Author Topic: Disabling MAME "Starting..." box  (Read 4465 times)
Well Fed Games
  • Delicious!
« on: June 06, 2011, 03:07:14 pm »
OK, I am going with a retro theme, and the only thing that visually reveals that my cab is modern is the "Starting..." box that pops up for a second when Mame launches a game. Would love to disable this... I am using (I think) a no nag compile of Mame, and I did a major search for answers with no luck. Anybody know how to disable this message (I could not manage to get a screenshot of it)? I'm using Mala as front end, FYI.
Well Fed Games
  • Delicious!
Re: Disabling MAME "Starting..." box OR change font?
« Reply #1 on: June 07, 2011, 04:47:16 pm »
OK, I would be happy with just changing the font to something pixellated. I tried the instructions here http://www.mameworld.info/mrdo/mame_artwork_supp.html with no luck- either I have done something wrong or the procedure has changed since then. Anyone have ideas on how to change the MAME UI font?
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #2 on: June 07, 2011, 05:26:48 pm »
Changing the font might be more trouble than its worth, i mean, that would break the TAB menu too, resulting in you never ever being able to tweak any setting on any game.
I gotta think that the answer is in here (the hiscore and no-nag diffs thread, which I'm sure you looked at)
http://forum.arcadecontrols.com/index.php?topic=64298.0
The changes you want to make have to be in virtually the same file as removing the other screens that pop up.  Compiling your own version of MAME isn't that difficult, especially with headKaze's MAME builder GUI.  (if that's still updated?)
Well Fed Games
  • Delicious!
« Reply #3 on: June 07, 2011, 06:28:38 pm »
Hmm. I think I already have a no nag compile of Mame (I didn't compile it myself- found one online, the compile process did not seem to work for me)... it doesn't bug me about less than 100% emulation of games anymore (no more moving the stick left-right). It just still has a "starting..." message that pops up (for less than a second). Unless it is a Mala message, hadn't thought of that.
I know I am getting picky here, but I've got the software side 99% of where I want it to be :dizzy:
51mmz0rz
  • Last login:January 14, 2012, 12:10:45 am
« Reply #4 on: June 07, 2011, 09:48:18 pm »
I'm using a hiscore/nonag build (built myself using the link NOP posted) and there is no "starting" text when launching a game through MAMEUI.
eds1275
  • Rock and Roll!
« Reply #5 on: June 07, 2011, 09:51:37 pm »
Mala does that with plenty of options to change or delete entirely.
Well Fed Games
  • Delicious!
« Reply #6 on: June 07, 2011, 11:26:18 pm »
Hmm, don't see "plenty" of options, but thanks for the confirmation- I did finally find the option I needed, in Mala like you said, not Mame. Here's the scoop for anyone else who is bugged by the "starting..." dialog-
In Mala
go to Options- GUI section- Game Start/quit subsection- check "use fullscreen starting picture instead of starting window." Specify the file path of what picture you want to pop up.
In my case, I just made a "please wait" message in the same font as my layout.
As always, thanks to the forum for being smarter than I am!  :cheers:
eds1275
  • Rock and Roll!
« Reply #7 on: June 08, 2011, 11:22:54 am »
plenty of options: you can change the starting font/text/background image as well as disabling it entirely
Well Fed Games
  • Delicious!
« Reply #8 on: June 08, 2011, 12:54:35 pm »
I will take your word for it... but any clues as to where these options are? I may be overlooking an options tab somewhere.  ???
TopJimmyCooks
« Reply #9 on: June 08, 2011, 01:14:55 pm »
If you first uncheck the use fullscreen starting screen, you get more options for the background/font of the small starting window.  If you supply a different image as part of your layout you can use that instead.  I don't have the exact stuff in front of me, but if you look around the options are documented in the wiki at www.malafe.net.
Well Fed Games
  • Delicious!
« Reply #10 on: June 08, 2011, 01:59:56 pm »
Hmm. Nothing about the game start options there that I saw. http://wiki.arcadecontrols.com/wiki/Mala_Config#Game_Start No biggie, I think I got it to where I am comfortable with it-- in fact the brief starting screen allowed me to use an art asset I was trying to work into the cab. Thanks! I think the front end is complete for the cab- hope to show it off in a video eventually.
TopJimmyCooks
« Reply #11 on: June 08, 2011, 04:04:26 pm »
In this screen:
if you don't check "use fullscreen . . .", you get the small starting window.  You can edit the text/font/background image, maybe size of that box? in layout editor.  Edit the layout you're using.  I'm vague after that but it's in there.  I think you're doing the layout editor thing already if you have art in this box.   :cheers:
