Author Topic: Control Panel Wiring Troubleshooting  (Read 928 times)
Froca
  • Last login:May 01, 2011, 01:12:49 am
« on: April 16, 2011, 08:37:18 pm »
I recently finished wiring my control panel for a 4 player setup. Everything works great except for one issue.
A button is not firing if it is pressed immediately following another button. If the button is pressed anytime other than right after the button it will register.
Ex. Button 4 works if pressed anytime other than after Button 3. If Button 3 is pressed Button 4 fails to register the first press, but will register the second press.
Any idea on what I missed?
BobA
  • What Me Worry?
Re: Control Panel Wiring Troubleshooting
« Reply #1 on: April 16, 2011, 08:47:00 pm »
Check to make sure you are on the NO and Com contacts of each switch.
Froca
« Reply #2 on: April 16, 2011, 09:37:31 pm »
Button 3 was mapped to Alt. When I pressed button 4 in my test application it was not registering due to the focus being on the menu.
Yay for not having to rewire though!
