Author Topic: Introducing: JoyChoose plugin  (Read 8667 times)
« on: July 19, 2011, 10:42:16 am »
New plugin available for down load at malafe.net.
JoyChoose is a plugin designed to work with Mala to automatically switch your joystick between 8, 4, and 2 way.
You must add the proper hardware to your joystick to actually switch it. JoyChoose tells your hardware which joystick position to switch to, based on what the selected game used.
If you would like to learn how to do this, this link will get you started:
http://forum.arcadecontrols.com/index.php?topic=104762.0
Edit: Thanks Loadman!
« Last Edit: July 19, 2011, 10:45:48 am by DaOld Man »
loadman
    • MaLa
Re: Introducing: JoyChoose plugin
« Reply #1 on: July 29, 2011, 02:59:46 am »
Cool Work  :applaud:
« Reply #2 on: July 29, 2011, 10:10:53 pm »
Thank you sir!
chopperthedog
  • Last login:Yesterday at 07:23:13 am
« Reply #3 on: December 27, 2012, 01:55:14 am »
Thank you so much for this. Just got a pair of ServoStiks (for my space invaders table) and added your plug-in to mala. Works perfect.
good day.
Wade007
  • Last login:April 06, 2017, 01:33:35 pm
  • A MAME cabinet at home is heaven
    • bit.ly/1cWnoIC
    • Cheapskategamer.com
« Reply #4 on: December 27, 2012, 11:42:16 am »
This looks really cool.
I tried to follow the links regarding hardware but I'm a bit confused. Does your software plugin require Servo Joysticks then?
An Ultimarc U360 won't cut it right? Just trying to clarify.
My Super Arcade cabinet project:
Software blog article: http://bit.ly/1cWnoIC
Hardware blog article: http://bit.ly/1dWxjvP
YouTube video: http://bit.ly/1N818Xm
Super Arcade Cabinet Progress thread (Now Complete):
http://forum.arcadecontrols.com/index.php/topic,123292.0.html
Frontend Video Intro: http://bit.ly/1P9HPDN
chopperthedog
« Reply #5 on: December 27, 2012, 12:24:40 pm »
The plug in saves the time of adding command line entries to each game within mala. It should work fine with the 360's.
good day.
juggle50
  • Last login:July 18, 2024, 07:25:48 am
  • Your either on the bus or off the bus
« Reply #6 on: December 29, 2012, 12:34:58 pm »
I assume this wont work for happ supers correct?
« Reply #7 on: December 29, 2012, 02:19:47 pm »
Not unless you've modified them with motorized 4/8 way switching that can be triggered via command line.
secret80sman
  • Last login:March 14, 2013, 07:04:31 pm
    • The Ultimate 80's Tribute Band
« Reply #8 on: January 17, 2013, 08:30:12 am »
Very cool. Thank you!
Gray_Area
  • -Banned-
  • -Banned-
« Reply #9 on: January 17, 2013, 05:43:48 pm »
To be clear(er), this app was in anticipation of those making their own mechanically switchable restricted joysticks. And the Servostik is a recently released product that is complemented by this app.
-Banned-
