Author Topic: painting T-molding  (Read 3810 times)
SavannahLion
painting T-molding
« on: June 13, 2011, 12:58:11 pm »
Back when I started my current WIP, I ordered some sample T-molding. I was largely dissatisfied with Tue options because, while I can find the width and color, I can't match the shape. And while I can match the width and shape, I can't match the color. It's been a while and, like a dummy, I didn't note which samples were for what, so I kind of have to start over.
Then it dawned on me that one of the paint companies (I'm at work and I'm
too lazy to Google this detail right now) sells a spray paint that's supposed to "bond" with plastics on a "molecular level" that I can try with the T-molding. Tried a forum search and found a few queries but no answers. Has anyone tried this paint on the molding? I really don't want it rubbing off, that would suck ass.
Note: IIRC, the white Nintendo "flat" T-molding is a perfect match in size and shape, but not color. If I can spray paint it black..... you get the idea.
If no one answers, I'll pick up a can of the plastics paint and give it a whirl on my sample.
eds1275
  • Online Online
  • Last login:Today at 01:56:04 pm
  • Rock and Roll!
Re: painting T-molding
« Reply #1 on: June 24, 2011, 06:29:53 pm »
The one you are probably thinking of is called Krylon Fusion. I have used it extensively with mixed results. Some of it has gone on pretty hard, different types of plastic seem to react differently with the paint. Since it is cheap, and you can probably find other uses for a can of black spray paint, I'd say give it a shot.
http://www.krylon.com/products/fusion_for_plastic/
Another option is to use a vinyl dye. Apparently these are much more permanent and can be found at auto-supply stores. I have never tried them but have heard only good things.
http://www.vhtpaint.com/vinyldye.html
