Author Topic: Mortal Kombat Kabinet and X-Arcade Controller  (Read 3499 times)
rmusick
  • Last login:November 12, 2017, 09:15:41 pm
« on: June 09, 2011, 08:51:39 am »
Sorry Guys wasn't sure if this should go in woodworking or the Main Forum, Please correct it if I made a mistake.
Has anyone put a X-Arcade Controller on a Mortal Kombat Cabinet?  Im debating whether to build or buy.
Re: Mortal Kombat Kabinet and X-Arcade Controller
« Reply #1 on: June 09, 2011, 08:58:28 am »
I will hate you if you do that. I mean, moving the guts is one thing, bolting an Xarcade onto a MK cab is another.
garnerb350
    • Hyperspin
« Reply #2 on: June 09, 2011, 09:50:31 am »
Has anyone put a X-Arcade Controller on a Mortal Kombat Cabinet?Thanks
If you do, Shao Khan will destroy you and Melenna will give you Baraka crabs...and Goro will use your carcass as toliet tissue...
If you buy the cab... buy the buttons, joysticks, interface, etc... DONT mount the  controler over the MK CP... If you are missing the MK control panel... buy a slab of wood and remake the CP...
rmusick
« Reply #3 on: June 09, 2011, 09:54:47 am »
Ok, Let me add..(Left the IMPORTANT part out) this is a scratch build replica.. the Actual Mortal Kombat cab in sitting nicely waiting for a little TLC.
« Reply #4 on: June 09, 2011, 10:03:21 am »
Hehe, yeah, that was the important part.  You almost brought down the wrath.  That being said, don't go the X-Arcade route.  You're building a replica from scratch, do it right, make your own control panel too.
garnerb350
    • Hyperspin
« Reply #5 on: June 09, 2011, 10:32:01 am »
Had me scared there for a moment... :laugh2:
rmusick
« Reply #6 on: June 09, 2011, 10:43:37 am »
Yea see that now.. probably a lot cheaper to build
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #7 on: June 09, 2011, 03:06:04 pm »
But will you hate him in his face ?
To the OP -- if you went through the trouble to build from scratch, keep doing so, unless the X-Arcade interface provides you an advantage (vis a vis interfacing to other systems).
Working: Not Enough
Projects: Too Many
Progress: None
« Reply #8 on: June 09, 2011, 03:18:36 pm »
I only do that for special people.
  • Last login:Today at 10:39:28 am
« Reply #9 on: June 09, 2011, 03:55:47 pm »
yeah.....how about a pic of them side by side.  :duckhunt
