Author Topic: MEGA TOUCH MODEL G20-100-003 problem please help.  (Read 8140 times)
abispac
  • Last login:January 31, 2026, 11:05:56 am
« on: August 13, 2011, 08:11:23 pm »
Hello and thanks for reading, i bought a MERIT MEGA TOUCH MODEL G20-100-003 at a local flea market, qhen i got home i plugged the machine and it dosnt turn on, so i wonder if maybe this is a monitor issue, since all i hear its a continues cliking noise near by the monitor but i dosnt turn on at all.So if anyone has one of this and maybe had have this problem can help me, thanks for any help
ed12
Re: MEGA TOUCH MODEL G20-100-003 problem please help.
« Reply #1 on: August 13, 2011, 09:17:07 pm »
hi is it the 12" crt style
if so what is the name on the side
u see merit olny used 2 dif model's of crt style monitor's
in there mega touch :bar-top: game's
if it is a 19" standup style then that is a dif story..
as a rule on the 12" unit's
if u look at the heat sink on the :left: of the chassic where the power cord goe's in will be a fuse
see if it is open..ie multi meter and machine un-plugged
if that fuse is good then u have a few other problem's
also look on the ami/merit site for there bar top's stand up-'s
but again most time merit used 2 dif type's which ken layton covered in our monitor thread's
good luck
ring me if u need me
ed
smartbomb2084
  • Last login:January 13, 2021, 03:14:53 pm
  • Having a SMART phone will make you DUMB.
« Reply #2 on: August 13, 2011, 09:19:32 pm »
This model number you have posted doesn't do anything for me.  I am lazy, research sucks.
Is this game a countertop or an upright?
Is it a Megatouch 1-7, an XL, or a MAXX?
Regardless of game type, if all you have is a monitor problem you should still be able to play the game 'blind', that is, when you touch the screen you should get a response acknowledged by a sound.
If you have no game boot up you can tell if the monitor is good by watching the screen when you turn off the power.  It should quickly flash white.
ed12
« Reply #3 on: August 13, 2011, 09:44:18 pm »
hi
straight link in
https://www.amientertainment.com/music/hardware
u want megatouch area
from there follow the d/l's section
ed
smartbomb2084
« Reply #4 on: August 13, 2011, 10:01:08 pm »
HERE is the link you want.
http://meritgames.com/new%20support.asp
Someone needs to go back to the eighties and get some HAIR on their DOG and learn how to write.
This abbreviated laziness you are posting is making me think of MISS MISERY  'cause now you are MESSIN' with a... a... SOB   ;)
abispac
« Reply #5 on: August 13, 2011, 10:12:52 pm »
its the 12 in crt monitor type,ill read the links and check for bad fuses too see if i get'it to work thanks.
ed12
« Reply #6 on: August 13, 2011, 10:15:22 pm »
hi
!huh!
my link takes me straight in
i just d/l 2011 ion up-date
for my ion's
ed
smartbomb2084
« Reply #7 on: August 13, 2011, 10:19:23 pm »
I have never heard of a MEGATOUCH with a 12" monitor.
It is more like 15" measured DIAGONALLY not straight across.
So is it a COUNTERTOP or an UPRIGHT?
Is it a 1-7, an XL, or a MAXX?
I just heard an echo coming from my computer.
smartbomb2084
« Reply #8 on: August 13, 2011, 10:22:06 pm »
What kind of non-speak is d/I?
abispac
« Reply #9 on: August 14, 2011, 12:25:29 am »
Im pretty sure its a 13 inch crt heres a link of one exactly like the one i have http://cgi.ebay.com/MEGA-TOUCH-MODEL-G20-100-003-TOUCHSCREEN-VENDING-GAME-/350423952933?pt=LH_DefaultDomain_0&hash=item5196e52e25
Anyway ,fuses look good and the cliking sound comes from the flyback so im taking this chasis to the experts to see if they can fix it.
ed12
« Reply #10 on: August 14, 2011, 12:40:16 am »
hi
d/l = download
and to be exact...12" 13"
1=yanke
1=canadian
pick
pix=picture tube and # if u can read
right out of a megatouch   #m34afa63x02 (u)
these are switch mode power supply type unit's
the tick tick u here is the switch trying to come on
problem's here are as a rule
1=cap's
2=vert-ic
3=ihvt >flyback<
that is usaly the last reason
good luck
english enough ?
ed
