Author Topic: Jamma Dreamcast  (Read 9356 times)
Jamma Dreamcast
« on: June 01, 2011, 04:57:25 pm »
Saw this on the neo-geo forums last night:
http://www.neo-geo.com/forums/showthread.php?225277-Jamma-projects.&p=3204006#post3204006
Thought it was pretty cool.
PCMedics
  • Last login:September 22, 2013, 12:28:12 am
Re: Jamma Dreamcast
« Reply #1 on: August 20, 2011, 05:39:59 pm »
Very creatve
  • Last login:July 23, 2025, 07:04:20 pm
Re: Jamma Dreamcast
« Reply #2 on: August 22, 2011, 12:55:04 pm »
I can't see the link, but I've started a DC JAMMA project.  Got a fingerboard, hacked a VGA box, and some controllers...  just gotta finish wiring.
Re: Jamma Dreamcast
« Reply #3 on: August 22, 2011, 01:03:10 pm »
Here you go:
Quote from: shadows;3203179
Currently stuck between contracts, weather is mostly ---steaming pile of meadow muffin--- and boredom is setting in. So I'd thought I'd finally get around to making my dreamcast, which I only bought for this purpose anyway, jamma compatible.
I still need to add a few things, like a switch to kill the internal controllers, for some light gun action. Also adding video out to the jamma edge, so I can get back my scanlines when in 15khz mode.
It is otherwise done.
Jamma connector, Headphone jack, DB9 kick harness connector and cutout for the memory card.
VGA connector, 15/31khz switch.
Guts spilled open.
There's two internal controllers with one slot for a memory card.
All of the components that sit on the top metal panel are going to connectors, strip boards. Making everything very easy to take apart when needed.
And a look inside the gutted modem shell.
Next up, is a Genesis. This one is going to be a much quicker project to do.
Using an harness going to the Sega CD extension port, instead of adding a jamma connector to the shell.
Im wondering if he's powering this off the 12v line...I'm assuming so.
I really dig his use of the modem area, maybe this will give you some ideas.
Beaps
  • Last login:July 09, 2020, 10:46:40 am
Re: Jamma Dreamcast
« Reply #4 on: February 03, 2017, 06:41:09 pm »
Hi
I know this is an old thread but has anyone tried this mod.
I'm a little stuck
Ta
B
ark_ader
  • I glow in the dark.
Re: Jamma Dreamcast
« Reply #5 on: February 04, 2017, 03:02:57 am »
The original link threw up all kinds of "don't go there" on my AV.  Be careful clicking on the link....
Beaps
Re: Jamma Dreamcast
« Reply #6 on: February 05, 2017, 01:26:55 pm »
Has anyone tried this mod, I am struggling on how to convert 5v to 3.3v, what did you guys use?
  • Last login:Yesterday at 11:11:41 pm
Re: Jamma Dreamcast
« Reply #7 on: February 05, 2017, 08:04:46 pm »
Well resistors will drop voltage, but depending upon what you need that might not be enough.
http://www.learningaboutelectronics.com/Articles/How-to-reduce-voltage-with-resistors.php
Just remember, you may have to reduce amperage as well.
I don't have any experience on this particular hack, so I'm Leary about giving any more advice than that.
