Author Topic: Star Wars Upright - Custom Cabaret!  (Read 84481 times)
Re: Star Wars Upright - Custom Cabaret!
« Reply #40 on: May 25, 2011, 04:03:52 pm »
Oh, it's on, buddy! IT'S ON!!!!
  • Last login:Yesterday at 04:39:53 pm
« Reply #41 on: May 25, 2011, 04:11:05 pm »
 >:D
« Reply #42 on: May 25, 2011, 04:13:17 pm »
I figure if worse comes to worse, I can go steal the RoadBlasters conversion Star-Wars at Castles N' Coasters.
LeedsFan
« Reply #43 on: May 29, 2011, 12:41:27 am »
I'd build one from scratch, but the control panel/plastic bezel part is what throws me for a loop.
Have you checked the ROTJ Vector version? He scratch-built a SW cab with the bezel. Looks pretty easy to make:
http://urbaninteractive.wordpress.com/2009/12/
That looks really cool!  But does anyone know what frontend is being used on this cabinet? I've not seen anything like this before but it's exactly what i would like to use on my own Star Wars project.
shrunkenmaster
« Reply #44 on: May 29, 2011, 08:34:27 am »
He made the frontend, you can grab it from his site. You'll have to go through his build pages month by month to find it though.
taylormadelv
  • Last login:February 18, 2019, 05:46:59 pm
« Reply #45 on: May 29, 2011, 01:06:37 pm »
Awesome project, I have been watching this one! Funny thing about emulating SW and ESB... I've been playing around with a P4 2.4 2gm ram, Radeon 9250 + ZVG card + Command line mame .137 and basically I always go into some sort of Frameskip on these games, even with zvg rendering off. This rig played most vector games in AAE pretty nicely.
I went back to Macmame OS 9 version .66 and these games all play PERFECTLY on an old, boat anchor G4 and I'm running classic, not even native OS9. The way Macmame OS9 renders vector games rivals even the output of the ZVG to a real WG6100 completely cranked up. Yes, I am comparing a real vector monitor to a VGA powered by Macmame and the way I am testing these, Macmame looks better because there is no frameskip, the intensity of the vectors can be cranked up way beyond any PC flavor of mame I have used. Macmame OS 9 .66 is the best vector game emulator I have used and I own several "real" arcade vectors. The problem is that OS9 has no front end as far as I know and always has that nag screen when you first open the app.
shrunkenmaster
« Reply #46 on: June 20, 2011, 04:41:16 pm »
Not much to report here, having mad problems compiling MAME. Artwork is coming along nicely though, have also sent the acrylic CPO for laser cutting, should be ready in a day or two.
LeedsFan
« Reply #47 on: June 20, 2011, 04:59:07 pm »
I've just been playing around with the PC and software side of things on my own project these last few days. It was quite frustrating but I think I've got there in the end.
I have a separate Star Wars.ini file with Gamma set at 2.0, Beam at 1.2.  I think the Beam will depend on your monitor, just play around with it till it looks good. Default Mame.ini settings suck for all vector games, but you can get them to look nice and bright if you play with those two settings.
Regards PC specs I had two boxes to play around with this past week. The first was a 2.9 GHz "eMachines 4034" box. I had this as favourite to run Star Wars smoothly with that kind of speed processor (Pentium 4). But it slowed to 65% on destryoing the Death Star and the sound stuttered like mad.
Then I tried a second box with only a Sempron 1.99 GHz processor. This was much better! Speed dipped to only 95% on destroying Death Star and the sound didn't skip so I'm happy with that. Both machines were running Windows XP (fresh installs on each) and both had the same onboard Radeon Xpress 200 graphics. The Sempron box did have 1.0 Gig RAM as opposed to the 512 MB RAM in the Pentium box. Both machines seemed run the game at 100% with no Frameskip just fine... until the Death Star sequence. But on a dedicated cab you can't have that sequence screwing up! I'm still surprised at the box that won out in the end though.
EDIT:  Just for info purposes I also have two other machines which I tried Star Wars on.....
1)   Intel Core Duo E8500 @ 3.16 GHz with Windows Vista, Radeon HD4850 and 3.0 GB RAM.   Games runs about the same as the Sempron. It does very slightly drop speed at Death Star sequence with no sound stutter. I'd say it's slightly better than the Sempron but when you factor in the cost the Sempron still wins.
2)  Intel i3 530 OCed to 4.0 GHz with Win7, Radeon HD5570...  blah blah     :laugh2:   Yeah... no flaws whatsoever. It laughs in the face of the Death Star at 100% without a flinch.  Just thought I'd add this in for completeness    :P
« Reply #48 on: June 21, 2011, 09:03:38 am »
I would like to see this.  The nag screen is easy to remove.
shrunkenmaster
« Reply #49 on: June 24, 2011, 06:41:03 am »
Thanks for the info, LeedFan. I now have my recompiled MAME 0.137 running, computer is a Core 2 1.83Ghz, 2G RAM, Nvidia Quadro FX 550.
No Death Star slowdown/sound stuttering! I can't believe it!
My mame.ini is below (just the video bits) - any video options you think need changing here, ie. hwstretch???
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
speed                     1.0
refreshspeed              0
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            0
numprocessors             auto
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  1
effect                    none
waitvsync                 0
syncrefresh               0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
« Last Edit: June 24, 2011, 03:28:15 pm by shrunkenmaster »
rrcade
  • Last login:December 03, 2019, 10:37:08 pm
« Reply #50 on: June 25, 2011, 05:58:40 am »
The problem I have with the frontend from urbaninteractive is that if you hit esc more than once you are exited out of the frontend, have you found a way around this?
shrunkenmaster
« Reply #51 on: June 25, 2011, 08:35:39 am »
Hey rrcade,
I'm having mad trouble with the frontend. What yoke/interface are you using? Could you please post your launcher .ini here?
No escape button workaround here, just be careful to press once!
shrunkenmaster
Re: Star Wars Upright - Custom Cabaret! - Artwork Update
« Reply #52 on: June 25, 2011, 08:53:34 am »
Here's the new marquee I've been working on:
and the new yoke overlay:
and the new control panel:
Not sure what to do with the kick panel yet...
« Last Edit: June 25, 2011, 08:56:19 am by shrunkenmaster »
  • Last login:January 29, 2026, 10:37:15 am
« Reply #53 on: June 25, 2011, 09:20:03 am »
Artwork looks clean and awesome!  :cheers:
Bender
« Reply #54 on: June 25, 2011, 12:26:20 pm »
Man this is going to be sweet!!! :cheers:
I want one!!!!
shrunkenmaster
« Reply #55 on: June 25, 2011, 12:51:26 pm »
Thanks for the words of encouragement emphatic & Bender. I'm really looking forward to putting all the pieces together once I get the control panel acrylic back from the shop.
Just flipped the video for the Targetting Computer display, much better the right way up!
LeedsFan
« Reply #56 on: June 25, 2011, 05:47:21 pm »
Hey rrcade,
Easiest workaround to this problem is to set your Mame "Escape" key to something else... and then don't have an actual keyboard Escape on the cabinet.
EDIT:  The problem I had with the launcher is that it refused to work in portrait mode on my cab. It just froze every time. I had the config file set to the correct resolution but it was total fail.
Encryptor
  • Trade Count: (+34)
« Reply #57 on: June 25, 2011, 10:37:15 pm »
sm - Very nice artwork dude! This one is going to be as nice as your Tron mini. Nice job!
shrunkenmaster
« Reply #58 on: June 30, 2011, 12:42:03 pm »
Finally got the acrylic overlay back. Have also sent all the artwork to be printed, hope to have it back sometime next week.
Generic Eric
« Reply #59 on: June 30, 2011, 02:11:59 pm »
http://urbaninteractive.wordpress.com/2009/05/05/launcher-released-and-a-couple-facelifts/#comment-156
http://www.urbaninteractive.net/Launcher%20v1.01.zip
shrunkenmaster
« Reply #60 on: July 07, 2011, 11:11:55 am »
After a battle with the urbaninteractive front end, which now only seems to work with the mouse, I decided to go back to my old friend MALA. I created two snapshots, one each for Star Wars and Empire. I made a layout in MALA that just displays the snaps. It works well enough for me.
TopJimmyCooks
« Reply #61 on: July 07, 2011, 11:23:36 am »
Looks great and really shows the flexibility of Mala.  I like this trick and the other gent here with the superPac where he made only one game show up in the scrolling game list at a time.
Bender
« Reply #62 on: July 07, 2011, 11:43:08 am »
Great work on the Art, and the front end!!!!! :cheers:
How long till that Vector ROTJ comes out?
Will you do a triangle setup or 3 across?
Man I really like these Star Wars projects!!
if i didn't already have too many projects going I'd have to build one of these too :banghead:
« Reply #63 on: July 07, 2011, 11:58:26 am »
Wow, this is going to be phenomenal.  :notworthy:
shrunkenmaster
« Reply #64 on: July 07, 2011, 11:59:36 am »
Thanks for the encouragement guys.
I have no idea when the ROTJ vector version will be ready. The author was working on the engine last time I looked, but hopefully one day the circle will be complete!
I'm waiting on artwork now, so I can finally install the buttons and finish the CP. In the meantime, I need to find somewhere for the band to play...
Woodshop Flunky
« Reply #65 on: July 07, 2011, 12:38:43 pm »
This is just getting better and better!   :cheers:
shrunkenmaster
« Reply #66 on: July 07, 2011, 01:01:38 pm »
I've had this little Cantina Band Set for a while now, but had nowhere to put it. There's a battery-powered box with a button, which plays the "Cantina Band" music. I've now extended the switch wires and routed the power wires to the computers' 5v supply. Just need to find the ideal place for the band to perform... more soon.
LeedsFan
« Reply #67 on: July 07, 2011, 01:25:06 pm »
That is great what you did there with the frontend!  I also had trouble with the Urbaninteractive FE and just could not get it to work in portrait mode. It's a really cool FE but it looks like neither of us can use it.  :-\
I also made a Mala setup but it's not as nice as yours. I'm really crap at artwork and setting up FE's. One thing you could do (dunno if you think it would be as good) is to have the .avi file play in the background but without displaying it. Then as you highlight each game you also get the sound from the game video. That's what I did on mine but all you see is the game list and the marquee.
Oh... and I wanna hear that band play!   :applaud:
« Reply #68 on: July 07, 2011, 01:28:24 pm »
Love your FE for this project! And your targeting display! :applaud:
shrunkenmaster
« Reply #69 on: July 07, 2011, 01:29:28 pm »
TI'm really crap at artwork and setting up FE's.
Cheers mate, let me know if you need any help with your frontend graphics, it would be a pleasure!
shrunkenmaster
« Reply #70 on: July 07, 2011, 03:54:45 pm »
I was planning to do this next! Great idea, and another cool thing to do with MALA.  :cheers:
« Reply #71 on: July 07, 2011, 04:35:35 pm »
This is so awesome.  I love the targeting computer and your front-end menu.  You've managed to design something very new and creative yet would not look out of place in an arcade circa 1983.
shrunkenmaster
« Reply #72 on: July 09, 2011, 04:42:55 pm »
I just dug out MacMAME 0.103u2 and had a play on my PPC G5. All I can say is UNBELIEVABLE.
The vectors, the framerate, everything S**TS on the PC I've currently got in my cab. I'm looking at this on an old G4 LCD monitor too!
Words can't describe how much of an improvement there is.
Bender
« Reply #73 on: July 10, 2011, 02:23:14 pm »
Where did you get the illuminated buttons?
and how big are they roughly?
shrunkenmaster
« Reply #74 on: July 11, 2011, 04:37:44 pm »
Bender, here's the eBay listing :
http://cgi.ebay.co.uk/6pcs-Lighted-Push-Square-Button-Switch-Lamp-LED-12-Volt-/270770343541?pt=LH_DefaultDomain_0&hash=item3f0b2b8e75
All the dimensions are on there, but let me know if you need any further details.
shrunkenmaster
« Reply #75 on: August 15, 2011, 03:42:48 pm »
Finally got the artwork back (my printer was on holiday) - all looks good. Only managed to get the yoke overlay applied so far:
Should be able to get the bezel and marquee done over the next couple of days...
« Last Edit: August 15, 2011, 03:48:03 pm by shrunkenmaster »
shrunkenmaster
« Reply #76 on: August 19, 2011, 01:09:41 pm »
Applied the bezel vinyl. Luckily all my measurements came together - the yoke cutout in the vinyl and the acrylic are bang on!
Got the buttons in too:
Hopefully tonight I'll get the buttons and lights wired up. More soon...
« Reply #77 on: August 19, 2011, 01:42:51 pm »
Shrunkenmaster-
The vinyl looks great! How did you apply it? A friend of mine created a 23 by 20 inch vinyl bezel sticker for me, but I'm scared to death to apply it.
shrunkenmaster
« Reply #78 on: August 19, 2011, 01:56:16 pm »
Shrunkenmaster-
Yes my man, it can be scary! I aligned the vinyl with the acrylic, then clamped one end. At the other end I cut off about an inch of the backing paper and stuck that down. Took the clamps off, then just used my fingers to SLOWLY press down on the vinyl while pulling the paper up inch by inch. Take it slow, make sure the surface is free from dirt (including flecks of backing paper) and it's not as bad as you might think.
You can also make up a solution of slighty soapy water in a spray bottle and apply sparingly to the acrylic beforehand. This will allow you to reposition/peel up the vinyl should you have a problem during application. Some people also use a credit card to smooth things out rather than fingers! Hope that helps.
« Reply #79 on: August 19, 2011, 02:18:24 pm »
Shrunkenmaster-
Did you have the masking on the front of the artwork? The bezel I have doesn't have masking on it, but I COULD get some if need be.
