Author Topic: Best way to illuminate a Imperial/Betson Trackball?  (Read 3478 times)
sirhcman
  • Last login:January 20, 2008, 01:50:45 pm
« on: August 28, 2003, 02:29:36 am »
I know this thing can be illuminated but it didnt come with a light or anything....What is the best way for me to light this trackball? Bulb, etc?
AlanS17
    • AlanS17
Re:Best way to illuminate a Imperial/Betson Trackball?
« Reply #1 on: August 28, 2003, 02:32:12 am »
First of all, do you have a translucent ball?
sirhcman
« Reply #2 on: August 28, 2003, 02:32:48 am »
Yea.
GSXRMovistar
  • Last login:April 16, 2025, 06:01:17 pm
  • Gez, this is gonna be expensive!
    • forum.arcadecontrols.com/index.php/topic,148135.0.html
    • CoffeeCade
« Reply #3 on: August 28, 2003, 09:17:39 am »
I went with an extra bright LED, glued to the underside of my trackball unit and powered from the 5v+ out on my iPAC, works a charm.  :)
SpAwN
  • Last login:August 09, 2006, 01:41:48 pm
  • Mame Cab done, working on restoring a Wurlitzer
« Reply #4 on: August 28, 2003, 10:10:13 am »
I just did this last night. I used the Lazer Led's, I bought the small cluster of 4 leds and just taped it to the bottom of my trackball (the happ trackball I have has a hole on the bottom) http://www.glowire.com/Lazer%20LEDs.htm
There is a review of these lights at retroblast.com
http://www.retroblast.com/reviews/lazer.html
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #5 on: August 28, 2003, 11:19:03 am »
There's a hole at the bottom of the case that you point a light source towards... Tehre's a ridiculously expensive bracket you can  buy taht's just for that purpose... But you're better off fashioning your own bracket or hotglue gunning some superbright led's there as pointed out by the other posters...
good luck!
rampy
  • Last login:February 01, 2026, 01:32:52 pm
« Reply #6 on: August 28, 2003, 04:29:13 pm »
The "bracket" is a simple L-bracket you can get at any homedepot store for pennies.  Of course if you want to pay happs 30+ bucks to solder the bulb socket onto it then have fun.  I would go for 12 volt lights for one simple reason.  If you hook them up to an old powersupply, the lights ramp up as the powersupply warms up and slowly dim off as you switch it off. It's very cool.  As leds are resistors, they don't light unless there is enough voltage to run them, and thus you don't get this effect.
