Author Topic: Cant exit mame game with maximus arcade :(  (Read 11573 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: August 18, 2011, 09:40:55 pm »
Ive tried the ESC button and even putting a delay on it and it just goes to either a black screen or it resets the game in another window.  Tried mapping to the END key and same thing.  IVe tried multiple button presses and same thing.
IS there a way to fix this problem so i dont have to ctrl+alt+del each time?  I dont want to use the keyboard to exit every game :(
DCsegaDH
Re: Cant exit mame game with maximus arcade :(
« Reply #1 on: August 18, 2011, 09:48:19 pm »
hit control+p on your keyboard: controller, setup 1, you should be able to use esc or set it to something else if that doesn't work.
equlizer
« Reply #2 on: August 18, 2011, 09:54:54 pm »
ohh another thing in the setup my stick is showing as joystick #3, not #1.
Thats what i just said.  ive tried 1 button presses even with delays and multiple presses and still no go.  i wonder if the above is the issue?  I want to map all my keys to my joystick and soon to be mame cabinet.
Im running windows xp 32bit and mame32 ver 0.90u1 and maximus 2.10 (no beta)
« Last Edit: August 18, 2011, 10:00:33 pm by equlizer »
DCsegaDH
« Reply #3 on: August 18, 2011, 09:58:32 pm »
what kind of encoder are you using? it might be a ground problem, just guessing :dunno
equlizer
« Reply #4 on: August 18, 2011, 10:18:04 pm »
encoder? you mean pcb inside the stick?  Im using something called the PS360.  But like i said it doesnt matter if its the keyboard or joystick, i cant quit the executable :(
equlizer
« Reply #5 on: August 20, 2011, 02:34:25 am »
bump.  anyone help?  Can i use Xpadder or joy2key to fix this?
Sjaak
  • Last login:March 19, 2025, 02:54:38 am
« Reply #6 on: August 20, 2011, 02:07:12 pm »
If you get the black screen and just wait, does it return to maximus after a while (20 to 30 seconds)???
mgb
  • North East, US
« Reply #7 on: August 20, 2011, 02:21:17 pm »
I'm just guessing, as I'm not sure but maybe its a focus issue.
Maybe there is a setting in Maximus that needs to be set to regain focus from the Mame executable over to Maximus?  :dunno
heres something from the documentation:
http://maximusarcade.com/index.php?option=com_content&view=category&layout=blog&id=41&Itemid=55#exit
« Last Edit: August 20, 2011, 02:28:32 pm by mgb »
BobA
  • What Me Worry?
« Reply #8 on: August 20, 2011, 02:25:46 pm »
The exit has to be set within Maximus Arcade.  Use Ctrl P to get to preferences.  Do not use the separate Preferences program.  Select controler and then setup 1.   Set quit executable to the key that you want on your joystick.
equlizer
« Reply #9 on: August 21, 2011, 12:30:22 am »
got it!!!  thx guys!
now im stuck with some roms not working or files missing :(
