Author Topic: My Mala Layouts  (Read 16070 times)
Indy96
  • Last login:August 15, 2013, 05:29:25 pm
My Mala Layouts
« on: April 30, 2011, 06:26:55 pm »
Been lurking for a long time and figured out how to get Mala running through this forum. I thought I would finally sign up and share my progress to get your opinions.
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
Re: My Mala Layouts
« Reply #1 on: May 02, 2011, 11:15:29 am »
They are very nice and now the question is: Are you going to share them?  :cheers:
TopJimmyCooks
Re: My Mala Layouts
« Reply #2 on: May 02, 2011, 03:34:11 pm »
Good job, the cracked earth theme backing them up ties the emulators together very professionally.  Loadman on this board has a gallery on his site I'm sure you've seen - www.malafe.net I think.  If you decide to make them available I suspect he would be happy to host them there.  Welcome to BYoAC.
Indy96
Re: My Mala Layouts
« Reply #3 on: May 02, 2011, 05:29:28 pm »
Thanks....believe it or not the background image is  a high resolution pic of a log cut in half.  They are 1280x800.  I have no problem sharing them if people are interested.
loadman
    • MaLa
Re: My Mala Layouts
« Reply #4 on: May 03, 2011, 04:46:30 am »
Yeah, I like the MAME one in particular
Indy96
Re: My Mala Layouts
« Reply #5 on: May 03, 2011, 08:58:26 am »
Feel free to save these if you like.  I am using these on my 40" sony and they look really good.
« Last Edit: May 03, 2011, 09:00:18 am by Indy96 »
Indy96
Re: My Mala Layouts
« Reply #6 on: May 03, 2011, 09:01:16 am »
Nintendo
Indy96
Re: My Mala Layouts
« Reply #7 on: May 03, 2011, 09:02:06 am »
Super Nintendo
Indy96
Re: My Mala Layouts
« Reply #8 on: May 03, 2011, 09:02:47 am »
N64
Indy96
Re: My Mala Layouts
« Reply #9 on: May 03, 2011, 09:03:29 am »
Genesis
Indy96
Re: My Mala Layouts
« Reply #10 on: May 03, 2011, 09:06:03 am »
Atari
empardopo
    • My personal forum
Re: My Mala Layouts
« Reply #11 on: May 06, 2011, 01:08:13 pm »
wow!!!!! Thanks very much!!!  :notworthy:
Indy96
Re: My Mala Layouts
« Reply #12 on: May 12, 2011, 11:58:28 am »
Dreamcast
fallacy
  • Last login:Yesterday at 07:24:28 pm
Re: My Mala Layouts
« Reply #13 on: May 31, 2011, 03:42:45 am »
You have some nice clear cut out images. It would be nice to get one big Photoshop file so we could swap out the background and still use the images you cut out.
Gray_Area
  • -Banned-
  • -Banned-
Re: My Mala Layouts
« Reply #14 on: May 31, 2011, 07:21:59 pm »
I like that marquee list - how is that done?
-Banned-
Indy96
Re: My Mala Layouts
« Reply #15 on: June 02, 2011, 04:56:55 pm »
I no longer have the PSD files as my HD crashed last Wed.  :angry:  :banghead:
I lost a ton of work.  The Mame Computer still has the layouts though.  I had a ton of High Res images. :dizzy:
Gray_Area
  • -Banned-
  • -Banned-
Re: My Mala Layouts
« Reply #16 on: June 02, 2011, 06:50:08 pm »
I figured this out, with your help. In the lower left of the game list properties, you have to check 'image list', then at the top select the type of image from the drop down menu.
I had to play around a bit with the parameters to get the desired size of and spacing between marquees, plus I had to use 'stretch to fit' as my marquee images aren't all the same size.
However, this kind of feature benefits from a smooth scroll (a la Hyperspin or Ultrastyle)  rather than an instant shift of the list.
Too bad about your loss. Did you have high res marquees?
« Last Edit: June 05, 2011, 05:50:38 am by Gray_Area »
-Banned-
br2000ad
  • Last login:March 22, 2013, 03:55:09 am
Re: My Mala Layouts
« Reply #17 on: August 30, 2011, 12:32:36 pm »
how do i get these on my layout..?
wcndave
  • Last login:June 10, 2021, 03:37:36 am
Re: My Mala Layouts
« Reply #18 on: August 15, 2012, 11:54:44 am »
Hi, these look really great, however wouldn't we need the *.mll files? to use them?
many thanks,
Dave
dragon32
  • Last login:December 01, 2012, 05:19:46 pm
Re: My Mala Layouts
« Reply #19 on: September 08, 2012, 05:45:23 am »
great work they look awesome!
recklessindian
  • Last login:April 28, 2020, 04:11:39 pm
Re: My Mala Layouts
« Reply #20 on: November 24, 2012, 01:19:23 pm »
Very nice, I'm still looking for a layout for my sega  CD and 32X.  I made my own, but it is so bad I won't show it in public. ;D
Arrrrr Scurvy
Eldritch1969
Re: My Mala Layouts
« Reply #21 on: November 24, 2012, 01:30:46 pm »
Great layouts !
