Author Topic: Is it possible to shrink Windows desktop?  (Read 4130 times)
LeedsFan
« on: June 07, 2011, 04:08:46 pm »
I basically want to shrink the image of my desktop so that I get a smaller screen of around 10" viewable. As far as Mame is concerned I can just enter into the TAB menu and look in the slider settings and then play around with them so that all games fit exactly where I want them to. But once I'm in the frontend or back to desktop everything reverts to full size. I just want to display my desktop and all programs with a black border all around to mimic a smaller sized monitor. Is this possible? It's Windows XP by the way.
  • Last login:Yesterday at 12:10:06 pm
Re: Is it possible to shrink Windows desktop?
« Reply #1 on: June 07, 2011, 04:16:44 pm »
Most NVidia cards I've had allow you to adjust the size and position of the desktop.
Drivers from different time periods seemed to have different options for the Nvidia cards.
I remember having to install an older driver one time to get a feature I was looking for.  :-\
I currently have 8000 series cards in all my machines with the most current drivers (I think).
They have the option.
  • Last login:November 25, 2025, 07:49:55 pm
« Reply #2 on: June 08, 2011, 01:16:03 am »
Hmm.... tricky. This doesn't solve your problem as far as the desktop is concerned but couldn't you build a MALA theme that only uses a 10" portion of the screen?
LeedsFan
« Reply #3 on: June 08, 2011, 04:24:53 pm »
Yeah I could and that's exactly how I did my DK bartop. But this time I'm using a different frontend for my Star Wars project and there's no way to reduce the image size for that. Not that I can tell anyway.
ark_ader
  • I glow in the dark.
« Reply #4 on: June 08, 2011, 04:53:01 pm »
I was thinking of the same thing the other day after looking at those Flash Starwars screens.
Then I thought:  "what if I used my PSP to drive the display" and then remembered I had the homebrew software on the file server PC and tried it out.  I remembered this was going to be a part of my mini dragon's lair project (that is sitting in my shed) and use the cab as a docking station for it and the PSP as the scoreboard.
I'll try it out this weekend. I think the software is called PC Monitor Alpha.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #5 on: June 08, 2011, 10:04:22 pm »
I'm not getting why you would want this in the first place. ?
-Banned-
scofthe7seas
  • Last login:January 10, 2012, 11:33:10 am
  • I'm Eskimo. There's nothing here.
« Reply #6 on: June 09, 2011, 02:54:00 am »
Are you using an LCD? Depending on the brand (a lot of newer ones have this feature) you can put the pixel aspect to 1:1, which means it doesn't stretch lower resolution than the native res. Then, set the resolution as small as you like. I think Nvidia cards might have a feature similar to this also, regardless of screen type.
LeedsFan
« Reply #7 on: June 09, 2011, 04:34:22 pm »
I'm building a small scale cabinet. This means I need something like a 10" screen. A screen this size is very hard to come by without paying a lot of money for something like a modern touchscreen. But I can easily buy an older 15" monitor dirt cheap that will fit in the cab. Then I just need to adjust the visible area by letterboxing windows somehow.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #8 on: June 12, 2011, 06:03:07 am »
.....  If 15 inches fits in there, use the whole screen.
-Banned-
ark_ader
« Reply #9 on: June 12, 2011, 06:18:06 am »
I tried the PSP thing and it works but its not your 10" that you are wanting.  I have another solution for you though.  Since you are just playing Star Wars you can get away with with a smaller CPU size and still have the same experience.
I would look on ebay for a ThinkPad 240X.  Last one went for £27, and that has a 10" display and you can hook up your whatever size display for the main screen.  I have one that I was going to put into my Mini DL and I use it for college as it is really small.  Perfect size for your project.
You just have to find one.
I found this solution was possible and you can use photographers tape on the screen to mask the window frames, cheap I know but workable.  You would need to add a button to your cab that would activate the session for the flash and you would need to time it when it is trenchville.
« Last Edit: June 12, 2011, 06:56:54 am by ark_ader »
LeedsFan
« Reply #10 on: June 12, 2011, 02:08:48 pm »
I actually thought about the Thinkpad screen because I've owned one of those laptops before. But I also remember how bad the viewing angle on that thing was. It was terrible. You just had to move your head a little and the contrast on the screen shifted horribly.
I've just bought a Xerox XA7-15i monitor which I used in my DK bartop. It physycally just fits in my Star Wars cab above the artwork around the yoke. I did some research on Google and it seems Powerstrip software might be an option for letterboxing windows. I just need to power up this monitor and mess with the software and Windows settings. Trouble is this monitor uses a strange power cable which I need to go buy tomorrow (seller didn't have the cable which is why I got it cheap).
ark_ader
« Reply #11 on: June 12, 2011, 04:20:32 pm »
How about using a mirror instead?
