March 04, 2026, 11:38:19 pm
It is hard. You are using the wrong material. You should use black matteboard (with a black center). It's way cheaper and way easier to cut than foam board - they make excellent bezels.
Quote from: javeryh on April 08, 2011, 06:08:19 pmIt is hard. You are using the wrong material. You should use black matteboard (with a black center). It's way cheaper and way easier to cut than foam board - they make excellent bezels.Hey where do you buy that stuff?
Quote from: DataWest on April 11, 2011, 12:52:33 amQuote from: javeryh on April 08, 2011, 06:08:19 pmIt is hard. You are using the wrong material. You should use black matteboard (with a black center). It's way cheaper and way easier to cut than foam board - they make excellent bezels.Hey where do you buy that stuff?A.C. Moore or Michael's should carry it - anywhere you can get something framed. Just make sure you get solid black. Some matte board has a black exterior but a white interior. I found a local art store that sold the stuff in 1/4 sheets for like $2 or $3 - too bad they went out of business...
