Author Topic: Joypad hotkeys for close?  (Read 2331 times)
mrgrim333
  • Last login:July 02, 2019, 12:41:19 pm
« on: July 21, 2011, 04:30:53 am »
So I want to setup an external emulator to close with the hotkeys, which works fine.
Problem is, I want to set it so I can press two buttons on a joypad to trigger the closing of the emulator.
In mala (latest build), I can only assign keyboard keys as the hotkey.
I know I can set at least one button to be the "shift" in mala, but can't set the other?
Re: Joypad hotkeys for close?
« Reply #1 on: July 21, 2011, 01:50:01 pm »
You can try downloading and running a program like JoyToKey or xpadder. The program turns a joypad button push into a keyboard stroke. I'm not 100% sure how it would handle the two button combination, but I think it would work just fine.
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
« Reply #2 on: July 28, 2011, 05:04:47 pm »
You could use AllInOne.
Greetings!
