, 2011, 06:56:44 am »
Pm sent
jmike
« Reply #2 on: September 22, 2011, 07:07:43 am »
These look very familiar. Do you know if it's compatible with the PS3 and does it have "start" and "select"?
Thanks.
Sjaak
« Reply #3 on: September 22, 2011, 07:16:40 am »
PM sent
jmike
« Reply #4 on: September 22, 2011, 08:21:02 am »
PM sent
sham69
  • Last login:June 12, 2015, 06:03:44 am
« Reply #5 on: September 22, 2011, 08:24:33 am »
Can these be programmed for mame default?
Is there mapping software etc?
Thanks.
Sham.
t3design
  • Last login:January 02, 2026, 12:17:49 pm
  • Orange Power! Go Pokes!
    • Cowboy Arcade Project
« Reply #6 on: September 22, 2011, 09:11:28 am »
I may be asking the same question as directly above...
Getting ready to build a cabinet for a friend on the cheap. Will these work in MAME on a standard PC?
Cowboy Arcade Project ThreadCowboy Arcade Project Website
If you are an obsessive/compulsive pyromaniac, you better make sure you wear flame retardant pajamas.
jmike
« Reply #7 on: September 22, 2011, 09:43:10 am »
Thanks PBJ
              I've been trying to find that thread all morning.
« Reply #8 on: September 22, 2011, 10:24:28 am »
Does anyone know what type of connector that is on the board end of the wires (the white one)? Does it have a specific name?
« Reply #9 on: September 22, 2011, 10:36:56 am »
Sorry, its a crazy busy morning for me. I will reply to pm's soon.  :)
There are button slots for select and start. It comes with enough buttons to cover a standard "dual shock" style controller. While the board can be wired up for up to 12 buttons, it only comes with enough wires to cover 8 buttons. Unfortunately, that's how they just come. You can solder for the the remaining slots, but like yotsuya I am also trying to find out what kind of connector is being used. If anyone knows, it would be greatly appreciated.
Also, I have not tried on the PS3. I have a PS3, so I will try hooking it up tonight. I will post my results.  :cheers:
« Reply #10 on: September 22, 2011, 10:52:10 am »
PBJ gets a star! That looks to be the connector.
Here is the first website I checked:
http://www.pololu.com/catalog/product/1164
$0.75 per cable. I will check into ordering a batch as well.
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #11 on: September 22, 2011, 12:08:42 pm »
Seems to me you could use one of these to make a 2 player classic cab:
P1 - joy
p2 - POV hat
3 buttons per
1 start per
1 coin per
plus an exit button - that's all the inputs and 11 buttons...
Donkbaca
« Reply #12 on: September 22, 2011, 12:24:28 pm »
Well, you could do a 2player, 3 button panel?
1pjoy - joy
2pjoy - 4 buttons
3 buttons per player
2 coin
2 start
1 exit
Wouldn't that work?
« Reply #13 on: September 22, 2011, 12:31:50 pm »
Pretty sure they're JST XH 2-pin connectors.  They're used on battery packs.
James rocks!  :cheers:
« Reply #14 on: September 22, 2011, 01:45:11 pm »
1pjoy - joy
2pjoy - 4 buttons
2 coin
2 start
1 exit
Wouldn't that work?
If you are wiring the POV Hat mode as a shift function button, then I think you could do that.
Without the hat switch it would be 3 buttons short. (4 buttons for 2nd joy, 6 for game buttons, 4 for select and start buttons and 1 exit button needed)
If I were doing it, I would give P2 the dedicated joystick, then give P1 a real coin and start button. Player two would just need to hit the hat switch and press left on the joystick for coin and right for start. Then you could make hat switch and up as the game exit.
« Reply #15 on: September 23, 2011, 01:24:24 pm »
I know I promised to try this on a PS3 last night, sorry I haven't had a chance to try it out yet. I will make time tonight.  8)
« Reply #16 on: September 23, 2011, 01:27:34 pm »
You can send one to me, I'll test it on a PS3...   >:D
« Reply #17 on: September 23, 2011, 02:27:35 pm »
For $14.75, I'd be happy to.  ;D
PCMedics
  • Last login:September 22, 2013, 12:28:12 am
« Reply #18 on: September 23, 2011, 11:23:36 pm »
Great seller replied fast, set up payment simply with paypal . Looking forward to trying out a couple.
« Reply #19 on: September 24, 2011, 12:33:49 am »
Thanks, PCMedics! I will have your order in the mail tomorrow as well!  :)
« Reply #20 on: September 24, 2011, 12:38:38 am »
OK, good news! I have tried this out with my PS3, and it worked great!  :woot
I was finally kicking butt in Tekken tonight! Maybe I will make myself a PS3 CP with one of these.
« Last Edit: September 24, 2011, 01:40:12 am by Vigo »
Donkey_Kong
    • CNC Machines
« Reply #21 on: September 24, 2011, 01:27:21 pm »
Payment sent. Thanks Vigo!
« Reply #22 on: September 24, 2011, 04:59:33 pm »
Got mine today. Ordered late Wednesday night. Very fast! Thanks Vigo! :applaud:
« Reply #23 on: September 25, 2011, 05:40:21 am »
Thanks, Nephasth! Let me know if any questions come up about the boards!  :cheers:
SNAAKE
  • Trade Count: (+29)
« Reply #24 on: September 25, 2011, 08:54:35 am »
anybody know if this works with it?? I need one of your encoder(maybe more after I have the 1st one) either way. just wondering.
http://www.ebay.com/itm/Computer-PC-USB-XBOX-Adapter-Cable-FEMALE-NEW-/200583224220?pt=Video_Games_Accessories&hash=item2eb3b11b9c
jmike
« Reply #25 on: September 26, 2011, 11:15:19 am »
Awesome. PM sent.
jggamer
  • Last login:February 16, 2012, 08:40:25 pm
« Reply #26 on: September 27, 2011, 01:04:12 am »
PM Sent.. ;D
« Reply #27 on: September 27, 2011, 03:19:04 am »
Mine showed up today, Vigo! Nicely packed, with instructions, and about 18 days quicker than it was getting them from Hong King! thanks!
PCMedics
« Reply #28 on: September 27, 2011, 01:37:30 pm »
I received mine today expertly packaged and arrive quickly. Thanks Vigo
Sjaak
« Reply #29 on: September 27, 2011, 02:16:11 pm »
I live in the Netherlands (that's in Europe ;) ) Payment 9/22, received 9/27.
Vigo, you should get an award for packaging!
« Reply #30 on: September 27, 2011, 04:34:38 pm »
Wonderful! Thanks, guys! I'm really glad you got your orders quickly!  :cheers:
Oh, FYI - 10 left.  :afro:
jmike
« Reply #31 on: September 27, 2011, 05:37:10 pm »
10 left  :cry:
Would you be ordering more? I just placed my order so I haven't had time to use one for a PS3 fight stick.
« Reply #32 on: September 28, 2011, 12:26:55 pm »
I am considering buying more. I am looking to see how the rest of this batch sells, and what kind of feedback I get on the encoder first.
I am also looking into other products that would interest people if I could get them cheaper from overseas. Suggestions would be welcome. I already looked into finding a cheaper spinner from overseas, but after talking to some arcade enthusiasts in China, I have come to the conclusion that they rarely use them or make them to begin with.
« Reply #33 on: September 28, 2011, 12:51:29 pm »
See if you can talk them into making a 25 inch 4:3 LCD. :)
« Reply #34 on: September 28, 2011, 01:24:00 pm »
Buy some of the spinners anyway.  I'm getting sick of my mouse hack.
What's the issue?
seantk421
« Reply #35 on: September 28, 2011, 09:49:19 pm »
Got mine in the mail today.  Shipping was fast and packaging is perfect.  Thanks Vigo!  The board looks nice from what I can tell.  It does turn out that it doesn't work with the x-arcade switches so I'll need to go get the other connectors.  Does anyone know what type of connectors they use?
seantk421
« Reply #36 on: September 28, 2011, 10:51:34 pm »
Just gave soldering the connectors a try and it worked like a charm.  Thanks!  Vigo, do you have anymore left?
« Reply #37 on: September 29, 2011, 01:37:28 am »
I'm glad soldering worked well.  :) Yep, I have 7 encoders left.
« Reply #38 on: September 29, 2011, 10:26:11 am »
I'd really love to find something, and I am seriously looking into it. I understand why some would want an $80-150 spinner, but there has got to be some alternative out there. It's a metal shaft with an encoder. A ball mouse has a more similar encoder board, and they can be found at the dollar store.
« Reply #39 on: September 29, 2011, 10:26:55 am »
Vigo!  Have anymore?  Check pm, please...   ;D
