Author Topic: How do I correct a drilling error  (Read 3187 times)
notroubleclubber
  • Last login:October 07, 2023, 04:26:25 pm
« on: August 19, 2011, 12:38:27 pm »
Ive been stupid and drilled a couple of button holes in the wrong place.
I wanted to put my coin buttons on the front of the cab but they won't fit because the connectors hit the othe buttons inside.
What would be the best way to fix this:
1. Fill and then recover with vinyl (the area is only about 4" by 15")
I can't just fill and paint as it's chipboard covered with melamine)
2. Just use switch blanks if I can find them
3. Is it Possible to purchase shallow buttons?I'm in the uk
Sjaak
Re: How do I correct a drilling error
« Reply #1 on: August 19, 2011, 12:48:27 pm »
Happened to me once. If you can fill it, try it. But I started with a new piece of mdf and tried again.
TopJimmyCooks
  • Last login:Today at 03:28:53 pm
« Reply #2 on: August 19, 2011, 02:10:03 pm »
Ultimarc has Goldleaf internal leaf buttons that don't have the microswitch junk in the trunk.  Might be a more compact solution that fits your application.
http://www.ultimarc.com/goldleaf.html
drawfull
« Reply #3 on: August 19, 2011, 03:44:07 pm »
Don't want to hijack the thread but that's the first time I have seen those buttons... How do they perform?
TopJimmyCooks
« Reply #4 on: August 19, 2011, 03:59:39 pm »
Drawful: Don't know, haven't used them.  Not aware of any reviews out yet either.  Ultimarc products are generally top notch.
NTC:  there are also button plugs available from many vendors.  usually flat black but I bet you could sand and paint them to blend with your melamine.
MonMotha
« Reply #5 on: August 19, 2011, 04:26:09 pm »
You may also look into the Japanese style buttons used in candy cabinets.  They're quite shallow.  Commonly made by Sanwa and Seimitsu.
nitz
  • Last login:November 24, 2015, 07:57:29 pm
« Reply #6 on: August 19, 2011, 04:34:32 pm »
If the shallow buttons will work for you, that's probably the way to go, but if you do decide to fill it in, Bondo works wonders! Not sure if this would have the same name in the UK or not, but it's basically autobody filler. When it dries, it's as hard as the wood. If you do a good job of sanding it and covering it, no one will ever know there were holes there. I would strongly advise you to do it outside though, as the fumes off that stuff are nasty.
« Reply #7 on: August 19, 2011, 04:51:38 pm »
From what I have heard is that they are nicer, quieter and lighter feeling than microswitches. Real leaf-switch purists seem to dislike them though, because they are not as bouncy as a trampoline or something like that.
