Author Topic: remove click from switches all together!  (Read 3362 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: August 31, 2011, 01:27:36 am »
I think ive found a way to do it!  replace the metal pad inside the switch with a silicone conductive pad from an old gamepad button/dpad membrane.  Tried it on a switch tonight and its dead quiet but only sees 1/3 pushes :(  I think i need to make it a bit thinner as im getting 2.33ohms resistance (i think it sould be 0)
Will experiment more tomorrow
newmanfamilyvlogs
    • Newman Family Vlogs
Re: remove click from switches all together!
« Reply #1 on: August 31, 2011, 06:35:15 am »
I wonder if you could find a conductive pad like that where the resistance varied with pressure over a large enough span such that you could treat it like a 1D analog input (using a uhid or something). Then you could use regular push buttons like gas/break pedals, but still have the regular pushbutton action for everything else.
Hoopz
  • Last login:Today at 07:08:07 am
  • Intellivision Rocks!
« Reply #2 on: August 31, 2011, 08:42:57 am »
You may find something useful in this thread:
http://forum.arcadecontrols.com/index.php?topic=72400.0
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #3 on: August 31, 2011, 10:46:40 am »
How 'bout just use leaf switches?
Franco B
« Reply #4 on: August 31, 2011, 03:20:48 pm »
Seimitsus FTW.  :cheers:
tbombaci
  • Last login:October 31, 2024, 01:32:56 pm
« Reply #5 on: August 31, 2011, 03:30:14 pm »
« Reply #6 on: August 31, 2011, 04:48:34 pm »
+1
Leafs are completely silent, but not available for your modern joysticks.
But, I recently got some Zippy switches that are significantly softer and lighter than cherry switches. Under the CP they are virtually silent. I believe all the usually suspects (vendors) carry them, groovygamegear (though re-branded with Groovy, they look very similar to Zippy's), and Paradise Arcade.
I put them in a couple Seimitsu's and they have a very awesome feel. With a sub-20gram actuation force, my joysticks have a little less actuation resistance, accompanied with a round gate they make for a great shooter/shmup experience.
Next I'm going to put them in some JLF's and see how they feel for Versus Fighting games.
equlizer
« Reply #7 on: September 01, 2011, 12:58:48 am »
I ordered 10 of the GGG micro leaf switches. I sure hope they replace the ones in the happ buttons.  Everyone said they did ???
wweumina
  • Last login:August 30, 2022, 04:56:31 am
« Reply #8 on: September 01, 2011, 02:38:16 am »
You're fine.  The micro-leaf is still a switch based joystick and the comments above about leafs not fitting modern joysticks don't apply.
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
« Reply #9 on: September 02, 2011, 10:20:09 pm »
I've used both the paper pad as mentioned in the link above and leaf switches that fit great in most cherry switch applications and both work well.  One or the other should work for your application.
Bringing to life a child's imagination.
