Author Topic: Hiding Windows 7 Completely - DONE (new video added 22/8)  (Read 112510 times)
Banacek
  • Last login:November 08, 2017, 05:01:31 pm
Re: Hiding Windows 7 Completely - DONE (new video added 22/8)
« Reply #40 on: January 01, 2013, 11:56:31 pm »
Thanks for the walkthrough. I have everything working except for the boot animation replacement. It says that it worked, then Windows shows the default boot animation. Any ideas?
Bender
« Reply #41 on: January 29, 2013, 09:09:55 am »
Is this option in windows 7?
I find it invaluable for finding the single pixel cursor
EDIT: Yes it is still in Windows 7. I set a shifted button to be CTRL and i can easily find the cursor
« Last Edit: March 04, 2013, 01:00:33 pm by Bender »
Bender
« Reply #42 on: March 04, 2013, 03:45:03 pm »
I finally got around to upgrading to windows 7
So time to use the great info on BYOAC yet again!
Everything worked great!
I was able to take permission of the system files and move them without having to go through Linux live CD (which is great cause I couldn't get that to work)
First I made copies to the desktop edited them in Resource Hacker
Then I just right-Clicked the individual files in there original location one at a time selected take permission and changed the names to back them up.
Then dragged the new ones I edited in from the desktop
Reboot and good to go
I'm referring to these files from step 4-9
C:\Windows\System32\imageres.dll
C:\Windows\System32\en-US\winlogon.exe.mui   (the directory may be different if you didn't install as English-US (en-US - get it?)
C:\Windows\Branding\Basebrd\basebrd.dll
wweumina, thanks so much for the great tutorial! :cheers: :cheers:
« Last Edit: March 04, 2013, 03:48:37 pm by Bender »
JRoz
  • Last login:February 14, 2024, 07:33:43 am
« Reply #43 on: March 09, 2013, 07:45:13 pm »
Hey All,
I'm having issues with Step 9.  I try to drag the files back to the systems32 folders and get the access denied error, so I installed a copy of Linux Mint and am in it now.  I dont have access to any of my windows 7 folders or files...can someone help me out with this?  Only piece i'm struggling with
thanks
Jason
EDIT:  Just figured it out...instead of getting linux and doing it that way..I just booted into safe mode and dragged the files over...all set!
« Last Edit: March 09, 2013, 07:57:14 pm by JRoz »
Bender
« Reply #44 on: March 13, 2013, 07:44:51 pm »
Had a ---smurfette--- of a time removing the "welcome" and "shutting Down..." Text
It appears that if you have Win 7 WITHOUT the service pack you need to disable something called "Windows Gadget Platform"
instructions here
http://www.sevenforums.com/tutorials/126747-logging-off-text-message-change.html
abispac
  • Last login:Yesterday at 11:03:14 pm
« Reply #45 on: July 25, 2013, 01:09:39 pm »
can someone pin this please?
Aceinthesky2002
  • Last login:December 23, 2013, 04:21:32 pm
« Reply #46 on: August 03, 2013, 07:01:44 pm »
Hey guys I have figured out everything except this step. The mouse pointer is gone everywhere except for about 2 seconds after the windows boot screen and before the windows login screen. I think I might not be doing the step below correctly. There is also a spinning circle next to the pointer for that same spilt second.
This is the step from the page 1 instructions of this thread:
You may also need to add an extra key (as extended string) for 'Busy'.
« Last Edit: August 03, 2013, 07:05:33 pm by Aceinthesky2002 »
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« Reply #47 on: August 04, 2013, 01:24:37 pm »
what about gameex (instant sheller) that's what I'm using works great
« Last Edit: August 04, 2013, 01:33:59 pm by Caparo8bit »
MotorHedJr
  • Last login:October 06, 2015, 06:25:45 am
  • Christmas everyday!!!
« Reply #48 on: March 23, 2014, 08:21:06 pm »
Hey Wweumina, and all,
Great job on the tutorial! Thanks!
I’m using Windows 7 on a 64 bit mobo.
I’ve followed your tutorial verbatim; Windozes 7 is hidden fine and everything looks great. One issue I’m still having problems with is I just can’t get the front end (AdvMENU 2.6) to launch… Spent all weekend on it; any help is greatly appreciated, thanks!
Here is the error:
Error process exited with status 1.
Error generating the ‘advmame’ information file with –listxml and
-listinfo.
Emulator
‘C:\AdvMAME\advancemame-1.2-windows-x86\advmame.exe’
Without game information, ignoring it.
No working emulator found. Adjust the ‘emulator’ options in your
configuration file. These options are documented in the ‘advmenu.txt’ file.
Then it does this:
Updating the ‘advmame’ information file
‘c\windows\system32\advmame.xml’.
‘c\windows\system32\advmame.lst’.
And  (error 1) YES I did that… I checked and I can launch AdvMENU from the desktop shortcut (and launch AdvMAME games) on the desktop just fine. Quadruple checked the .rc – they’re OK… Seems like the regedit winlogon key gets angry. And just won’t launch AdvMENU… I can’t understand why????
And (error 2) Those damn files were never created in that respective folder WTF?
Please guys so frustrated any help/ideas??? Thanks so much!!!!!!!!!!!!!
Benzinbruder
  • Last login:January 10, 2016, 07:38:04 am
  • I want to build my own arcade cabinet!
« Reply #49 on: August 15, 2014, 04:41:40 am »
I have got a problem shelling Hyperspin as well.
I have added the registry key as described in the first post and everything seems to work at first.
However, a few second after Hyperspin loaded the menu loses focus. I have to alt-tab then to bring the focus back. From that moment on everything works fine, but the windows desktop loads and I can alt-tab to it anytime.
What am I doing wrong? Why is the desktop and explorer.exe even loaded at all?
Bartezz
  • Newbie
  • Last login:September 01, 2014, 03:10:14 pm
  • Life is good
« Reply #50 on: September 01, 2014, 02:56:45 pm »
Hello,
How can i hide "plaise wait for user profile service..." and "plais wait for the system event notification service...".
I can not find it.
ihve it on startup en on schutdow of my computer (windows 7)
mmg1design
  • Last login:July 30, 2016, 03:22:09 pm
    • My Website
« Reply #51 on: September 12, 2014, 10:11:41 pm »
Your tutorial makes these changes really easy to follow. Thank You!
I did all the changes except the cursor replacement and I also made a custom boot animation with a red ball top joystick and "classic arcade" text.
[youtube] [/youtube]
If anyone wants to use this animation, download the zip file from my blog.
http://www.mmg1.info/blog/boot-animation-arcade-classics-widescreen/
Instruction Cards for Street fighter games and other fighting genre. Download Here
bulbousbeard
  • Last login:August 25, 2015, 11:58:25 pm
« Reply #52 on: December 22, 2014, 11:12:33 pm »
I've been reading this, and it inspired me to improve my frontend. I updated Big Blue so that when the program starts, it hides the Windows cursors for you, and when you exit Big Blue, it restores the cursors for you. This means no downloading of separate .cur files, no manual setting tweaking, and instantly getting your cursors back when you exit the frontend. Completely brain dead.
This doesn't hide the cursor when Windows loads, but I personally don't care about the start up. What always bothered me was seeing the loading cursor when you launch a game and MAME's loading.
paigeoliver
  • Awesome face!
« Reply #53 on: December 22, 2014, 11:20:41 pm »
Maybe I am asking the wrong question here, but if you are booting from a PC why do you not just delay the monitor from starting up or even easier add a switch near your CP.
Also you can boot your PC in Barts PE it really isn't that difficult.
Real arcade games that run on windows never seem to make any efforts to hide it, they just boot to windows and then load the game.
jaharr01
« Reply #54 on: December 22, 2014, 11:26:56 pm »
All this talk about hiding mouse cursor and putting the arrow down to one pixel. Would it not be much easier to unplug the mouse or rig up a switch to the USB wire turning off the data, or 5V. If you needed to do housekeeping or maintenance you flip a turn it on hit Ctrl Alt Delete and temporarily turn off shell. You wouldn't be scrambling to find the mouse. I did that with my XBMC. I had a logitech all in one keyboard, I just flipped off the switch on the keyboard. and I used a remote most of the time.Then flipped it on when I needed it. Just a thought.
bulbousbeard
« Reply #55 on: December 22, 2014, 11:31:47 pm »
Unplugging the mouse doesn't work. If you unplug your mouse, and you launch a big game in MAME from any frontend, you'll see the hourglass dead center in the screen while the program's starting up.
csnow
  • Last login:March 07, 2023, 10:30:54 am
« Reply #56 on: December 25, 2014, 01:04:45 pm »
How do you guys handle shut downs?  If you hard power down the cabinet, the next time Windows boots it will ask to start normal or safe mode.  I am in the planning phase of building a cabinet so I would like to have these items ironed out at the onset of the build.
JDFan
« Reply #57 on: December 25, 2014, 01:09:53 pm »
In power options - system settings - you set the computer to shut down on the power button press so that pressing the power button shuts down the system properly rather than hard shut down.
bulbousbeard
« Reply #58 on: December 25, 2014, 08:24:35 pm »
Why not just use a frontend that can shutdown Windows itself?
keilmillerjr
  • Web Developer.
« Reply #59 on: December 26, 2014, 07:44:20 am »
It's convient to have the machine also start with the same button. Smart strip.
byancey
  • Last login:October 07, 2023, 03:11:17 pm
« Reply #60 on: January 01, 2015, 02:16:37 pm »
9. Copy the hacked resources back in to windows.
For this step you need to copy the updated files from the desktop back to their original locations.  It seems it is sometimes possible to do this inside Windows but I kept getting file protection errors so the easy way is to get a live linux cd and reboot your computer from this.  (I recommend Linux Mint if you are unfamiliar with Linux).  Go to the file explorer in linux and copy the new verison of the file to the original location.  Make a backup of the original file first and call it something that you'll remember (eg. imageres_BACK.dll).
Here's a quick tip for step 9 that may save some the trouble of setting up and booting to a Linux live CD.  Windows won't allow you to overwrite system files that are in use, however, it will allow you to rename them.  I was able to replace each of the 3 system files as follows.
  • Open a command prompt as administrator
  • ren C:\Windows\System32\imageres.dll C:\Windows\System32\imageres.dll.old
  • copy C:\Users\[username]\Desktop\ResourceMods\imageres.dll C:\Windows\System32\imageres.dll
  • repeat for other files
Your newly copied files will be loaded on the next reboot.
« Last Edit: January 01, 2015, 02:20:40 pm by byancey »
haynor666
  • retro maniac
« Reply #61 on: January 02, 2015, 05:34:05 am »
Above options works but still I don't know how to force UEFI and windows 7 boot at 640x480.
system01
  • Last login:March 04, 2023, 08:06:55 pm
  • System Idle Processes are the Devil's Playthings
« Reply #62 on: March 18, 2015, 08:52:12 pm »
Big thanks to OP!
I've done this a couple times and I always have to look up all the steps somewhere.  7 is a ---smurfette---.  You can save a lot of time using instantsheller for the cursors and shelling, and no, you don't need Linux.  Just use DOS and copy/ren like byancey said.  I do this on Tiny7, which makes it a little more difficult, but the steps are similar.
I use one button for power up & down, both on arcade and HTPC.  Just keep the default of single press=shutdown feature and it, uh, behaves just like a regular PC (because it is).  Gotta give a nod to bender though, never thought of using the mouse-sonar.
What I do to get back into windows:  Most FEs have a "run on exit" command.  Point this to explorer.exe.  Whenever I do maintenance, I plug in a keyboard, Alt-F4 to close FE, and explorer starts.  If you want cursors back, make a shortcut for instantsheller and hit the bigass "Undo".  When you're done, hit the power button to shutdown and once more to fire it back up.  Done.
The Big Man
  • Last login:April 13, 2015, 01:00:05 pm
« Reply #63 on: April 13, 2015, 12:16:59 pm »
I know this thread is a couple years old but I thought I'd chance my arm.
Ive followed this guide and on the whole it works fairly well apart from one tiny little problem, since deleting the bitmaps in the imageres file and editing the wininit.exe.mui to get rid of the shutdown text on my logoff/shutdown screen I get a spinning circle and the message "PLEASE WAIT", and I cannot find any reference to these in any of the files that reshacker can edit, have I done something wrong?
As a result of editing the winlogon.exe.mui file I have managed to remove the text from the welcome screen so I don't think its a case of me not knowing what I am doing, I assume that its possible to remove the text from the shutdown screen as the video in the guide seems to show.
Ive included a vid of my machine booting up and shutting down and if you squint real hard you can see the PLEASE WAIT and spinning circle on the shutdown screen, any help with this would be greatly appreciated.
Phreakwars
  • Last login:December 07, 2025, 07:04:20 pm
  • Waka-Waka
    • forum.arcadecontrols.com/index.php/topic,146325.0.html
    • My Facebook Page
« Reply #64 on: July 15, 2015, 04:34:18 am »
Just wanted to chime in here on this topic a bit. I'm coming out of arcade cabinet building retirement after about 12 years to work on a whole new project for my son. My very first arcade that I made was an old Player's Choice 10 cabinet that I converted into a MAME cabinet with a new customized control board and the then rarely heard of iPac... loved that machine. Ran it on Windows 98 with ArcadeOS.. ah the good ole' days.. Hiding windows was MUCH MUCH simpler then.. but anyways. After researching a bit on how I wanted to do it, I decided to buy a cocktail kit from recroommasters.com and have at it like that. Chose the ASUS A58M-E motherboard with an A-6 5400 CPU. Mainly because it was a great buy when you get it as a refurb off of newegg, and, having used that same board for a PC build I did for a kid at work, I know I can use the  MyLogo2 software on it to replace the BIOS boot screen. I also use the programs "TweaksLogon" and "Windows 7 boot updater" to change the startup animation and the login/shutting down screens. Glad I found this topic, the tips should help me with a few more tweaks like hiding the cursor, and etc.. thanks.. appreciate it... BUT ANYWAYS..
As for being able to work on the computer, seeing the cursor, etc.. I have THAT taken care of as well. I plan on keeping the access door side for the cocktail cabinet against the wall and locked up, but I will STILL be able to perform any maintenance/updating roms, etc without having to scoot the cabinet back and opening the door, or installing any external USB port, or any other nonsense like that.... My solution?? A nifty little program called "Ultra VNC" and a TP-LINK TL-WN722N.
When you are viewing the screen remotely, you don't need to worry about the cursor being visible, or about changing setting and rebooting or this or that. You simply send the kill commands to the FE, then send the commands to start the explorer.exe shell.
And, since you have file transfer capabilities as well, you can actually send/rename/delete/etc  files without using the explorer.exe shell. Of course, this will require that you have a wireless router... but then, who doesn't have one of those these days??
Another option is to use TeamViewer, which is my preferred software for all the other computers in my house and owned by friends, but for something like an arcade FE, I find Ultra VNC to be a bit more discrete and unobtrusive. Team Viewer, when you disconnect, will pop up a "thanks for using me blah blah blah" dialog, Ultra VNC doesn't do that.
PS, Here's a sample of what the bootup animation will look like... It's how my son wanted it
« Last Edit: July 15, 2015, 08:36:33 am by DeLuSioNal29 »
Phreakwars
  • Waka-Waka
    • My Facebook Page
« Reply #65 on: July 26, 2015, 09:10:03 pm »
Yep, I'm getting that same "SHUTTING DOWN" on shutdown as well.
Edit: Quick question as well. I have my PC booting up vertically instead of horizontal, is there a way to change the bootup animation screen to display the same way? I can probably flip the animation itself in a paint program, but the words still show up horizontal.
« Last Edit: July 26, 2015, 10:04:13 pm by Phreakwars »
Phreakwars
  • Waka-Waka
    • My Facebook Page
« Reply #66 on: July 26, 2015, 09:49:55 pm »
Here's a short video showing what's happening so far:
abispac
« Reply #67 on: July 27, 2015, 12:18:43 am »
I just completed these steps but I was unable to get rid of my "Welcome" text and also my "Shutting Down..." text.  To fix it:
WELCOME TEXT - After following the instructions above to edit and replace winlogo.exe.mui you need to do the following.
1) Open a elevated command prompt.
2) In the command prompt, type mcbuilder and press Enter.
3) When the command window closes, restart the computer.
SHUTTING DOWN TEXT - The "Shutting Down..." text is in a different file called "wininit.exe.mui".  After modifying you need to run mcbuilder as well.
Also, HUGE thanks to wweumina!  I found you on YouTube first but there was no instructions.  Thankfully I found your post here, worked great!
Phreakwars
  • Waka-Waka
    • My Facebook Page
« Reply #68 on: July 27, 2015, 03:13:33 am »
Followed those steps,and now I'm getting a "PLEASE WAIT" massage instead of saying "SHUTTING DOWN".
abispac
« Reply #69 on: July 29, 2015, 12:26:12 am »
Then you might be doing it wrong.
Phreakwars
  • Waka-Waka
    • My Facebook Page
« Reply #70 on: July 29, 2015, 02:25:03 am »
Nope, I have searched the net and discovered others have similar probs.
holaplaneta
  • Last login:June 09, 2023, 09:23:54 pm
« Reply #71 on: November 22, 2015, 06:55:41 pm »
Did you find a way to make it work?
rablack97
« Reply #72 on: November 22, 2015, 10:14:50 pm »
Check out the updated tutorial in the sticky, the issue was resolved there.
Jonny G
  • Last login:March 04, 2024, 05:59:46 pm
« Reply #73 on: February 04, 2016, 05:21:50 am »
Thanks for the tutorial! I couldn't get any of it to work and had to resort to using InstantSheller but still, there's not many guides on how to even attempt this out there, definitely lead me in the right direction.
I'm still trying to get my boot animation set to the space invader one you posted. I run Win 7 Boot Updater 2 as admin, go through the process as described and it tell me all the files were updated as required, but there's still no sign of it on boot.
I'm using Win7 x64 SP1 and have tried editing both the C:\windows\bootmgr file, and the one on hidden partition, both with no success. Has anyone managed to figure this out?
