August 19, 2025, 09:35:00 pm
Currently stuck between contracts, weather is mostly ---steaming pile of meadow muffin--- and boredom is setting in. So I'd thought I'd finally get around to making my dreamcast, which I only bought for this purpose anyway, jamma compatible.I still need to add a few things, like a switch to kill the internal controllers, for some light gun action. Also adding video out to the jamma edge, so I can get back my scanlines when in 15khz mode.It is otherwise done.Jamma connector, Headphone jack, DB9 kick harness connector and cutout for the memory card.VGA connector, 15/31khz switch.Guts spilled open.There's two internal controllers with one slot for a memory card. All of the components that sit on the top metal panel are going to connectors, strip boards. Making everything very easy to take apart when needed.And a look inside the gutted modem shell.Next up, is a Genesis. This one is going to be a much quicker project to do. Using an harness going to the Sega CD extension port, instead of adding a jamma connector to the shell.
